NV5600 6 Speed 1st or 2nd gear start? - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 11-08-2013, 10:46 PM Thread Starter
CumminsRacetruck's Avatar
So I just bought this new truck and it has the NV5600 6 speed transmission and I want a clear answer on what gear to start in. Okay so let's say I'm not towing or hauling anything. If I'm at a stop light and I'm completely stopped (not uphill), should I start in 1st or 2nd gear? I have been starting in second gear usually but I hate when I get that lugging/grinding sound. If I don't accelerate fast enough while starting in second gear I get that lugging sound and I feel as if that can't be good for the truck. Should I just start out in 1st gear from now on?
CumminsRacetruck is offline
post #2 of 13 (permalink) Old 11-08-2013, 11:09 PM
Jsmuck94's Avatar
Starting in second is fine even if it feels like it's lugging a little isn't gonna hurt anything. And it beats shifting twice in like 2 seconds lol. 1st gear is super low in this trans more meant for starting on hills if you have a load, etc.
Sent from AutoGuide.com App
2001 2500 4wd QCSB 6spd - FASS 150 - Quadzilla Adrenaline PV2 - Banks High Ram Intake - Bigger Turbo Housing - 4in TBE - Leveled - 35in Cooper Discoverer AT3
Jsmuck94 is offline
The Following User Says Thank You to Jsmuck94 For This Useful Post:
dozer12216 (11-10-2013)
post #3 of 13 (permalink) Old 11-08-2013, 11:10 PM Thread Starter
Thanks for the answer. Also, you say the lugging/grinding sound isn't gonna hurt anything?
post #4 of 13 (permalink) Old 11-08-2013, 11:19 PM
TheDude724's Avatar
I always started in 2nd with my 04 that had a nv5600 when unloaded truck had 170k miles when I sold it to get my current truck no problems. Only used first when I needed to crawl in traffic or towing trailers.
Make sure your gear box has 6 qts in it (over fill by one quart) to keep it alive.
Some Thuren and Carli stuff but not enough...
TheDude724 is offline
post #5 of 13 (permalink) Old 11-08-2013, 11:21 PM
krashDH's Avatar
Both the answers above I agree. Really no need for first unless you have a load. You just need to shift sooner. If you are on a steep incline, put it in first and let the clutch do the work for you.
2004.5 2500 QCSB 6sp 4x4 SLT. 5" turbo back ,Isspro EV2 gauges, SB DD3250-6, custom intake, Pac exhaust brake w/ on-board air, Pusher intake, leveling kit, Bushwacker Pocket fender flares, custom front and rear bumpers, Smarty S06 POD
krashDH is offline
post #6 of 13 (permalink) Old 11-08-2013, 11:22 PM Thread Starter
Ok thank you. Did you ever have the lugging sound though?
2004.5 Dodge Ram 2500 5.9L 24 Valve Cummins with NV56000, Valair Dual Disk #3800 Plate Load, Valair Heavy Duty Hydraulic Assembly, Smarty S06 With UDC Custom Tunes, AutoMeter C2 Series Gauges, S&B Cold Air Intake, MBRP 5" TBE, Fass Titanium 150
post #7 of 13 (permalink) Old 11-08-2013, 11:24 PM
The only time I use first is when I just let the truck idle along in really slow traffic. Second gear starts are fine. And like jsmuck said, just one less shift in a couple of seconds.
2005 3500 QC/SB 6spd 4x4, Pacbrake, ATS manifold, AFE stage 2 intake, 5" TBE, Smarty S06, Raptor 100, II Dragon Fly 50hp injectors
md05cummins is offline
post #8 of 13 (permalink) Old 11-08-2013, 11:26 PM
Jsmuck94's Avatar
If we're thinking of the same thing then no. Does the truck possible have an aftermarket clutch? Some of them especially if dual disk will have a lot of chatter/noise at lower speeds and starting off which is normal and not a problem. Stock clutches in my experience are usually fairly quiet though
Jsmuck94 is offline
post #9 of 13 (permalink) Old 11-08-2013, 11:31 PM
I'm pretty sure its the same sound my truck makes. I don't know if my clutch is stock or not. That lugging sound is normal for me at least and I havent had any issues.
post #10 of 13 (permalink) Old 11-08-2013, 11:35 PM Thread Starter
I do not believe it has an aftermarket clutch. The thing that also leads me to believe that it does no damage is that, it only makes he lugging sound sometimes. It only happens if I'm not accelerating fast enough which seems to make sense.
post #11 of 13 (permalink) Old 11-08-2013, 11:35 PM
Jsmuck94's Avatar
Yea as long as the gear box is full like mentioned above I wouldn't worry about it
Jsmuck94 is offline
post #12 of 13 (permalink) Old 11-09-2013, 12:18 AM
krashDH's Avatar
I agree. You let the rpm s drop she'll groan for a second
krashDH is offline
