2006 Dodge 5.9 Diesel wont start !!!HELP!!!! - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 01-25-2013, 12:23 AM Thread Starter
I just purchased a 2006 Dodge ram 2500 5.9 Diesel with 123k Miles. I drove the truck home 525 miles. i stopped twice for fuel and motor started no problem. while i was driving(1 hour away from home) i noticed a slight miss for about 3 seconds. it was so slight I starting second guessing myself then it was fine the rest of the trip home. The next morning i went to start it to do a few things and the motor just turns over(normal speed) but wont start. when i turn the key on i can hear the lift pump turn on in the fuel tank. I also cracked the fuel line before the injectors and fuel is coming out. i checked the codes p0336 and p0541. p0336 is the first code which is the crank sensor. i Just bought a new cranks sensor thinking it would be fixed and it still wont start. I live in sunny San Diego and the temp is 70 deg outside so i dont think the intake heater A circuit low would affect it. After further research im guessing there might be an open circuit going to the computer.
PLEASE HELP ME TRY TI FIX IT.
The truck would fire right up after fueling up. crank maybe 2-3 times and it was running perfect.
da_lohman is offline
post #2 of 6 (permalink) Old 01-25-2013, 01:34 AM
Lake Mead Explorer
Slats Extend's Avatar
I had an intermittent no start on my 2005.. Chased it down for a year as this did not happen very often..
Ended up being a bad Fuel Rail Pressure Sensor. It never did set any codes...
You could pull the connector off and check for any corrosion.
Just a stab in the dark for you!
2016 3500 Laramie Limited, AISIN, 3.73,RVK 3600. Titan 55 gal fuel tank, BD TSB
2012 Ram 3500 CCLB Laramie 4x4 DRW 68RFE 4.10 ,
BUYBACK.
2005 Ram 3500 CCLB Laramie Dually,auto 4x4 3.73 Traded
2001 Ram 2500 QCSB SLT+ Auto 4x4 3.54 SOLD
1992 W250 Getrag, SOLD
Slats Extend is offline
post #3 of 6 (permalink) Old 01-25-2013, 02:19 AM
Try disconnecting the fan clutch and see if it starts. I've heard a bad clutch can cause a similar problem.
2006 SLT Mega, 4x4, Auto, EFI, Carli and Thuren things, one piece Al driveshaft.
2014 Limited Mega, 4x4, Thuren, and other good stuff - thanks Rich!
Rimcrew is offline
post #4 of 6 (permalink) Old 01-25-2013, 02:54 AM Thread Starter
thanks for the help ill try that tomorrow
post #5 of 6 (permalink) Old 01-25-2013, 06:52 AM
TECH SPECIALIST
steelhead01's Avatar
Get the cold cranking rail pressure measured.
these will not start if RP is below the cutoff start RP, ECM will not turn on the injector pulses, no pulses no diesel squirty.
common problem in these high mileage Dodge Cummins that have not had the loving care of a meticulous owner who ONLY feeds it absolutely clean and NO water fuel plus runs the best filtration and water separator.
best choice to take it:
1. several specialized disel pickup shops in SD that do R Cummins.
2. last resort Dodge dealer shop, have them ONLY measure the cold crank start RP and if they get it started, the cylinder contribution test.
DO NOT LET THE DEALER DO ANY REPAIRS ON THE ENGINE. READ THE HORROR STORIES ON HERE.
Post results here of tests.
You're at the mileage of worn out tit nipple leaker injector nozzles, hard starts and a quick engine killer
and of leaking injector return valves, hard starts and poor performance.
Crank sensor wiring is often damaged by a broken flying fan belt. can't easily be seen. same as smashing the new sensor, no worky.
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
post #6 of 6 (permalink) Old 01-25-2013, 07:18 PM Thread Starter
steelhead you were right. I took it to a dodge mechanic in san diego and the rail pressure is 700lbs suppose to be 4000. waiting for them to dig in deeper to the situation. will keep you all posted
