Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-07 Common Rail Forums > 3rd Gen. Powertrain
CumminsForum.com is the premier Dodge Cummins forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 03-21-2008, 02:56 PM   #1 (permalink)
04.5 Cummins
rufushusky's Avatar
Error Codes For 2003+ 3rd Gen Trucks
Enjoy...
Here is the complete list of diagnostic trouble codes for the 2003 Cummins. Do not try and use them for gas engines, as they may not be the same.
P0016 Crankshaft/Camshaft Timing Misalignment/Out-of-Sync
P0071 Ambient Temperature Sensor Performance / Rationality
P0072 Ambient Temperature Sensor Low
P0073 Ambient Temperature Sensor High
P0088 Fuel Rail Pressure Too High
P0106 Manifold Absolute Pressure Sensor Performance / Rationality
P0107 Manifold Absolute Pressure Sensor Low
P0108 Manifold Absolute Pressure Sensor High
P0111 Intake Air / Charge Temperature Sensor Performance / Rationality
P0112 Intake Air / Charge Temperature Sensor Low
P0113 Intake Air / Charge Temperature Sensor High
P0116 Engine Coolant Temperature Sensor Performance / Rationality
P0117 Engine Coolant Temperature Sensor Low
P0118 Engine Coolant Temperature Sensor High
P0128 Cooling System Error / Thermostat Rationality
P0148 Fuel Delivery Error
P0169 Water-in-Fuel Detected For Too Long
P0192 Fuel Rail Pressure Sensor Low
P0193 Fuel Rail Pressure Sensor High
P0201 Fuel Injector 1 Circuit
P0202 Fuel Injector 2 Circuit
P0203 Fuel Injector 3 Circuit
P0204 Fuel Injector 4 Circuit
P0205 Fuel Injector 5 Circuit
P0206 Fuel Injector 6 Circuit
P0217 Coolant Temperature Too High
P0219 Engine Overspeed
P0234 Turbocharger Overboost Condition
P0236 Turbocharger Boost Pressure Sensor Performance / Rationality
P0237 Turbocharger Boost Pressure Sensor Low
P0238 Turbocharger Boost Pressure Sensor High
P0251 Injection Pump Fuel Valve Feedback
P0300 Multiple Cylinder Misfire
P0301 Cylinder 1 Misfire
P0302 Cylinder 2 Misfire
P0303 Cylinder 3 Misfire
P0304 Cylinder 4 Misfire
P0305 Cylinder 5 Misfire
P0306 Cylinder 6 Misfire
P0335 Crankshaft Position Sensor Circuit
P0336 Crankshaft Position Sensor Performance
P0337 Crankshaft Position Sensor Circuit Low
P0338 Crankshaft Position Sensor Circuit High
P0340 Camshaft Position Sensor Circuit
P0341 Camshaft Position Sensor Performance / Rationality
P0381 Wait-to-Start Lamp Inoperative
P0461 Fuel Level Sensor 1 Performance / Rationality
P0462 Fuel Level Sensor 1 Low
P0463 Fuel Level Sensor 1 High
P0477 Exhaust Pressure Control Relay Low
P0478 Exhaust Pressure Control Relay High
P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay)
P0483 Cooling Fan Speed
P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1
P0514 Battery Temperature Sensor Performance / Rationality
P0516 Battery Temperature Sensor Low
P0517 Battery Temperature Sensor High
P0521 Oil Pressure Sensor Performance / Rationality
P0524 Oil Pressure Too Low
P0532 A/C Pressure Sensor Low
P0533 A/C Pressure Sensor High
P0541 Intake Air Heater Relay 1 Low
P0542 Intake Air Heater Relay 1 High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0572 Brake Switch 1 Low
P0573 Brake Switch 1 High
P0580 Speed Control Multiplexed Switch 1 Low
P0581 Speed Control Multiplexed Switch 1 High
P0602 Control Module Programming Error/NotProgrammed
P0604 Internal Control Module RAM Integrity Failure
P0606 Internal ECM Processor
P0607 ECU Internal Performance
P0622 Generator Field Control Circuit
P0628 Fuel Pump Relay Circuit Low, or Fuel Lift Pump Control Circuit Low
P0629 Fuel Pump Relay Circuit High, or Fuel Lift Pump Control Circuit High
P0630 VIN Not Programmed in PCM
P0633 SKIM Key Not Programmed in PCM
P0642 Sensor Reference Voltage 1 Circuit Low
P0643 Sensor Reference Voltage 1 Circuit High
P0646 A/C Clutch Relay Circuit Low
P0647 A/C Clutch Relay Circuit High
P0652 Sensor Reference Voltage 2 Circuit Low
P0653 Sensor Reference Voltage 2 Circuit High
P0698 Sensor Reference Voltage 3 Circuit Low
P0699 Sensor Reference Voltage 3 Circuit High
P0700 Transmission Control System (MIL Request)
P0837 Four Wheel Drive (4WD) Switch Performance / Rationality
P0838 Four Wheel Drive (4WD) Switch Circuit Low
P0839 Four Wheel Drive (4WD) Switch Circuit High
P1652 J1850 Communication Bus
P2121 Pedal Position Sensor 1 Performance / Rationality
P2122 Pedal Position Sensor 1 Low
P2123 Pedal Position Sensor 1 High
P2127 Pedal Validation Switch 2 Low
P2128 Pedal Validation Switch 2 High
P2146 Fuel Injector Group 1 Supply Voltage Circuit
P2149 Fuel Injector Group 2 Supply Voltage Circuit
P2266 Water in Fuel Sensor Circuit Low
P2269 Water in Fuel Condition
P2502 Charging System Output Voltage
P2503 Charging System Output Low
P2504 Charging System Output High
P2509 ECM/PCM Power Input Signal Intermittent
P2607 Intake Air Heater Relay 2 Low
P2608 Intake Air Heater Relay 2 High
P2609 Intake Air Heater System Performance
04.5 Ram 2500 Reg Cab 4x4 5.9, 48re, AEM, Smarty, Banks High Ram,FASS HPFP, Boost/pyro/trans/FP/RP gauges, 5" Exhaust w/86531M muffler, Cat 2 micron fuel filter, Amsoil Bypass, Reese Hitch, Single Disc Converter w/ Strictly Diesel VB, PML Pan
1997 Fleetwood Prowler 26.5"
rufushusky is offline   Reply With Quote
The Following 22 Users Say Thank You to rufushusky For This Useful Post:
02cummin (08-21-2010), 05pscc (08-03-2009), AH64ID (05-26-2010), BBRam (05-12-2010), bjmollerson (07-14-2009), Clane (02-12-2010), CowboyUP90 (04-06-2010), cummin95 (05-11-2010), eott (02-09-2010), fromthehills (10-30-2009), hfhanson (06-15-2010), Hit.It. (04-05-2010), justglb (01-16-2010), NightForce213 (04-19-2010), oilfield trash (02-03-2010), parklane (07-13-2010), Pipewelder (12-08-2009), redneck2006 (12-26-2009), RobertMatthewFF1806 (06-20-2010), SEAN06 (08-10-2010), spideygill (11-18-2009), WATERLOO49 (11-29-2009)
Old 03-21-2008, 03:25 PM   #2 (permalink)
#1 Thread Derailer
BBRam's Avatar
iTrader Score: 8 reviews
Nice job Dennis. :thumbsup
03-3500, DRW, QC, 4X4, DTT, HTT, FTE, S&B, FLO PRO, Motorsport Diesel, FloorIt, ARP, Fluidampr, DDP, Dipricol, Smarty, Edge EZ, MagHytec, ATS, BD Power, Dynatrac, Timbo
95 1500 Sport 2wd Cummins Drag Truck under construction.
Special Thanks to Garys Chassis & Fabrication
Old 03-22-2008, 10:10 AM   #3 (permalink)
cojonu06's Avatar
great info to have, thanks.
'06 3500 srw, 48re, afe stage 2, 4x4, 4.5 lift pro-comp, 18" wheels/37"x-terrains, ez,smarty jr , exhuast , guages, cfm+,
cojonu06 is offline   Reply With Quote
Old 03-22-2008, 10:34 AM   #4 (permalink)
CTDFan5.9's Avatar
Thanks, I agree, great info to have. I copied it to my computer for future ref, since both of my CTD are 12V, but you never know.
CTDFan5.9 is offline   Reply With Quote
The Following User Says Thank You to CTDFan5.9 For This Useful Post:
djkajlk (10-08-2009)
Old 03-22-2008, 10:50 AM   #5 (permalink)
BOWZ's Avatar
thanks!
bowz
2005 RAM 3500 QUAD CAB DRW LB, 4.10, 6SP, EDGE JUICE W/ATTITUDE,SMOKE SWITCH, BULLY DOG INTAKE, BAFFELS AND SILENCER MIA, 7IN MITER STACKS, 6IN LIFT, REAR WHEEL SPACERS, 22.5 W/ GOODYEAR G622'S, FASS FUEL PUMP,CLUTCH. THANKS GUS FBD
BOWZ is offline   Reply With Quote
Old 03-30-2008, 03:46 PM   #6 (permalink)
oldsmobiledave's Avatar
Error Codes
Awesome Info...thanks Much.
I created a word document & saved this to it. Will print off & keep in the truck.
2004.5 QC 2500 4x4 auto VA C3.2, tripple gauges, Carli Starter Kit, Devino 772s 18 x 9s, Dunlop Maxx Tractions 275 70 18s. 2005 Reg Cab 1 Ton Dually 4x4 auto Smarty S06, valve body. quad gauges, shut down timer, Firestone Transforce tires & Air Bags.
oldsmobiledave is offline   Reply With Quote
Old 03-31-2008, 10:40 AM   #7 (permalink)
My MIL came on last nite. I checked or codes this AM and found the P 0108. What to do with this without going to the dealer. TIA.
Jim
03 quad cab dually, J&J stainless boards, extang full tilt toneau, bhaf, glacier 392
"some days you get the bear, some days the bear gets you"
dezeldog is offline   Reply With Quote
Old 04-07-2008, 05:29 AM   #8 (permalink)
mybadford's Avatar
Great info. I get the 2146 code once in a while. Anybody know the cause of this?
2005 quad cab LB 6spd Edge/Smarty/5" Magnaflow/Fass150/150/Spearco intercooler/II phat shaft 62/ATS intake and exhaust manifold/SB DD http://www.youtube.com/watch?v=TEyU-...eature=channel http://www.youtube.com/watch?v=jVQ18_0HPg4
mybadford is offline   Reply With Quote
Old 04-13-2008, 07:01 PM   #9 (permalink)
dodge 3500's Avatar
Can we reset the check engine light by turning the ignition key on and off six times like the 2nd gen trucks? Just wondering
5.9L 2003 Dodge 3500 QC SB SRW S&B COLD AIR INTAKE 4"STRAIGHT PIPE PXRB PAC BRAKE AND RIDE RIGHT FIRESTONE AIR BAGS SILENCER RING MIA
dodge 3500 is offline   Reply With Quote
Old 05-22-2008, 06:34 AM   #10 (permalink)
SUPER MODERATOR
Devon E's Avatar
Whats a skim key my truck has that code no clue what it is thanks
Devon E is offline   Reply With Quote
Old 10-24-2008, 10:27 PM   #11 (permalink)
2008 mineral gray brand new only 2000+ miles, had check engine light come on with no codes showing when i did the 3 key thing. is there any way to turn off the light without going to the dealer besides disconnecting the battery? and is there a reason there is no code?
mineralgray2008cummins is offline   Reply With Quote
Old 12-24-2008, 10:08 AM   #12 (permalink)
stock dodge's Avatar
Thanks very useful !!!!!
stock dodge is offline   Reply With Quote
Powered by vBulletin® Version 3.8.5
