| 3rd Gen. Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
Airdog install
OK, So i have a few gallons left in my tank, and I want to drop it to put in the liberty module. Can I use the in tank pump to drain the fuel tank? In other words, attach a longer hose on the filter canister on the motor, open up the valve, bump over the motor, then let it drain through the filter housing into a gas can??? I don't see why this wouldn't work. heck, I forgot to close the valve once and started the truck up and got diesel all over the driveway! ![]() I just want to make the tank as light as possible so it's easier to drop.
06 Silver Quad Cab 4x4 Automatic -4" Rancho Lift w/Superlift Traction Bars & Defiant Steering Support, 315 MTZ's on H2's -Smarty, AFE Intake, Muffler Delete, Airdog100/Liberty Setup, ISSPRO Gauges, Amsoil BMK-11 |
#2 (permalink) |
Also.... Anyone with a 06+ quad cab short bed can install an Airdog using the stock bracket? For the life of me, I can't get it to fit. It seems that the body mount and the transfer case are too close together to fit the bracket in correctly.... May have to cut and modify the bracket????
#3 (permalink) |
You could take the bed off pretty easy and leave the tank alone. As far as the bracket goes, no, it won't fit on the newer 04.5 and up short bed trucks... I ran into that problem myself. You'll have to hack it up and put something together that will. I got tired of messing with it in 30 degree weather crawling under the truck and said to hell with it - can wait til warmer weather... Modify the bracket with the bed still on there so you can be sure everything clears....
Chris 2007 Ram 2500, SLT Big Horn, Mineral Grey, 4WD, 5.9, BMK11 bypass, G56, 285/70/17, GV overdrive, D'Trac manual hubs, Smarty Jr, 6" Wwhistler, 4" turboback, LED's 2008 model 387 Pete, ISX, 10sp, 3:58 rears Last edited by Dsljnki07ctd5.9 : 03-07-2008 at 07:49 PM. Reason: modifying the bracket |
#4 (permalink) |
Yeah I got a reply from John (Jbarker) and he said that you have to hack off the miscellaneous bracket at the top of the frame and move it closer to the fuel tank. Problem is that my traction bar bracket is in the way. I think what I am going to have to do is hack up the bracket, like you said, and make something work.... I have no welding equipment, so I am going to have to have it done by a shop, when I figure out what the heck to do!
#5 (permalink) |
Colorado Chapter Pres
That bracket welded to the truck is a pain and does nothing but get in the way. you can cut it off as I have done a few times to get it to fit. I have seen that bracket on long beds as well as short beds. and from 2001 and up. again not every truck has it. from what i can find out it used for the assembly line as the frame moves down the line. Pulling the Bed is the easiest way to do the entire job especially if you have to install the draw straw. We have pulled a bed off in about 20 minutes compared to fighting a 4 ft long tank with fuel in it. six bolts and your done. the first one i did was a 100 that uses the OEM tank feed and i fought trying to get that oem clip off of the tank while it was in place for over 1 1/2 hours. i could have pulled the bed and finished the entire deal in that time John:thumbsup
99, QC short bed running the best of the best and proven to perform. A daily driver that gets 19+MPG and runs a 12.86 @ 104 mph 1/4Holland Court Diesel Your one stop Diesel SUPER SHOP 303-986-0330 Give us a call for the best of the best. Quality brand names with service you can trust all backed by nation wide warranties. Pureflow, Valair, BD power, DDP, HTT, Industrial injection, Dipricol, Quadzilla, S&B, Snow performance, Edge, Diamond eye, MBRP, PDR and more. We install what we sell
#6 (permalink) |
I wish I had a lift or the manpower to lift the bed..... I think by slightly modding the bracket, I can use it closer to the transfer case. I figured I could cut off the portion the airdog mounts to, and then weld it directly onto the center of the plate that mounts to the frame.
#7 (permalink) |
Let me know if there is anything on my end i can do to help. we thought that the traction bar was going to be an issue and now this If i was closer i would be there in the morning to help yaJohn:thumbsup
#8 (permalink) | |
Chris 2007 Ram 2500, SLT Big Horn, Mineral Grey, 4WD, 5.9, BMK11 bypass, G56, 285/70/17, GV overdrive, D'Trac manual hubs, Smarty Jr, 6" Wwhistler, 4" turboback, LED's 2008 model 387 Pete, ISX, 10sp, 3:58 rears Last edited by Dsljnki07ctd5.9 : 03-08-2008 at 04:14 PM. |
#9 (permalink) |
well, it looks like I figured it out. I had to flip the bracket over and then redrill it (since the stock holes are upside down now. I also had to do what Dsljnki said and redrill the airdog mount to frame mount holes so that the airdog unit clears not only the floor of the cab, but so that the outputs on the airdog do not hit the stock fuel and brake lines. I am going to try and take pictures during the whole process.... As far as fiddling with the tank - mine is almost empty. I plan to open the valve on the filter housing - connect a hose to it and run it to a new gas can. Then bump over the starter to get the fuel pump to pump out the fuel.... We'll see if that works!
#10 (permalink) |
Yeah that's what I did - just flip the frame rail bracket - then you clamp the AD mounting bracket to that extension it bolts to and have ready made guide holes for redrilling and flipping the unit right side up, but it has to be cut off and rewelded down a little bit lower... After that was done I found I couldn't set the AD unit up as high as I wanted it though... Some of my bracket flipping hole drilling details may be a little off I'm going by memory from a few months back and editing this as necessary... I know you're doing exactly what I tried though and you surely know what I'm meaning lol...
Chris 2007 Ram 2500, SLT Big Horn, Mineral Grey, 4WD, 5.9, BMK11 bypass, G56, 285/70/17, GV overdrive, D'Trac manual hubs, Smarty Jr, 6" Wwhistler, 4" turboback, LED's 2008 model 387 Pete, ISX, 10sp, 3:58 rears Last edited by Dsljnki07ctd5.9 : 03-08-2008 at 05:05 PM. |
#11 (permalink) |
OK, here is what I did to the bracket.
#12 (permalink) |
Here is the final mounting. Now, all I need to do is drop the tank and run the hoses!! Easy! LOL...
