BLACK engine oil, normal??? - Dodge Cummins Diesel Forum
post #1 of 28 (permalink) Old 07-20-2008, 10:17 PM Thread Starter
Mega Dodge's Avatar
I change my oil every 6000 mi. with Amsoil 15w-40. At every oil change the oil is nasty black with soot. After I fill it with fresh oil and run it for a minute I check it again and its all ready black again.
This is normal right? Should I be concerned?
Will a bypass filter help?
2012 Mega Cab 3500
Mega Dodge is offline
post #2 of 28 (permalink) Old 07-20-2008, 10:19 PM
Canadian_Diesel1964's Avatar
Yes absolutely normal and yes a bypass will help somewhat..no need to be concerned the CR's are like that....
2004 2500 4X4 Mag-Hytec Tranny Pan, Frantz TP Filter, Coolant Filter, MBRP 4" TBE with FTE Resonator, Raptor100 with WS and 2 Mic Filter also in box, XRF Ball Joints and All 4 Tie Rods
IAFF LOCAL 142
(Professional Firefighter)
Canadian_Diesel1964 is offline
post #3 of 28 (permalink) Old 07-20-2008, 10:24 PM
Cummins CrAzY
DevilDogDiesel's Avatar
All diesels are like that.
2000 2500 ext. cab short bed, AFE cold air intake, single 6 inch stack, SPS 62 turbo, FASS 95, Scheid Lightning II's, .093 connector tubes, Maxspool valve springs, A1 head studs, Fire ringed head, Adrenaline, HP intercooler boots, 6 speed with a Haisley Street puller clutch, custom trac. bars, draw straw
DevilDogDiesel is offline
post #4 of 28 (permalink) Old 07-20-2008, 10:25 PM
smokedrail's Avatar
iTrader Score: 4 reviews
bypass will help some but that is just a diesel thing nothing to worry about.
06 cummins
96 cummins
95 cummins dump
smokedrail is offline
post #5 of 28 (permalink) Old 07-20-2008, 10:29 PM
Tech Specialist
SmokinDiesel's Avatar
Totally normal.
Michael Charlton - Keystone Diesel
SmokinDiesel is offline
post #6 of 28 (permalink) Old 07-20-2008, 10:45 PM
Banned
DORKWEED's Avatar
Location: "The Peoples Republic of Illinois".....behind enemy lines
Black oil....normall!!! Changing Amsoil oil at 6k intervals.......waste of Even without a bypass, Amsoil oils usually go much longer than that and are still analytically "good"!! And I don't run Amsoil engine oil either!!!!!
DORKWEED is offline
post #7 of 28 (permalink) Old 07-21-2008, 12:05 AM
Garrett's Avatar
doesn't it also get blacker sooner because of the engine trapping the exhaust in the cylinder!
98 12v 5sp work truck lots of work done
04.5 auto way to much work done to it
11 auto enough work to make it sound good and go fast
Garrett is offline
post #8 of 28 (permalink) Old 07-21-2008, 12:28 AM
TDI
Yep, my Volkswagen's oil is pitch black 5 min. after an oil change too. Actually the Cummins seems to stay cleaner looking longer than the VW.
2004 Quad Cab 4X4 HO 6 speed manual
2002 Volkswagen Jetta GLS TDI 5sp (Yes, it's a DIESEL)
2012 Subaru Outback Limited (wife's)
TDI is offline
post #9 of 28 (permalink) Old 07-21-2008, 12:44 AM
COFFMAN CUSTOMS
AH64ID's Avatar
I wouldn't go that far... I have been around diesels for more than a day or two and they dont all do that... My dads 3406 Cat would stay golden for hundreds of hours with a bypass.... The HPCR is a different breed based on in-cylinder EGR.
AH64ID is offline
post #10 of 28 (permalink) Old 07-21-2008, 12:47 AM
Burgundy Bomber's Avatar
mine was black after startup before I had all thes truck prollems...now it's amber for a good 10 miles!!!!
Truckless, Carless, Homeless, Jobless
so I'm having a rough decade...... oh well.
Burgundy Bomber is offline
post #11 of 28 (permalink) Old 07-21-2008, 12:59 AM
dom42's Avatar
that's just the way these third gens are.they have a "in cam egr".........check this link out.
in cam egr:thumbsup
hope this helps.
a bypass wont clean it up.....trust me i have one. but what i t will do is filter out all the soot in oil down to like 3microns or less. i am able to achieve 30,000miles + on the same oil. could go longer but that's just were i like to change. good luck.
Jeepecodieselfix.com "Protect it, Guard it, Shield it" - your JeepEcodiesel is not so trail rated.....
BoogieRated.com "Got Bumpstops"
dom42 is offline
post #12 of 28 (permalink) Old 07-21-2008, 08:11 AM
Semicrazy's Avatar
Mine oil always turned black right away both on my current truck and my last truck right after the oil change.
But since adding a Smarty my oil has been much cleaner, I don't know if I should be happy or worried that something is wrong?
I am at 7500mi on my synthetic and getting ready to change, and yet when I pull the dipstick the oil is still fairly clean. I can see all the the cross hatch and low line no problem . I will try to take a pic and post it.
03HO, 6spd, 5in stacks, BHAF/Cool Hose, Smarty/EZ, AD150, 3250DD, HTT62/71, Fluidampr, Isspro EGT-FP-Boost & Quad RP, Leveled...06, LBZ, Transgo Jr, 6" lift, 6in stacks, Edge Race, Raptor...07, LBZ, 7in Lift, 35s, Banks 6gun, traction bars
Semicrazy is offline
