popping sound in the front end - Dodge Cummins Diesel Forum
 1Likes
post #1 of 76 (permalink) Old 08-09-2012, 04:57 PM Thread Starter
Mega Cab Fanatic
Themoparman68's Avatar
I got a popping in the front end when I press the brake in sometimes. I have replace Ball Joint, wheel bearing, everything in the front end. I can't find out what is causing it. Need some help. Oh the control arms are good had them checked today.
2007 3500 Laramie 4x4 mega cab airlift on rear, Smarty , Ram Air Hood Fully Functional, Pacer Cab Lights, cat & muffler deleted
Themoparman68 is offline
post #2 of 76 (permalink) Old 08-09-2012, 05:23 PM
600crpower's Avatar
Sway bar end links or steering shaft.
2010 CCLB F350 King Ranch - Sinister EGR Delete, Coolant filter - No Limit Intake - CCV Mod - Mini Max HD300 - 4" flo pro duals
1/4 mile 13.1 @100 spinning in 4x4
600crpower is offline
post #3 of 76 (permalink) Old 08-09-2012, 05:28 PM Thread Starter
Mega Cab Fanatic
sway bar ends are new just got them today steering shaft is new. I did a search on here and I think that it maybe the brakes caliper. It started after I put in the new ball joints and they are Carli Ball Joints. I have replace everything on the front and the popping is on the driver side only.
post #4 of 76 (permalink) Old 08-09-2012, 05:30 PM Thread Starter
Mega Cab Fanatic
Going to take it all a part tomorrow and see what i come up with.
post #5 of 76 (permalink) Old 08-10-2012, 01:30 AM
cumminsdieselfreak's Avatar
What about the caliper?
2013 Dodge 2500 6 Speed, S&B Cold Air, 2.5" Leveling Kit, 35x12.50x20s
2007.5 Dodge 2500 G56 Dual Disc Clutch, GDP Intake Manifold, CCV Delete, GDP Throttle Valve, EGR Delete, AirDog Fuel System, Banks Intercooler, Banks Ram Air, H&S Mini Maxx(soon to be EFI Live), Fuel Press. Boost & Pyro Pillar Gauges
2000, 2002, 2006, 2007(5.9) Dodge 2500 - SOLD
cumminsdieselfreak is offline
post #6 of 76 (permalink) Old 08-10-2012, 01:41 AM
Drillbit's Avatar
Ok here is a thought i had a popping sound in mine when i stopped really hard or floored it and it sounded to me like it was coming from the front end of the truck i finally had my wife sit in the truck while i watched the underside having her go in reverse and slambon the brakes then forward.... turned out it was my carrier bearing on my driveshaft going bad and flexing.... might not be your problem but its worth looking into.... also does it do it if you crank the wheel and push the gas pedal in?
2003, 2500, 4x4, auto,3.73, 6in lift 35 in tires, Banks 6-gun
Drillbit is offline
post #7 of 76 (permalink) Old 08-10-2012, 08:21 AM
Please update us on what you find. I too have a popping sound in my front end since changing out everything. The only time I notice it is when backing up and then pressing the brake firmly so that the suspension actually moves. The next time you go forward and brake, you can hear it pop again and then it doesnt do it again until I back up again. I have dynatrac ball joints, carli leveling kit with carli control arms, and 08.5+ steering. I really believe the noise is coming from the control arms even though I have tightened them incredibly tight. The popping is too loud and you can feel it in the floor so much that I dont believe it is brake related. I also have a Carli track bar, but I dont see how the track bar could make the popping noise but I guess anything is possible.
Glidehm is online now
post #8 of 76 (permalink) Old 08-10-2012, 08:58 AM Thread Starter
Mega Cab Fanatic
That is how my dose.
post #9 of 76 (permalink) Old 08-10-2012, 10:58 AM
Drillbit's Avatar
Do you guys have a two piece driveshaft?
Drillbit is offline
post #10 of 76 (permalink) Old 08-10-2012, 11:04 AM
No. I have a one piece. Guess I should have added that along with my info. 2005 QCLB 4x4. Popping noise didn't start till the front end was redone, and I have also taken the upper control arm bolts out at the frame, and they are not egg shaped from being loose. I have read this could possibly be a problem causing the noise, but not in my case!
post #11 of 76 (permalink) Old 08-10-2012, 11:08 AM
Midnight Smoker's Avatar
Check the upper bolt on your track bar, sometimes the bolt will move around in the hole causing a very loud pop...
MIKE 06' Laramie Mega, 57 Chevy 3100
Midnight Smoker is offline
post #12 of 76 (permalink) Old 08-10-2012, 11:10 AM
Drillbit's Avatar
Well then what i was talking about wouldnt apply to you glidehem. Does it do it when your wheels are turned or just if they are straight or both?
Drillbit is offline
