| 3rd Gen. Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
#13 (permalink) | |
As for bypassing the co-pilot to verify it isn't the problem, I haven't actually manually bypassed it. It should automatically bypass once shut off. I know there is always the possibility of that not happening, but the problems I'm experiencing are not consistent with torque converter lock-up. Rather, the problem of the trans not up-shifting from 1st to 2nd until redline (3000 rpm), is 100% consistent with trans temperature, and using reverse gear. The trans shifts absolutely normal from a cold start. It's not until after warming the transmission up to normal operating temperature, then using reverse gear that I begin to experience problems. After meeting those 2 criteria, it exhibits delayed shifting in 1st gear, and harsh downshifting upon deceleration. It's my understanding (by the little research I've done in the past few days) that when Reverse is engaged, the line pressures in the transmission increase by about 55% over forward gear pressures, so I'm almost wondering if there is something about the pressure from using reverse that is causing leakage within the valve body that is pressurizing the low (1st gear) valve beyond what it is supposed to withstand, and causing it to stick until the trans has time to cool down (metal parts changing size and binding due to heat expansion + high line pressures, and then cooling down and freeing up the sticking valve). This is, of course, purely speculation. And as previously stated, I'm no automatic transmission expert by any stretch of imagination. Just trying to throw something out there.
'05 2500 4x4 auto - ATS Stage 4 w/co-pilot, Edge Juice w/attitude (HOT flash), Phat shaft 64, cat delete/high flow muffler, custom CAI. |
#15 (permalink) | |
06 3/4 4x4, Stage 3 ATS tranny w/ five star convertor, auto meter phantom II,aurora 3000, 3% tint all around black beauty, AFE stage II, Crazy Larry , air dog 100, camo seat covers, kick ![]() ![]() system, 18's moto metal ,33x12.50 baja atz
#17 (permalink) | |
I really need to learn more about valve bodies, and how they function...
#18 (permalink) |
Isn't the warranty the main reason to go to ATS? 3 years unlimited warranty right?
06 Dodge Cummins Mega cab Laramie edition, all the goodies except 4x with: Superchips programmer, Banks Techni-cooler, hi-ram intake and torque converter, Mag-Hytek DD Pan, AFE magnum force intake, 4" silverline exhaust, silencer ring MIA |
#19 (permalink) |
Update: Received the valvebody today. Pretty punctual with shipping! That's always a plus. I have to work graveyards this week, but I'm planning on doing the swap tomorrow morning if the temperature outside isn't too cold. It has come just in the nick of time, as the trans seems to be worsening, and it's beginning to act up w/out provoking it with Reverse. It now seems to be solely temperature related.
#20 (permalink) |
your taking it to a shop to have the VB replaced?
1998.5 24v, 5 speed, quad cab long bed, 17 inch wheels with Big-O XT's edge juice, AFE CAI, 4 inch bully dog TBE, what silencer ring? 1991 CTD, 7 inch hood stack, tons of fuel, would you like some pollution with your prius? |
#21 (permalink) |
I'm going to tackle the job myself. I found a set of install instructions, and it seems to be pretty straight forward. Just need to make sure the bolts go in the proper locations, as there are several different sizes.
#23 (permalink) | |
![]() Anyways, good to hear I'm not the only one who's had this problem, or maybe it's not such a good thing...since we both own ATS trannies. But, at the least it's a fairly simple problem to tackle.
#24 (permalink) |
Well if your doing the work your self because ATS is not paying for it to be fixed, that has a lot to say about there warranty.
2006 Ram 2500 Big Horn Edition Auto 5.9L Mineral Gray Met. Quad Cab SB 4X4 SRW 3.73's |
