Does this look like a water pump leak? - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 09-11-2012, 09:28 PM Thread Starter
I opened the hood and noticed the coolant overflow bottle was low and the truck had never lost any coolant in the past. Upon further inspection, I noticed that there was coolant fluid on the ground. Below are the pictures of the area.
Do you think these are the signs of needing a new water pump? If so, what is a good quality water pump? Are there certain brands of water pumps to stay away from?
picture from top looking down at the water pump and leak.
looking at the leaking area from below.
2004.0 Dodge Ram 2500,Stock 5.9L Diesel H.O. 305HP/555lb.ft ,6-speed NV5600,South Bend Dual Disk clutch,2WD,2" front level, Frantz oil bypass,Cat 1R-0479 fuel filter,Baldwin BF1212 filter,Smarty S06,revo tune,Issopro FP,ETG,Boost gauges,boost elbow set to 32PSI
Jbremount is offline
post #2 of 19 (permalink) Old 09-11-2012, 09:34 PM
nickg9785's Avatar
id say your best bet is to find someone with a pressure tester. it looks like theres a trail or somethhing above the water pump but its hard to tell
1997 cclb. some fuel, some air, some this and that
nickg9785 is offline
post #3 of 19 (permalink) Old 09-11-2012, 09:35 PM
c farmer's Avatar
Looks like it. I would buy the cummins one. Alot of people also use a Napa one.
Sent from my DROID3 using Tapatalk 2
02 3500 HO 6 spd dually straight exhaust - 7x.010 injectors-edge ez-Dr. P box- exhaust brake - silencer ring gone - autometer boost-egt-fuel - napa 6637 bhaf-valair dual disc - timbo's apps(soon he351vgt 4 inch exhaust)
Looking for a timing box or a small timing/fuel box. Pm me
c farmer is offline
post #4 of 19 (permalink) Old 09-11-2012, 09:37 PM
99CumminsRon's Avatar
Oh ya change that water pump. They are real easy by the way. I bought one from autozone and it stayed in my 2005 for 3 years before i sold the truck. Good luck
1999 cummins, superchips, K&n Intake
99CumminsRon is offline
post #5 of 19 (permalink) Old 09-11-2012, 09:42 PM
looks like a pump. i second 99cumminsron,they are simple to change.i got mine at napa with a lifetime warranty and its been in there couple years now with no problems.see if you can get a mirror in there and look at the bottom of the pump.there should be a weeping hole that will show a trail of coolant coming out if the seal is gone. in the one pic it kind of looks like the top had coolant on it at one time but hard to tell
HOLD IT TO THE FLOOR UNTIL IT SOUNDS EXPENSIVE
bmucci is offline
post #6 of 19 (permalink) Old 09-11-2012, 09:51 PM
macko300exc's Avatar
It looks like the gasket between the block and pump is leaking. For the price and since you would have to remove the pump just replace the pump. Change hoses and t-stat if they are old and change fluid while your thwre
Sent from my C771 using Tapatalk 2
macko300exc is offline
post #7 of 19 (permalink) Old 09-11-2012, 09:57 PM
Twistedcummins's Avatar
Just got to napa, they're like 50 some bucks and take less than 30 minutes to install, the hardest part is cleaning up the coolant mess you will make
99 QCSB 4x4 auto/Edge/Airdog/Isspro
Originally Posted by USARMY12V View Post
With a 47RE it's impossible to tell. It's easier diagnosing what's wrong with a woman.
Twistedcummins is offline
post #8 of 19 (permalink) Old 09-11-2012, 10:15 PM
Double post...
post #9 of 19 (permalink) Old 09-11-2012, 10:48 PM Thread Starter
Stuck a mirror under the pump and attempted to get a good picture of the weep hole. The truck has been off for about a hour but the weep hole is wet. I think the weep hole is leaking, but I agree that it looks like the whole seal is leaking. I wonder if this pump is the original and has never been changed out. The pump sure looks like an old one!
The Following User Says Thank You to Jbremount For This Useful Post:
OilEngine (01-17-2015)
post #10 of 19 (permalink) Old 09-11-2012, 10:50 PM
i think macko is right too.looks like the whole seal is leaking. my opinion is new pump and seal should fix it.
bmucci is offline
post #11 of 19 (permalink) Old 09-11-2012, 11:00 PM
Make sure your pump is NOT made in India! I've replaced a couple 'Cummins' water pumps recently on industrial engines they were all made in India, one lasted 2 weeks before it started leaking again, and one is starting to loose the bearing 2 months later. The other's have never had a problem.\
Oh, and it's literally a 5 minute job. Cleaning up the coolant takes longer than the actual repair!
06' Megacab 3500, leveled on 285/70/17's, built 48RE Goerend triple disk billet input blah blah bkah... , Edge JA
needabronco is offline
post #12 of 19 (permalink) Old 09-11-2012, 11:08 PM Thread Starter
I called around to the Auto parts stores,O'riley's, Advance Auto, and Auto Zone, and most had a house brand made in who knows where for about $50. Auto zone's pump was made in Spain, the others claimed to not know where their water pumps were made! I could not find a name brand water pump anywhere. I'll call Napa and Cummins in the morning. Rock Auto has a Gates and a Bosh water pump that look pretty good. From my past experiences, Rock Auto usually has the best prices on the better quality auto parts. Anyone know if the Gates or Bosh water pumps are good/bad? I rather pay once for a quality water pump that will last.
