Engine still sounds like it has a fuel knock after injectors and still no power... - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 06-01-2013, 08:03 PM Thread Starter
I had new injectors installed a couple months ago but truck still is performing poorly and is noisy as hell. Had the new injectors pulled and tested at Bosch certified shop and everything tested good. Had them reinstalled and had another valve adjustment done. It quieted it down some but still has some knocking going on. I have changed everything on the the fuel system except the CP3. We exchanged parts from another truck to verify the rail sensor, FCA and PRV are good. The guy checking the truck out cracked the fuel supply nut on #1 tube slightly at idle (I know, I know.. He said he knows its high pressure and he barely moved it).. The truck smoothed out and sounded great, tightened it and knock back! Same with #3. Ideas??
dodgerzr is offline
post #2 of 22 (permalink) Old 06-01-2013, 10:29 PM
cerberusiam's Avatar
Injectors are junk, at leasy #1. Where did you get them from?
cerberusiam is offline
post #3 of 22 (permalink) Old 06-01-2013, 11:30 PM Thread Starter
Rocky Mountain Cummins. Had Southwest Diesel in Phoenix test the injectors and they came back good.
dodgerzr is offline
post #4 of 22 (permalink) Old 06-01-2013, 11:50 PM Thread Starter
So my question is.. Why when he shut the injectors down on by one, did the sound not change yet when a injector line is cracked it sounds normal? He used his scan tool and then capped them to verify. Makes no sense to me..
dodgerzr is offline
post #5 of 22 (permalink) Old 06-02-2013, 08:55 AM
Because when he loosened a line the rail pressure falls.
Your rail pressure it too high.
What happens when you unplug the FCA with it running?
Does it change the knocking?
1998 2500 4X4. built my own automatic. Built my own engine too.
j-fox is offline
post #6 of 22 (permalink) Old 06-02-2013, 09:51 AM
Shutting down an injector does not effect rail pressure, cracking a line does. The drop in rail pressure changed the injection characteristics.
Usually a bad tip(s) or pintle in there somewhere. Bench testing will not tell you how they run in the truck, as you can see.
post #7 of 22 (permalink) Old 06-02-2013, 03:11 PM Thread Starter
Rail at idle is 6800 and when he unplugged the fca it only went to 22800
dodgerzr is offline
post #8 of 22 (permalink) Old 06-02-2013, 07:07 PM
Thats normal, everything sems to be fine there.
post #9 of 22 (permalink) Old 06-02-2013, 11:40 PM
TECH SPECIALIST
steelhead01's Avatar
with the miles and 2 probably failures already replace all 6 with new.
they're wear replacement items like water pumps and tires. look at them as spark plugs on HD work gas engines and what conditions they are exposed to.
Workman's comp does not pay for HPCR diesel spray into human tissue due to mechanic's screw up in any state. Self inflicted intentional act wound from dangerous unapproved unauthorized trouble shooting tech. that is specifically pointed out in training as NO
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
post #10 of 22 (permalink) Old 06-04-2013, 01:35 AM Thread Starter
So I have less than 1000 miles on new injectors that have been tested like everyone always suggests and I need to replace them again? So what is the real determination of a bad injector? I cant get them warrantied because they passed bench testing and cylinder contribution test.
dodgerzr is offline
post #11 of 22 (permalink) Old 06-04-2013, 01:57 AM
easymon's Avatar
You can test all you want but they can still have probs. been there test good and still hammerd . Buy new only is your best bet the 1 s you got at cummins are remans to. You could buy 1 injector and swap 1 at a time to find culpert but time is money to just not what i would recommend.
06 dodge 3500 G56 ,EFI,BY Zach Fuller at starlite diesel,tunes by,anachy Les at silver bullet ,valair dd organic,fass 150
2013 Ram Laramie longhorn 342 none assin
easymon is online now
post #12 of 22 (permalink) Old 06-04-2013, 02:50 AM Thread Starter
I appreciate the feedback, I really do. Just trying to fix my truck that has driven correctly 2 days of my 7+ months of ownership. The reason I went to Cummins for injectors was that I couldn't find any "NEW" injectors with the proper spray pattern. I almost bought Exergy, but I researched on here and seems its 50/50, maybe too many opinions out there. You would think that the manufacturer of this engine would sell decent parts for it regardless, since it is their reputation. Trust me, I see people say all the time "If you want to play, you gotta pay". I subscribe but I need some play. Thanks again for the input.
dodgerzr is offline
