Old 07-14-2008, 11:10 PM   #13 (permalink)
A write up with pics and part numbers for all the fittings and such would be great. Thanks for doing all the research too.
2006 Dodge, 2500, CTD, 4x4, 6 Speed, SLT, Thunder Road Package, Mineral Grey, MBRP Muffler Replacement Kit, Fast Idle Enabled.
NickBeek is offline   Reply With Quote
Old 07-14-2008, 11:59 PM   #14 (permalink)
WoodRep's Avatar
Good write up AH! You have to keep this one going with some pics and parts. I am looking into GDP's system and share your concern for the best filtration as well.
Wood
'05 Quad-Cab 4X4, Amsoil Nano drop-in, gutted torque tube, silencer MIA, TAG, BMK-11 bypass, SmartyJr., Dipricol Optix Trans/EGT/Boost, 2" leveled, 295's on H2's, Rancho 5k's front 9k's rear, 51" Donaldson, still don't like obama
WoodRep is offline   Reply With Quote
Old 07-15-2008, 12:48 AM   #15 (permalink)
Super Moderator
rufushusky's Avatar
Originally Posted by ah64id View Post
According to Baldwin the SAE standard changed in the late 90's. Prior to the change 2 microns was "testable", and was commonly used. When SAE changed the standard there was no way to measure 2 microns, 5 microns became the smallest absolute rating. It was found that most 2 micron filters on the old standard were 5-7 on the new standard, so some filters are even better but rated higher.
So what I gathered was that Baldwin and Fleetguard now report on the new standard... which is a change and why many refer to the filters as 2 microns... And Cat and Donaldson still report on the old system.
So the Baldwin BF7633 meets all the requirements of the 1R0750, and I can get the 7633 for about $4 cheaper, so thats what I will run...
It kinda annoyed me that companies are reporting ratings based on 2 standards... but they all filter about the same...
Interesting.....good stuff man!:thumbsup
Dennis
04.5 Ram 2500 Reg Cab 4x4 5.9, 48re, AEM, Smarty, Banks High Ram,FASS HPFP, Boost/pyro/trans/FP/RP gauges, 5" Exhaust, Cat 2 micron fuel filter, Amsoil Bypass, Reese Hitch, Single Disc Converter w/ Strictly Diesel VB
1997 Fleetwood Prowler 26.5"
Check out: Rig of the Month!
http://www.cumminsforum.com/forum/rig-month/
rufushusky is offline   Reply With Quote
Old 07-15-2008, 01:47 AM   #16 (permalink)
Diesel Poser
slagburn's Avatar
Very good info, thanks for posting it.
I'm running the BF1212 and BF7633 between the OE lift pump and OE filter for now, based on your findings about the 1212 I might switch to a vacuum setup between the 1212 and the 7633 - my fuel pressure measured before the OE filter isn't exactly great at WOT with the stock LP which is another reason for redoing the system.
07.5, 6.7, Auto, QC, 4x4, Lots of gauges - ISSPRO (Pyro, Boost, Trans Temp) PriCol Optix (Fuel Pressure Lift/Rail) AutoMeter (Oil Pressure) - Dynatrac Free-Spin Hub Conversion Kit - RETRAX bed cover - homebrew stealth shaved bluetec badge - plugged up EGR - Baldwin BF1212 water separator and CAT 1R0750 fuel filter - MSD Dashhawk - Baldwin B164 Bypass Filter - BD SBS - TS MP8
When a strong man armed keepeth his palace, his goods are in peace - Luke 11:21
slagburn is offline   Reply With Quote
Old 07-15-2008, 01:53 AM   #17 (permalink)
Local Rotor Head....
ah64id's Avatar
What will your pressure drop to?
I am thinking that if I ever go to a different fuel pump it will probably be the Walbro between the 1212 and the OEM filter. I am thinking that the 03-04 "draw straw" would probably be best as well.. .I don't need the volume, just the reliability at low fuel.
ah64id is offline   Reply With Quote
Old 07-15-2008, 09:27 AM   #18 (permalink)
MikeyB's Avatar
Excellent information! Another fan of the Baldwin PF7977.
MikeyB
'03 2500 QC SWB 2wd, 305/555, NV5600, 3.73 LS, Airbox mod w/Amsoil Ea, Adjustable boost elbow, PML diff cover, Westach boost/EGT gauge, Line-X, Sirius, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake, Smarty/Van Aaken C3.2
MikeyB is offline   Reply With Quote
Old 07-16-2008, 01:42 AM   #19 (permalink)
Diesel Poser
slagburn's Avatar
5-6psi WOT on an uphill freeway onramp with no mods, runs around 9psi at 65mph cruise.
Old 07-16-2008, 03:25 AM   #20 (permalink)
ah64id's Avatar
for 3 filters on a OEM pump thats not bad at all...
Old 07-18-2008, 01:15 AM   #21 (permalink)
Diesel Poser
slagburn's Avatar
Currently my fuel pressure sensor is after the Bladwins and before the OEM filter so 2 filters, no telling what the pressure is like at the IP.
Old 07-23-2008, 06:45 PM   #22 (permalink)
ah64id's Avatar
Alright so I did some more digging... well actually the Baldwin guy told me they use a multipass rating for there fuel filters... WTF.. thats for oil filters...
So back to the drawing board, the BF7633 is only 7 microns single pass. The PF7977 stays 5 microns, and the BF1212 is 97.88% (not quite absolute) at 20 microns...
So I am going to keep the BF1212's I have, I returned the BF7633's, if favor of the Cat 1R0750.
Here is my install thread.
Old 07-24-2008, 10:19 AM   #23 (permalink)
DBLR's Avatar
Never heard of any fuel filter being tested for several passes to gets its rating, wonder if he misspoke?
2006 Ram 2500 Big Horn Edition Auto 5.9L Mineral Gray Met. Quad Cab SB 4X4 SRW 3.73's
DBLR is offline   Reply With Quote
Old 07-24-2008, 12:30 PM   #24 (permalink)
ah64id's Avatar
He didn't misspeak, in fact he gave me the ISO standard for multi-pass. Since then I have found Cummins and Cat data stating that baldwin uses multi-pass on some of there filters.
