Old 01-04-2009, 03:41 PM   #13 (permalink)
billw's Avatar
Originally Posted by mineralgray2008cummins View Post
2008 mineral gray brand new only 2000+ miles, had check engine light come on with no codes showing when i did the 3 key thing. is there any way to turn off the light without going to the dealer besides disconnecting the battery? and is there a reason there is no code?
If you don't have an OBD 2 reader then no. If the truck is new I would bring it in and ask WTF?
Loud pipes save lives!!
2005 Ram 3500 Laramie 6spd man. *stock* for now
2004 F-150 FX4 *lot's of goodies*
billw is offline   Reply With Quote
Old 01-04-2009, 03:44 PM   #14 (permalink)
billw's Avatar
Originally Posted by Devon E View Post
Whats a skim key my truck has that code no clue what it is thanks
Your skim key is the programmed key for you anti theft. no idea why a code would show, unless it is ignition related maybe.
Old 01-05-2009, 06:48 PM   #15 (permalink)
choupique108's Avatar
im getting a P0700 code. anyone know what will fix it
2003 7.3L Crew Cab Short Bed FX4 Lariat-Dipricol Gauges-Train Horns-08 Console-5" Flo Pro exhaust w/ 6" SS tip-Ranch Hands Front and Back-Tint-Whole lot more to come.
choupique108 is offline   Reply With Quote
Old 01-07-2009, 12:14 AM   #16 (permalink)
BO's_06_Cummins's Avatar
these are for all 3rd gen 5.9's right? 03-07?
BO's_06_Cummins is online now   Reply With Quote
Old 01-07-2009, 12:17 AM   #17 (permalink)
Super Moderator
rufushusky's Avatar
To the best of my knowledge yes.
Dennis
04.5 Ram 2500 Reg Cab 4x4 5.9, 48re, AEM, Smarty, Banks High Ram,FASS HPFP, Boost/pyro/trans/FP/RP gauges, 5" Exhaust, Cat 2 micron fuel filter, Amsoil Bypass, Reese Hitch, Single Disc Converter w/ Strictly Diesel VB
1997 Fleetwood Prowler 26.5"
Check out: Rig of the Month!
http://www.cumminsforum.com/forum/rig-month/
rufushusky is offline   Reply With Quote
Old 01-12-2009, 04:18 PM   #18 (permalink)
mauls's Avatar
Is that the complete list of codes? because I didn't see my codes on there. P1754 & P1751
2005 Dodge Cummins quad cab 4x4 : de-ringed, Afe stage 2, straight pipe, recon smoke cab lights, 2" leveling kit, 18" prova black wheels, 35x12.50x18" BFG M/T T/A
mauls is offline   Reply With Quote
Old 01-12-2009, 04:41 PM   #19 (permalink)
TECH SPECIALIST
JWH_03_Dodge's Avatar
That's not complete. P1751 and P1754 are both transmission codes -
P1751-TRANSMISSION THROTTLE VALVE POSITION MINIMUM RANGE PERFORMANCE
P1754-TRANSMISSION THROTTLE VALVE ACTUATOR STUCK
John - 03 QC/LB 4x4 5sp
Visit the Hoosier Truck Club
FTE Diesel FASS giveaway Click here!!!
Originally Posted by Broke Down View Post
come on Steve....my nuts hurt and i am stuck on the couch
JWH_03_Dodge is offline   Reply With Quote
Old 01-12-2009, 04:43 PM   #20 (permalink)
TECH SPECIALIST
P0700 is just a companion code telling you that there is a code set in the transmission control module, and tells it to set the check engine light.
If you guys start up a tread with your problem in the 3rd gen powertrain forum or the 911 help forum, you'll get quicker response and more exposure.
Old 01-15-2009, 01:09 AM   #21 (permalink)
kenny110482's Avatar
Great info!! Thanks
Black 2003 Dodge 2500 QCSB, 4X4, 5 speed, 6" Aussies, Smarty, KC Customs intake manifold, 90HP Dragon Flow Injectors, AirDog 150 , Quad Boost Fooler, DiPricol FP Guage, Isspro Performax: Rail Pressure, Pyro, Boost, Few other interior goodies
kenny110482 is offline   Reply With Quote
Old 01-21-2009, 02:59 PM   #22 (permalink)
cummins35's Avatar
this is one of God's gifts to earth...thanks man
06 2500, 6 spd, 4x4, Smarty REVOlution , Quadzilla Boostfooler, Banks High Ram, K&N Intake...just bought it so its still in the making!
cummins35 is offline   Reply With Quote
Old 01-28-2009, 11:18 PM   #23 (permalink)
NW05cummins's Avatar
Thanks for the list!!
Can I clear my codes with out going to the dealer?
will unhook the battery clear codes?
05 3500 4x4 Dually 6sp, Jacobs Exhaust brake, firestone airbags, B&W turnover ball,2nd gen intake horn(thanks craig UT) stock air box modified, 5" TBE
http://s698.photobucket.com/albums/vv349/NW05cummins/
NW05cummins is offline   Reply With Quote
Old 01-28-2009, 11:20 PM   #24 (permalink)
GA CUMMINS CREW PREZ
SOUTHERN SMOKE's Avatar
no, they battery trick doesnt work on our trucks, you have to have a scan tool, or someone to plug in their programmer and clear them for ya...
CLICK---> GEORGIA CUMMINS CREW
"There are no stupid questions, just stupid people."
Originally Posted by milldog View Post
Unless she makes the move first then show her the sambo stick!!!
SOUTHERN SMOKE is offline   Reply With Quote
