Excessive oil loss 5.9 - Page 3 - Dodge Cummins Diesel Forum
post #25 of 35 (permalink) Old 10-01-2012, 02:04 AM
StealthDiesel's Avatar
MontanaDave, slowdown!!
1 logical step at a time. Don't jump around, dont' buy anything until you know what the problem is.
1. Please fill out your signature as asked earlier so we know your truck details.
2. Did you go for a long drive as mentioned to see how that affected your oil level?
3. It's hard to tell in that picture but that black ring is a metal snap or spiral ring that is designed to hold the turbo air guide in place. The gap is totally normal. Going from that picture your turbo looks fine.
Did you check the turbo shaft end play?
This is from the BD Diesel website:
http://www.dieselperformance.com/pro...Inspection.pdf
The specs are from the BD Special turbo but the procedure is the same.
Just going by experience...
Zero to very little end play.
Very little up & down play. The compressor wheel should not touch the housing, nor should there be any rub marks on the housing...
Oil is flowing thru the turbo shaft center section at all times. The turbo shaft rides on bearings & there are end seals to seal the shaft.
You can see a braided stainless steel line from the top of the oil filter head to the top of the center section of the turbo.
From under the turbo you will see an oil drain tube going back to the engine.
4. Did you remove the exhaust from the turbo? What were your findings there?
What part of Montana are you in? My wife and I love Montana. Friendly folks, nice country, great stock car tracks, excellent ski hills.
I'm just 3 hours north of the Montana border..
2004.5 Dodge SB QC 2500 2wd Cummins 600/6spd manual/3.73 LSD
ATS 3K/5K Twin turbos. DDP 50HP tips, F1 valve springs, ARP headstuds.
SBC Dual disk 3250. Smarty. Glacier Diesel intake plate, air horn, fuel & filter system.
MBRP S.S. muffler. BD short shifter. Brakesmart tow controller.
BD exhaust brake. Pullrite 24k Superglide.
StealthDiesel is offline
post #26 of 35 (permalink) Old 10-01-2012, 02:21 AM Thread Starter
Montanadave's Avatar
I tried to go and fill out all my specs. I will have to get back on the computer tomorrow. Im going to pull exhaust tomorrow to investigate where it comes out.
My truck is a 2005 Dodge ram 2500 5.9l, 4x4, quad cab, stock everything so far. It has a small lift with 35" tires.
I moved from Missoula out to Washington and ever since I've been called Montana. I absolutely love Montana!
I didn't drive the truck today. I opted to take our 4 runner instead. I just have really been scratching my head. So you don't think it looks damaged?
Montanadave is offline
post #27 of 35 (permalink) Old 10-01-2012, 02:26 AM
Kmonares's Avatar
Originally Posted by Montanadave View Post
See if this uploads the pic
That the silencer ring retaining clip..... It's supposed to have that gap there. If the leak is in the turbo it's probably on the exhaust side based on that picture.
'14 QCLB DRW, Aisin, 4x4
'08 Megacab 4x4 auto
'04.5 QCSB- sold! 2011 Duramax POS- sold!
Kmonares is offline
post #28 of 35 (permalink) Old 10-01-2012, 02:30 AM
Kmonares's Avatar
Somebody wrote I may be able to find one for $300 bucks used. Who and where would I go through to find one and would it be worth while to buy a used turbo?
The for sale section on this website has them all the time, check it out
Kmonares is offline
post #29 of 35 (permalink) Old 10-01-2012, 03:58 AM
So if my turbo has been damaged what would cause the truck to loose oil. I don't fully understand where the oil would go or why because of a damaged turbo. I haven't ever had to work on a diesel engine before so I am some what of a newbie. So be easy. Lol
If anyone has any input on the photo I posted a couple posted up and where the oil has gone I am all ears.
Thanks
If a turbo bearing is bad, oil can go into the intake or exhaust, or both. Since you're not burning it, likely going directly into the exhaust side and down the exhaust system.
2006 3500SLT 4x4 Dually 5.9 Diesel w/ 25' Gooseneck Tandem Dually Equipment Trailer
55_Cans is offline
post #30 of 35 (permalink) Old 10-01-2012, 04:11 AM
jb15's Avatar
turbo looks fine to me. side to side play is ok and normal is its just a little bit, in and out play is bad.
turbo looks finethough
2006 long box 4x4 big horn
jb15 is offline
post #31 of 35 (permalink) Old 10-01-2012, 08:41 AM
I'am not sure if this fits your truck, but a turbo is for sale here:
(http://www.cumminsforum.com/forum/98...hx35-sale.html )
2004.0 Dodge Ram 2500,Stock 5.9L Diesel H.O. 305HP/555lb.ft ,6-speed NV5600,South Bend Dual Disk clutch,2WD,2" front level, Frantz oil bypass,Cat 1R-0479 fuel filter,Baldwin BF1212 filter,Smarty S06,revo tune,Issopro FP,ETG,Boost gauges,boost elbow set to 32PSI
Jbremount is offline
post #32 of 35 (permalink) Old 10-01-2012, 10:41 PM Thread Starter
I have the truck at proper oil level. I ran it today hard. Let it idle running down hill and I gave it a bunch of fuel and all I got was very little black smoke. I stepped on it and really got on it. All I seen was black smoke. No sign of any white or blue smoke. Turbo worked just like it should. I have talked to multiple shops and they all say to drive it and keep an eye on it. To monitor how much oil it consumes between fill ups and every 500 miles or so. I took a drop of oil and driped it onto a piece of white paper, I'm going to leave it over night. They said that by tomorrow if it looks like the sun coming from around the drip that I would have fuel in my oil. Two different things I've been told. The O rings around the injectors could have gone out (not common but could happen I was told) also the fuel pump??????? So I guess for now I am going to keep my eye on it and see what happens. I don't feel that it is something catastrophic like I orinally had thought. Thoughts?
Also on a side note I called the dealership from where the guy bought the truck at Lithia in Kennewick WA. They had no record of any engine oil issues. Just going back in for safety recalls.
The Following User Says Thank You to Montanadave For This Useful Post:
jmayo35 (10-01-2012)
post #33 of 35 (permalink) Old 10-02-2012, 12:49 PM
Well I am not sure about the 05 models but I can tell you for a fact in the early 07 if the truck is not perfectly level it will throw your measurement off. I basically have to park at the same place everytime and let my truck cool about 30 min to get a accurate reading. So my advice is find a nice level spot before you add more oil over filling is every bit as bad if not worse then under filling.
2007 5.9L 2500 Mega 6-speed: So far GDP big line MK-II kit, gauges, raptor 150, south bend 3250 new dual material, efi live by Les, intake, exhaust, arp studs
2002 Volkswagen Jetta TDI: PP520 Nozzles
tran_65 is offline
post #34 of 35 (permalink) Old 10-02-2012, 05:21 PM
kummin's Avatar
its just as important to wipe stick, put back in then check oil level...
i've seen many many vehicles under filled due to driver pullin dipstick out look and see oil up to crosshatchs and think its full, when in fact it was low about 4-8 quarts.
gotta wipe 'er first, they re-stick 'er to check properly...
05 2500HD SLT (big horn) 5.9 48re 4x4 qclb
"mispellin' iz delibarate"
kummin is offline
post #35 of 35 (permalink) Old 10-02-2012, 06:36 PM
DBLR's Avatar
Maybe it does not like the oil your using. After reading the below about the oil you used I sure as heck would not put it my engine, I will not use any oil that is made with Group II base stock in any engine I own.
"Guardol ECT is formulated with a blend of synthetic and high-quality Group II base stocks and a proprietary low-SAPS additive package"
Oil Groups:
Group I base oils can have a mix of different hydrocarbon chains, with relatively little uniformity; these oils are the least refined. They are usually not used for autos.
Group II are the most common base oils in “dino juice,” with good performance in most areas except cold temperature viscosity.
Group III are called synthetic, and have high molecular uniformity and stability. Group III oil bases are used in most synthetic oils.
Group IV are chemically engineered stocks, arguably with the highest performance and longevity.
2006 Ram 2500 Big Horn Edition Auto 5.9L Mineral Gray Met. Quad Cab SB 4X4 SRW 3.73's:
DBLR is offline
