What Are The Warning Signs When Injectors Are Going Bad? - Dodge Cummins Diesel Forum
 1Likes
post #1 of 103 (permalink) Old 07-11-2012, 03:30 PM Thread Starter
Injectors go bad and destroy an engine.
What do you do to avoid that from happening?
How do you know the injector/injectors are a problem before the engine is trashed?
Seems to be a fairly common problem and no safeguards - which makes owning a diesel - which should be a troublefree truck a potential timebomb and money pit.
tijuanasam is offline
post #2 of 103 (permalink) Old 07-11-2012, 04:01 PM
jb15's Avatar
change fuel filter regularly, pull some injector cleaner (diesel) through them every once in a while
per my limited knowledge only gained by reading posts on these forums, white smoke out of the exhaust and after you turn the key off your engine goes to 6k rpms for a small amount of time
2006 long box 4x4 big horn
jb15 is offline
post #3 of 103 (permalink) Old 07-11-2012, 04:02 PM
CRCarnage's Avatar
hard starting, making oil, white smoke, rough operation, injector knock, search button, useful tool.
*03 RCLB, NV5600,4x4 Sold
Paying off my flhrci... Then it's 4th gen time
Originally Posted by madstuka View Post
Maybe you could get a loud bass stereo and crank "Boots in the Dryer" music. That is a form of expression too.
CRCarnage is offline
The Following 6 Users Say Thank You to CRCarnage For This Useful Post:
06 5.9 (07-11-2012), commtrd (07-17-2012), INHISI (07-11-2012), Unnamed (07-11-2012), w5gm (07-16-2012), Wheelie (07-14-2012)
post #4 of 103 (permalink) Old 07-14-2012, 08:05 AM Thread Starter
Im aware of the search button. However, I was hoping for some specific info.
When an injector/injectors go bad and wash out a cylinder, or cylinder,s and do engine damage that is costly. In order to avoid that from happening Im looking for ways to know its happening at that time it actually happens. in other words, to avoid potential engine damage.
This seems to be a somewhat common problem and it appears that the truck is not made with any safeguards to keep this from happening. Or there are no warning signs/indicators to let you know its happening until its too late.
Example, most vehicles have an idiot light or oil pressure gauge. You get a red light, or the oil pressure gauge shows no/low pressure you shut it down to avoid more costly damage.
On these Cummins an injector that floods cylinders washes out the oil and lubrication and you screw up your motor. So why no warning signs? Or is there any kind of warning? If not, its a major screw up by Dodge considering the potential for engine damage.
If Dodge wasn't bright enough to have any way to know when this is happening, what can we do to protect ourselves if we are in the situation? Who wants to own and drive a truck that at any time can have an injector go bad and destroy the engine - and have no way of knowing its happening?
post #5 of 103 (permalink) Old 07-14-2012, 08:12 AM
Get you oil checked every, oil change. Send it to the lab.
When your fuel % numbers go up then you got issues
sent from my mobile
2006 Mega 4x4 5.9 auto - Predator
Smuggler is offline
post #6 of 103 (permalink) Old 07-14-2012, 09:11 AM
papaduck's Avatar
Put a real oil pressure gauge in your truck. A drop in pressure will not show on the in dash gauge. I saved a Cummins ISB engine at work when the pressure was dropping below normal because the crank case was filling with fuel. That engine is still running a few years later.
03 Dodge 3500 SLT, HO, 6 spd, 4x4, SRW, quad cab, gauge on lift pump-boost-EGT-engine oil pressure and rail pressure, FASS 95, water seperator and 2m filter, steering box brace, 6.7L fluid damper
papaduck is offline
post #7 of 103 (permalink) Old 07-14-2012, 11:36 AM Thread Starter
sent from my mobile
That might work, but way too impractical. Who would want to do that every oil change?
post #8 of 103 (permalink) Old 07-14-2012, 11:37 AM Thread Starter
Ok, sounds like a good idea.
Still Dodge should have something in the truck as a legitimate warning IMO.
post #9 of 103 (permalink) Old 07-14-2012, 12:00 PM
You have been given good answers. If you think there needs to be a better warning system, maybe you could get rich coming up with one. Just curious, since you want to bash Dodge for not having a better warning system, what warning system do chevy and ford use? What about Peterbilt and Kenworth?
2004.5, Smarty and MP-8, HTS Trans, E.D 64/68/14,
DiPricol fuel, rail, boost, trans, EGT
Intake, elbow, exhaust
DieselPlower is offline
post #10 of 103 (permalink) Old 07-14-2012, 12:35 PM
dieselnoob89's Avatar
where does a guy get a "real" oil gauge?
05. Stg 2 shift kit, Smarty, AFE, 13" Rize, 40" toyo, BMF novakane, Road Armor, MBRP, Carli balljoints, Thuren steering, Yukon hub kit, SS brake lines, FASS HD 150 lift pump, Fox, Autometer rail, fuel, egt, boost, tranny temp gauges. TRUCK SOLD OCTOBER 2016
dieselnoob89 is offline
post #11 of 103 (permalink) Old 07-14-2012, 12:45 PM
Any diesel performance shop.
post #12 of 103 (permalink) Old 07-14-2012, 01:00 PM
World Champs!!!
MoparProud's Avatar
Search on all these forums is about as good as boobs on a guy; good for a quick glimpse, but then you really see what's going on and it's completely worthless.
In other words, search is a joke.
First off, Dodge didn't design the fuel system, Bosch did. Bosch also designed the system used in the Duramax as well as the system used on the 6.7 Powerstroke, not to mention the system used on VW's and Mercedes, and....see a common thread here?
Don't blame the vehicle manufacturer for the issue. For some reason, the Cummins seems to have far more issues with injectors going bad and eating a piston or two...Duramax trucks largely don't (LB7 sounds like it's still a problem); I've yet to hear of a 6.7 Powerstroke popping pistons, or a VW. Even tuned, I don't think it's an issue really with them. But, something in the Cummins system certainly cause alarm; I've toasted two engines with injectors as the root cause. I'm at the point, hey if it blows, it blows. Build another to support more power. A failure is simply an opportunity to upgrade.
So, how is a manufacturer supposed to monitor injector health on the fly?? Let's see, I believe VW has a new injector design that monitors cylinder pressure, but I bet an injector failure wouldn't show up as a definitive "injector 4 is going bad, replace it". Sounds like a billion-dollar prospect, get on it.
'07 3500 SRW QC/LB-EFILive w/Silverbullet Tuning-Goerend-WOP triple turbo-200% Exergy-Carli Backcountry
'03 2500 QC/LB. HO/NV-
-HE351v-Southbend-TNT/R
Originally Posted by Common View Post
Why would you buy a Hellcat for road trips?
Originally Posted by MorSmokPls View Post
Because you can
MoparProud is online now
The Following 2 Users Say Thank You to MoparProud For This Useful Post:
8secondride (08-10-2012), Rockin3Ltraining (10-25-2012)
