injector testing - Dodge Cummins Diesel Forum
post #1 of 23 (permalink) Old 06-06-2013, 03:57 PM Thread Starter
injector testing
what places can I send my injectors to to be tested and how much do they usually charge? I have called exergy and emailed them and no one answers
06 3500 QC DRW, 2nd gen manifold swap, 5'' TBE str8t pipe/ FTE resonator, 4.5" lift, steering stabilizer, quadzilla boost fooler, Freightliner 22.5'', smarty jr, c&c fender flares
Tekkaomega is offline
post #2 of 23 (permalink) Old 06-06-2013, 06:18 PM
TECH SPECIALIST
steelhead01's Avatar
Beans Diesel Performance
About Us
We Can Test Your Diesel Injectors
High Performance Cummins Injectors
Diesel Injection Systems | Santa Maria California
Diesel USA Group Locations
Our Services
Fuel Injection Rebuilds Hutchinson, KS - Diesel Control Technicians
Diesel Injection, OEM Fuel Injection Parts & Service.
Diesel Fuel Injection Service, Inc
Services – Midwest Fuel Injection
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
post #3 of 23 (permalink) Old 06-06-2013, 06:31 PM
TECH SPECIALIST
Common Rail Injector Testing
Welcome to Diesel Injection Service, Inc. :: Total Diesel Care :: DIS Fuel Injection Equipment Services Available
Service & Repair
http://www.uniteddiesel.com/testing-rebuilding.htm
http://www.dumasdiesel.com/services.html
http://www.advanceddieselinjection.com/services.html
post #4 of 23 (permalink) Old 06-19-2013, 10:35 PM Thread Starter
so had my injectors tested by delco in Oklahoma city, they said all 6 had high return rates and 4 had higher than normal pop pressure which would indicate a blockage of some sort. any thoughts ? I don't know the numbers I forgot to ask. but judging by this should I replace them ? what kind of damage can be done putting them back in?
post #5 of 23 (permalink) Old 06-20-2013, 01:31 AM
waywardtravel's Avatar
Get your injectors out of there.
In a different type of injector they open on pressure. Ours do not.
Ours are opened by a solenoid controlled electrically.
We can't fail a POP test which would be what most injection companies would call the other type of injector test.
If they told you that I'd doubt they tested them at all.
I guess if you know them maybe they mixed you up.
04.5,QCSB, Goerend full billet, 4:10's, MPI 63/475,Engineered diesel 63, Exergy 40%'s,Dual CP3's, gauges, Airdog 2 165, S-06 TNT R and Gordon's UDC,edge JWA CTS, Top Gun Customz 3 1/2", Carli BJ's, BIG steering box, 5100's, Helo 791's with 35's.
When all's said and done there's usually a whole lot more said than there is done.
waywardtravel is offline
post #6 of 23 (permalink) Old 06-20-2013, 05:04 AM
TECH SPECIALIST
Del Co. Ok. City only has a Hartridge IFT 70 single injector test analyzer.
Capable of testing the Bosch HPCR injector, not capable of printout so only have the word of the tech running the test
Slow with only 1 injector at a time so some techs take "shortcuts" might we say
doesn't say their staff is capable, from the repeated conversation, doesn't sound like it.
what symptoms were you experiencing to cause you to send injectors in for testing?
do they correlate to the test findings?
post #7 of 23 (permalink) Old 06-20-2013, 07:01 AM Thread Starter
good pop off white smoke on startup decreased fuel mileage decrease power which is pretty noticeable higher egts, my idle got real choppy
post #8 of 23 (permalink) Old 06-20-2013, 07:04 AM Thread Starter
does anyone know of any places in upstate New York that I can actually take them to myself
post #9 of 23 (permalink) Old 06-20-2013, 07:09 AM Thread Starter
Delcos website says they are Bosch authorized to service n deal with Bosch injectors
post #10 of 23 (permalink) Old 06-20-2013, 10:30 AM Thread Starter
I'm getting them to email me the test reports so I'll have some real facts
post #11 of 23 (permalink) Old 06-20-2013, 03:07 PM
TECH SPECIALIST
""""white smoke on startup decreased fuel mileage decrease power which is pretty noticeable higher egts, my idle got real choppy """"
all symptoms point toward worn stuck open leaking injector nozzles needles/pintles.
how many miles/hours on the injectors? if over 100k, cut your loses and buy 6 new Bosch only, along with 6 new improved style upgrade low corrosion stronger tubes, the ones with the single alignment bar not the balls.
pull an oil sample and send in to an engine oil analysis lab such as Blackstone. request specific test for diesel contamination in engine oil.
DO NOT run the engine until problem is found and resolved.
Leaking injector nozzles kill Cummins HPCR 5.9s
may be matter of miscommunications understanding of terms with Del Co. on injector test results. what tekmega is reporting as "4 had higher than normal pop pressure" may be actually the person on phone stating higher than normal aka spec nozzle leakage rates.
again, NO POP testing of HPCR 5.9 injectors, they do NOT have a spring loaded pressure actuated release of diesel from the injector. Old school never to return mechanical injectors.
Strictly electric solenoid controlled pintle/needle release of diesel initiated by electrical current pulse originated by and controlled by the ECM brain.
The Following User Says Thank You to steelhead01 For This Useful Post:
Ram_Wagon (06-20-2013)
post #12 of 23 (permalink) Old 06-20-2013, 06:28 PM Thread Starter
I have 118k on my truck, they told me none of the nozzles were cracked or leaking, and the NOP test was high if that makes a difference.the report shows nop spec is 145-175, one was 170 the rest were higher and that's in bar, ill post the report when i get home
