| 3rd Gen. Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
#13 (permalink) |
New England Chapter President
are you jacking up both sides or one at a time, one at a time is probably the limited slip thats making it feel funny.
'01 - 2500 53 Block - 600+ HP Build Up Thread
AirDog 150|285/60-18's|S&B Intake|Head Bolts at 125lb/ft|66/71/14|Custom Injectors|.093" Connector Tubes|Suspension Work|Custom Charge Piping|4" into 7" Miters|Water/Meth|Autometer Gauges ***NV4500 swap and 4 Link in the works*** TOO MUCH POWER FOR TWO WHEEL DRIVE |
#14 (permalink) | |
Does the Front have Limited slip or is it open? I dident check the Fluid yet. I am going to check for oil Shavings in the Fluid.
2003 DRW 5.9Smarty 375WHP 720WTQ Pittsburgh Performance $55 3 pulls dynojet 224X 4 or more trucks $50 Located 610 6th St Clairton PA 15025 PM ME! |
#15 (permalink) | |
Banned
#16 (permalink) | |
#17 (permalink) |
i would take the driveshaft off and spin it. If it still makes noise its either wheel bearings or a bearing inside the dif.
2005 dodge 2500 4x4 4 door short bed 16 inch one up offroad lift with coilover all the way around 40 inch toyos 22x14 chrome diesels custom mbrp exhaust silencer ring mia gutted torque tube ppe sold smarty on order , finally custom paint
#18 (permalink) |
well i took the dif cover off right now and there are no metal shavings but the fluid did look pretty crappy. how many bearings are in the dif and how hard are they to replace. i put a locker in my ford but im not familiar with this front end. any help is appreciated
2004 2500 cummins 6 spd. quad cab. triple piller gauges, rest stock |
#19 (permalink) |
going to order some side dif bearings tommorow and put them in. hopefully thats the deal. new fluid didnt help. dont think its the wheel bearing. any way to test either for sure before wasting the money?
#20 (permalink) |
![]() I've read this entire thread, hoping to find a conclusion to this matter. I've got the same problem with my 2wd 04 2500 quad. It sounded similar to off-road tire noise, but after changing tires, ball joints, checking wheel bearings, alligning....it still makes the exact same noise. Humming at lower speads gets pretty loud and does not make a difference on or off the gas, or in or out of gear. Still the same. Pitch rises with speed. Did dieselguy147 ever fix it?
#21 (permalink) |
I am having the same humming problem. I also changed the wheels with no luck! Mine started out making the noise between 50 and 70 mph. It would go away beyond 70. Now it is making the noise and vibrating beyond 70. Letting off the gas doesnt make it stop. I am not sure what it is. My next step was to fork over the 600 and replace the wheel hub assemblies. Anyother suggestions? BTW, it is an 05 4wd.
