| 3rd Gen. Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
#25 (permalink) |
![]() Join Date: Dec 2008
what kind of programmer do I need to clear my codes?
05 3500 4x4 Dually 6sp, Jacobs Exhaust brake, firestone airbags, B&W turnover ball,2nd gen intake horn(thanks craig UT) stock air box modified, 5" TBE http://s698.photobucket.com/albums/vv349/NW05cummins/ |
#26 (permalink) |
GA CUMMINS CREW PREZ
![]() Join Date: Dec 2007
any kind will work that clears obd codes
CLICK---> GEORGIA CUMMINS CREW "There are no stupid questions, just stupid people." |
#27 (permalink) |
I'm new to all this stuff, what brand, type is a good one?
#29 (permalink) |
TECH SPECIALIST
![]() Join Date: Jan 2008
P0069-BOOST KEY ON RATIONALITY When Monitored: While the key is on. Set Condition: The boost pressure recorded at key on is not within a calibrated range from the inlet air pressure sensor. Did it do this before you loaded the bullydog?
John - 03 QC/LB 4x4 5sp Visit the Hoosier Truck Club FTE Diesel FASS giveaway Click here!!!
#31 (permalink) |
i got this how do i fix it p0251 p0336 p193 p2269 p0341
2005 dodge laramie, 16000 original miles, 7 inch lift, 4 inch body lift,20 inch rims,40 inch tires, edge chip, bully dog exhaust and injectors,bed cover its a good work truck |
#32 (permalink) |
TECH SPECIALIST
I would suggest opening a new thread with your problems in the 3rd gen forums for better exposure, but it sounds like either the ECM or the 5V wire is shorted to the FCA somewhere.
#33 (permalink) |
My friends 06 threw P1740. TCC O/D Sol Performance Anybody know what causes this? Theory of operation is : The Torque Converter Clutch (TCC) selenoid is used to engage the tcc which improves fuel economy. That is what my other friends scan said. Also threw P2509 - powerdown data lost Any help would be appreciated.
2007 5.9 ctd, edge,afe,silverline,37s 1998 12v, single/fuel 652hp 1191 12.11@109mph/old set up 1994 12v- Project Red. Regular cab |
#34 (permalink) |
TECH SPECIALIST
P2509 is that the ECM lost voltage for a length of time. Could be a bad ground. P1740 is basically that it didn't see a RPM drop when it thought it should have shifted into OD or locked the torque converter. Does he have a torque converter lockup switch installed?
#35 (permalink) |
Truck is bone stock. They got it with 300k miles on it just for there farm. Thanks for your reply JWH
#36 (permalink) |
Error Code P0868
Im getting code P0868. My PDA sais it is governor pressure sensor volts too high. when the light came on I noticed it didnt have much low end torque. I didnt see that code on the list and was wondering if this is a common code and how do I fix it without going to the dealership! thanks in advance for the responses.
