Excessive blow by, what's best oil additive - Page 2 - Dodge Cummins Diesel Forum
post #13 of 27 (permalink) Old 10-08-2012, 07:19 PM
Lyle C's Avatar
I decided today to crawl underneath the truck and have a look. I can notice a very slight haze coming out of the blowby tube, is that normal as well??
05' Ram 5.9 Cummins. Afe stage2, Mbrp 4" tbe. Stock
Built tranny by Rick Rood!
. Silencer Ring in sounds better
Dream Truck- '94-'97 Ram Cummins ECLB with nv4500
Lyle C is offline
post #14 of 27 (permalink) Old 10-08-2012, 09:07 PM
smokindully99's Avatar
Sure is buddy
Sent from my iPhone on my way to anywhere but here
99 3500,309K on 53 block. Yeah, its got some STUFF!
97 chevy 1500 parts runner
smokindully99 is offline
post #15 of 27 (permalink) Old 10-09-2012, 04:49 AM
Lyle C's Avatar
Thanks man! You just helped me decide to keep my truck and not sell it, lol!
Lyle C is offline
The Following User Says Thank You to Lyle C For This Useful Post:
smokindully99 (10-10-2012)
post #16 of 27 (permalink) Old 10-09-2012, 07:25 AM
GNR
Thanks buddy for the response, it helps a lot!!
My nerves aren't bad, lol, but like you say, I would sell the truck if I knew it was bad.
Just rolled 177 000 on the clock and I'm pretty sure it has original injectors. I don't run her hard but I know new injectors are a good idea.
thanks again, Lyle
Is that 177k kms or miles?
GNR is offline
post #17 of 27 (permalink) Old 10-09-2012, 07:48 PM
Lyle C's Avatar
^^^ miles. It's an American truck. 287 000 kms if my math is correct..
Lyle C is offline
post #18 of 27 (permalink) Old 11-20-2012, 06:48 PM
Genodiesel is offline
The Following User Says Thank You to Genodiesel For This Useful Post:
Redthies (01-17-2013)
post #19 of 27 (permalink) Old 11-20-2012, 07:02 PM
Lyle C's Avatar
UUUmmmmmm, yea that no looka goood!! Good luck with that....
Just like smokindually said, I had a clogged crankcase vent (oil was leaking out underneath it) I changed that out and after a coupe days I noticed my blowby has really decreased, almost none at all. Gotta like it!
Lyle C is offline
smokindully99 (11-20-2012)
post #20 of 27 (permalink) Old 11-20-2012, 07:12 PM
C Schomer's Avatar
I new old truckers that did Bonami overhauls. Start it up and put about 1t. of Bonami down the intake. Sometimes it would reseat the rings for a while. Craig
03, QC, dually, HO, 6spd, 4.10, custom hauler bed, 4" turbo back, TST PMCR, PS 62/65/14, 2pc. exh manifold, Walbro 391, 2, PRXB, Rancho 9000s, FS airbags, Onboard air. 08 Sunnybrook 30 RKFS
C Schomer is offline
post #21 of 27 (permalink) Old 11-20-2012, 08:13 PM
You could pull all the injectors and put a lil oil in each cylinder and it could possibly reseat the to hs but at 214 I don't think it'll work... You might wind up doin a complete on that one, I'm sure ull prolly find a scared cylinder wall when u tear into it and if not then that'll be great
post #22 of 27 (permalink) Old 01-10-2013, 02:45 AM
Whats the best way to look into the cylinder? scope or should I just do a compression test. If its not a scored wall or messed up ring what could it be?
Im still paying on the truck I already put a tranny in it its gonna suck if i have to spend 5k for a short block but nothing i can do about it but i will basically have a brand new truck lol
03 cummins 3 inch skyjacker lift, straight pipe, stock
post #23 of 27 (permalink) Old 01-10-2013, 11:45 AM
You can use a borescope for a quick way to ck the cylinder walls and u should be able to see the crosshatch marks on the walls as well if ur cylinders are still ok
post #24 of 27 (permalink) Old 01-11-2013, 08:39 AM
D-Roc's Avatar
For the ten bucks it costs you can give Schaeffer's EP 132 a try...two bottles
1998 QCSB 5 sp, 3.55, EGT, boost, SB intake, 4 exhaust, KDP, AFC mods, 8 plate, FASS T D10 125G , TT OFV50, SBC OFE
D-Roc is offline
