2 micron fuel filter - Dodge Cummins Diesel Forum
post #1 of 16 (permalink) Old 03-19-2013, 03:29 AM Thread Starter
Backwoodsboy7's Avatar
What do I need to convert to a 2 micron fuel filter?
2005 Dodge Ram 3500 SLT 4x4, 2.5" HBS leveling kit, 35" Pro comp xtream A/Ts on 17" Falken ORC952s, TBSP 5" dimondeye, T/Rex control arms
Backwoodsboy7 is offline
post #2 of 16 (permalink) Old 03-19-2013, 05:25 AM
Rpadar's Avatar
This one is for the engines without the apps mounted on the engine. (Big black bell?). They make one for both. Just pic what u need
http://www.glacierdieselpower.com/pr...d=MK20307-CHMB
2004 5.9 smarty S06 pod, 4 inch mopar air filter, stock exhaust aero muffler, boost and pyro, fuel rail, fuel pres, trans temp autometer,super built 48re lift pump in tank, 2 inch leveling kit, gdp 2 mic filtration pure performance adj. control arms, lightforce, fat mat through out
Rpadar is offline
post #3 of 16 (permalink) Old 03-19-2013, 09:02 AM
davesupra's Avatar
I used the Cat setup, it mounts the filter under the truck.
Cummins CAT Fuel Filter Kit
DaveH
'07 2500 5.9 CTD
6-speed - No cat/Dsport Predator
davesupra is offline
post #4 of 16 (permalink) Old 03-19-2013, 06:41 PM
Glacier Diesel Power - Product Detail
I used this kit as well. I have had it for almost a year and 10k
2006 MegaCab 2500 SLT 4x4 SRW Cummins, BD transmission, convertor and killer b turbo, rear diff pans, ride rite bags, hellwig rear sway bar, s&b air filter, smarty jr, BD brake, GDP 2 micron,leather seats.com kit, borgeson shaft and box, 08.5 steering 421HP 837LBFT
MegaCleanCab is offline
post #5 of 16 (permalink) Old 03-19-2013, 06:48 PM
davesupra, I see on the web site that they say mount the Cat before the stock filter. That sounds back wards to me. Is that how yours is mounted? I am going to get one for my 2003, but seems like it should be mounted after the stock. Thank you for any info.
2003 3500 SLT 2 wd qclb.
S&B air filter. New vb in tranny.
rehless is offline
post #6 of 16 (permalink) Old 03-19-2013, 07:01 PM
Rpadar's Avatar
While I personally would chose to have the filter under the hood. Under the truck can be trouble. The cat filter is 4 micron. Fleet gaurd is what u want.
Rpadar is offline
post #7 of 16 (permalink) Old 03-19-2013, 07:55 PM
Cat advertises the filter at 2 microns. Are they lying? They may be, that's why I ask. I ordered one and my question is why mount it before the stock filter. thanks, guys.
rehless is offline
post #8 of 16 (permalink) Old 03-19-2013, 08:10 PM
Rpadar's Avatar
I think it's a 5 micron or 4. They changed the rating. Either fleet gaurd or the cat is fine but I chose the fleet gaurd because it came in my gdp kit. I've heard negative about the cat filter
Rpadar is offline
post #9 of 16 (permalink) Old 03-19-2013, 08:16 PM
Thank you, Rpadar. Can any one give me info on why the Cat kit should be mounted before the stock filter? Thank you all.
rehless is offline
post #10 of 16 (permalink) Old 03-19-2013, 08:47 PM
i am going to paste a $75 setup that is the best there is. some of our 06's still have the stock filter that was installed at the factory. we mount the filters just forward of the fuel tank. we run a fleet of dodges and recently installed one on a 06. there is two bolts through the floor board for a rear seat option at this location. some of our trucks use them others do not. get a 2" x 3" piece of angle iron 6" long. make a card board template that the two bolts and keeper nuts will go through hold the template on the inside against the 2" part and drill the two holes they will be about 5/8" i think and about 3 7/8 " between. center the holes on the 2" and near the edge on the 2" hold the angle iron over the bolts with the 3"part the furtherest away from the tank and drill a 1/4" hole between the two holes, keep drilling through the floor board. now after you mount the filters to the angle iron just simply mount it with a 1/4 grade 8 bolt. this is the only hard part the other items is easy. the total time including building the bracket is about 1 1/2 hours. i will give you napa numbers but they can cross reference to wix or car quest. the two bases are 4770 the water separator pre filter is 3406 the 2 micron filter is 3674. use a 3/8" nipple with about 1/2" space in the middle connect the two bases together observing the in and out. because of this the mounting plate on one filter base is about 1" further out than the other. install two 90* 3/8" barbed fittings on the bases and temporary bolt the angle iron up and hold the filters up to it. make sure everything clears and mark the one base that touches the plate to drill the three holes to mount the filters. next cut the feed fuel line at this location and bend the lines out a little and install 3/8 hose over the lines and to the barbed fittings. i put a small amount of flair on the steel lines. but i do not think it is necessary. Bleed the air out through the stock filter before trying to start it. use a gauge and do not change the filters until you see a four pound drop this should be about every 150,000 miles and the stock filter will never need to be changed. Cheapest place is Wix Filters - Bases: FleetFilter Secure Online Store
your filter base has two inlets and two outlets on each base be careful to connect the nipple between the outlet of the first filter to the inlet of the second. only one of the bases get's the bolts as the offset places the second base about a inch away from the plate. we use to make spacers on the first ones and then decided they were not needed
063500dually4X4qcg56,dynatrac,bd exhaust brake,donaldson m090535muffler,cfm+,winspeed spacer,smartyjr,taylor wings,luberfiner bypass filter,psm cold air,cool hose,tag,air tab's,pdr cam,ddp50hp injectors,htt 62 65 13ss,ss manifold, turbo and manifold blankets
carl48 is offline
post #11 of 16 (permalink) Old 03-19-2013, 08:55 PM
Thanks, guys. I've purchased a Cat kit. Being a noob, I probably shouldn't have. Now, if I want to have the secondary filter mounted after the oem, do I need to purchase a different kit? A straight to the point answer would be greatly appreciated. I can't see the wisdom of mounting a 4 micron filter before a 5 or 7 micron filter. Some one please set me straight. thank you all.
rehless is offline
post #12 of 16 (permalink) Old 03-20-2013, 12:02 AM
Rpadar's Avatar
Yes
Rpadar is offline
