Old 07-22-2008, 10:40 AM   #1 (permalink)
humming noise from front differential
i have a 2003 2500 and while driving now it makes a sort of humming noigse coming fromt he front end. i took the brake pads off and spun it and still hear it. sounds like it is coming from the fron dif. anyone have any ideas to what this could be? it is a constant noise but it gets louder around 35mph and keeps going until you stop.any help is appreciated. the dealer didnt help one bit
2004 2500 cummins 6 spd. quad cab. triple piller gauges, rest stock
dieselguy147 is offline   Reply With Quote
Old 07-22-2008, 10:44 AM   #2 (permalink)
Fabricator
id start with changing the diff fluid
'01 - 2500, 47re 2wd, 53 Block 70k miles and counting.... no cracks
4" turbo-back - Intake w/ heat shield - Traction bars - AirDog 150 - Edge Juice with Attitude HOT - HX-40 limited to 36psi - Getting Close to Leveled, rear dropped 2" - 7x.010" Injectors - 285/60-18's on Black Rims w/ Machined Lip - Tailgate Spoiler - Black Projector Headlights - 7" White Miter Cut Stack
14.2 @ 100 6psi boosted lanuch(hx-40 making 35psi, pre-injectors)
Rollin Coal is offline   Reply With Quote
Old 07-22-2008, 10:44 AM   #3 (permalink)
HotshotTX's Avatar
Hello! Is your truck a 2wd or 4wd? Also, does the noise decrease when you step on the brake pedal?
Darrell
HotshotTX is offline   Reply With Quote
Old 07-22-2008, 10:45 AM   #4 (permalink)
Fabricator
i hope its 4 wheel with a front diff
Old 07-22-2008, 10:47 AM   #5 (permalink)
it is a 4x4. the noise doesnt go away until the truck is at a complete stop. i thought it would be the wheel bearing at first but it doesnt change when i turn or step on the brakes. it just keeps going until it comes to a stop. its is the loudest at abotu 35 and sort of gets quieter when slowing down. once i get above about 45 i cant really hear it to good anymore but the stacks sort of over power the noise haha
Old 07-22-2008, 10:47 AM   #6 (permalink)
HotshotTX's Avatar
I missed that part. My bad!
Old 07-22-2008, 10:49 AM   #7 (permalink)
HotshotTX's Avatar
Besides the humming, is there any vibration? Also, what is the mileage on the truck? Sorry for all the questions, but starting at the basics and working up.
Old 07-22-2008, 10:59 AM   #8 (permalink)
no vibration at all really. its got 65000 on it now. all new u joints and balljoints
Old 07-22-2008, 11:12 AM   #9 (permalink)
HotshotTX's Avatar
I have had this noise happen to me with my previous Dodges. If it's the same noise I am thinking about, you might want to start around your driveshaft area. Noise location when it comes to humming can be deceptive at times. Does this makes sense to you? Check your fluid in the differential first. If fluid is clean and not dirty, then proceed with driveshaft inspection. Keep me posted on the findings.
Darrell
Old 07-22-2008, 01:06 PM   #10 (permalink)
dobienut's Avatar
Wheel bearing ?
2002 245Hp HO CTD,6 Spd 4x4 quad cab short box ,Glacier Fuel BOSS mechanical lift pump! Shake, Rattle and Roll...Cummins! http://img145.imageshack.us/img145/6...lmediumsp2.jpg
dobienut is offline   Reply With Quote
Old 07-22-2008, 01:12 PM   #11 (permalink)
Fabricator
you *usually* cant hear a wheel bearing or driveshaft on the lift w/o having the truck running and sometimes without the chassis ear.
Old 07-22-2008, 08:37 PM   #12 (permalink)
I have the same noise in my truck it just started yesterday...
It almost sounds like a tire, but its not.
when i jack it up it is sort of hard to spin the wheel...( on both sides) I am Very conserned its one of the diff bearings
2003 DRW 5.9HO 6speed Smarty S06 stock everything else!!
fmfkid250 is online now   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
