Dodge Cummins Diesel Forum
Dodge Cummins Diesel Forum (http://www.cumminsforum.com/forum/)
-   3rd Gen. Powertrain (http://www.cumminsforum.com/forum/3rd-gen-powertrain/)
-   -   2006 Ram 3500 Gear Indicator not working (http://www.cumminsforum.com/forum/3rd-gen-powertrain/560574-2006-ram-3500-gear-indicator-not-working.html)
corkyclem 12-29-2012 01:49 PM
The gear indicator stop working in my 2006 Dodge Cummins and of course will not start. I changed the neutral safety switch , didn't help. Anyone have any ideas? Would appreciate any help?
Podiesel 12-29-2012 04:46 PM
Please fill out your signature, (ie. - mods on the truck), under the "UserCP" tab so folks will know what mods you have. It will help in the diagnosis.
I know a Smarty programmer can cause the indicator to go blank with certain defuel options but I 'm sure you have something else going on since it won't start. Does it turn over?
Good luck.
cerberusiam 12-29-2012 06:30 PM
Can you get ANY lights on the dash when moving the gear selector? Frequently the shift cable will get out of adjustment and you will have to move the shifter to get it to start. Adjusting the cable will usually cure that unless you have a bad cluster or controller.
corkyclem 12-30-2012 10:17 AM
Thanks for the heads up on the signature line. No the truck will not turn over.
corkyclem 12-30-2012 10:19 AM
No I don't get any dash lights. I was thinking that the cluster/controller may be the problem, just hoping it wasn't. Thanks.
corkyclem 01-01-2013 02:26 PM
I do have some shift indicator lights, but will not go into park light indicator. I adjusted the shift cable, put in new neutral safety switch which gave me the indicator lights that I do have now. ECM fuse under hood, should both sides of that be hot. Thanks
cerberusiam 01-01-2013 05:05 PM
Are the rest of the gears showing correctly? Is the transmission going into park?
Gen-X 01-01-2013 05:07 PM
Is it in park and just not showing or not in park at all? You can start it in neutral also.
Fat fingered from a dumb phone
ecw 01-01-2013 05:19 PM
No park
HAD THE SAME CONFUSING PROBLEM....EVERYTHING WORKED BUT THE PARK INDICATOR... ORDER A NEW SHIFT ARM (TOP OF VB, & CONNECTS TO SHIFT CABLE) I PUT A NEW ONE IN AND EVERYTHING GOOD.:party018:
corkyclem 01-01-2013 06:51 PM
Yea when I move the shifter I can find the gears they are lit and the transmission is going into park just not showing on indicator.
cerberusiam 01-01-2013 06:58 PM
Put the transmission in drive and adjust the cable to read D. Make sure you can move between D and N and they light correctly. Adjust until this works. At that point all your gears should work and light correctly. If the don't likely problem is the rooster comb on top of the VB.
ecw 01-01-2013 09:15 PM
Old shift arm was hitting the neutral safty switch, put a new arm on and all is well,...
Powered by vBulletin® Copyright ©2000 - 2017, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
