trac bar and tie rod ends? - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 11-02-2013, 05:40 PM Thread Starter
Wyoming BAMF
osiris's Avatar
Hey guys have a few questions. First off, is there an aftermarket replacement for tie rod ends that will last longer that 27k? I have replaced mine going on the 3rd time in 3 years. This last set lasted 27K miles. I run an 18" wheel with the Carli starter kit and 35" tires. Would love to find something that actually lasts. My trac bar is also bad but it was a carli one. Are those warrantied at all? I haven't had a chance to look...
Thanks guys
2006 quadcab Dodge 4x4 Laramie
osiris is offline
post #2 of 3 (permalink) Old 11-02-2013, 07:08 PM
rghavana's Avatar
tierods and tracbar
Hi
Not sure how you use your truck but if your going thru tierods at that rate and everything else is normal, I would give Doug Thuren a call or email.
He has some really heavy duty custom stuff and was very helpful to answer questions.
link to his site
Thuren Fabrication- Crossover steering kits
As far as Carli track bar issue You should contact the dealer you bought it from or Carli directly to discuss. I always talk to Pat Losko ,very helpful guy, his email is pat@thecarlisuspension.com, phone (888) 99-CARLI
I had an self inflicted issue with Carli torsion sway bay and the guys/girls at Carli had the replacement part across the country overnight !
I know some of these trucks end up with a rounded out bolt hole for mounting track bar and at that point your going to have to fix mounting holes.
Make sure bolts are torqued, I went 5lbs over these specs ,some torque wrenches could read +/- 5%
TORQUE VALUES:
- 14mm Bolts (18mm Socket): Tighten to 180 lbs/ft.
- 16mm Bolts (21mm Socket): Tighten to 215 lbs/ft.
I have Carli track bar, there is no lube point on heim end, so I spray heim joint end with a little silicon every once and while and grease urethane bushing end with Redline CV2.
Good luck
rghavana is offline
post #3 of 3 (permalink) Old 11-02-2013, 10:37 PM
MegaB's Avatar
I am Thuren equipped on my truck and love them . 35k and counting .
06 Mega 2500 4x4 auto ; EFI by AD , TaterBuilt 63/65 , rebuilt "built" 48re , Banks bolt-ons , aFe SS ex. mani. , HBS 2.5" level kit , MBRP , Tuff Country , lots of Thuren front end goodies , Doghouse 1pc.DL w/ spicer 1480's , 6X Isspro EV2 , Custom Billet Badges , Stock 2012 rims , Mopar Severe Duty setup w/ CAT 2 mic. filter , Retrax PRO , Amsoil OBP kit . Firestone Ride Rite . 2014 Mega Laramie leather interior .
Wifes ride : 08 MB R320 CDI
MegaB is offline
