Running rough - Dodge Cummins Diesel Forum
post #1 of 15 (permalink) Old 06-13-2012, 08:35 PM Thread Starter
sthrnrider's Avatar
Running rough
Ok my 06 just rolled 100k. I took the wife to the doctor today, me and the kids rode around the car lots looking well after about an hr. or so of low RPM driving around the truck started acting like it was missing when at a stop light. But when i took off it was ok. Well I got it on a good stretch and opened it up for a few seconds and it was fine after that. This happen to anyone else?
2006 Megacab 3500 Dually 4X4 5" turbo back / Edge Juice with CTS
2001 QC 3500 DUALLY SILVER
OILFIELD TRASH & PROUD OF IT
AFE STAGE 1 /4" TO 6" TURNOUT STACKS / HOLLEY BLACK / FUEL GAUGE / EDGE JUICE W/ATT / PHAT SHAFT 62
sthrnrider is offline
post #2 of 15 (permalink) Old 06-13-2012, 08:41 PM
Ram_Wagon's Avatar
iTrader Score: 5 reviews
Mine has had a rough idle every once ina while. Like you stated, usually after short trips without much 'boosting' but I haven't had any concern because it's so intermittant. Doesn't seem to last long, and doesn't appear to be "Life Threatening" to the 5.9L.
I'd say keep a mental note of how often and under what conditions it happens, and Then ask here...?
Daniel
Former Dodge Truck(s) Owner... Still a part of Cummins!
Ram_Wagon is offline
post #3 of 15 (permalink) Old 06-13-2012, 09:07 PM Thread Starter
sthrnrider's Avatar
First time it had happened but this is the first time idling around lots and not building much boost.
post #4 of 15 (permalink) Old 06-14-2012, 07:45 PM
Ram_Wagon's Avatar
Wish I had an answer for ya? I would say again, just pay attention IF it does it again? And see what conditions actually "set" the rough idle. I haven't done that, because I figured with 154K miles, I should expect it?
Keep us posted IF you find anything?
post #5 of 15 (permalink) Old 06-15-2012, 11:00 PM
CumminsGirl91's Avatar
Mine did that in the 9X,XXX+ miles and still does every now and then. It would lope, idle rough, and sometimes just when I came to a stop. Took it to the dealer under warranty and of course, "they didn't see anything wrong with it".
I used Stanadyne and it worked for a good while. Started doing it again and so, I tried 2-stroke oil...worked for while. Then, started doing it again occasionally. It left me in the parking lot at work after working 12 hours the other day. I wasn't too happy. Now, at 118,XXX miles, found out that I do have a bad injector in number 2. Not saying you have the same problem, but just throwing it out there.
I bought a re-manufactured injector today and we're going to get it in tomorrow- hopefully, I'll be good for a long time now.
CumminsGirl91 is offline
post #6 of 15 (permalink) Old 06-15-2012, 11:11 PM
Ram_Wagon's Avatar
Just outta curiousity, any clue as to why only 1 injector fails? (asking that in general, not to anyone specific) Would it be safe to say that if 1 of 6 fails, then the other 5 maybe suspect later on?
I gotta quit thinking out loud...
But in MOST cases, let's use something as simple as a headlight. If 1 goes out, if it was installed around the same time as the other, is will more than likely go out too soon.
So in the case of injectors, CumminsGirl91, I'd be ready to find the other 5. JUST in case!
I REALLY Hope you don't have another crap out on ya! You'll blame me for jinxin' ya!!!!
Mine does the "loping" too, along with the rough idle... sometimes? Can't "make" it do it. Just does. Wondered about Low Sulfur diesel sometimes...
Daniel
post #7 of 15 (permalink) Old 06-16-2012, 01:45 AM Thread Starter
sthrnrider's Avatar
Yeah I get the lope sometimes as well. Noticed it a cpl weeks ago it loping when I started it up was wondering what the heck was going on. It doesn't lope enough to move the tach.
post #8 of 15 (permalink) Old 06-16-2012, 12:07 PM
Daniel
Lol, yeah! I was thinking the same, especially considering my luck!! I hope the other 5 won't go out, at least for a long time. I was considering buying a whole new set but maybe later on. I just had to buy a new a/c last week and didn't feel like spending any more $ this month.
The Following User Says Thank You to CumminsGirl91 For This Useful Post:
Ram_Wagon (06-18-2012)
post #9 of 15 (permalink) Old 06-16-2012, 04:33 PM
Moochoff's Avatar
I would be very wary of the othe injectors if it were mine... It's often advised to get all 6 NEW injectors. Messing around with remans can be extremely time consuming and cause more down time than it's worth
And to the OP it might not be a bad idea to check out the rough idle sticky and check some wires out
Sent from my Autoguide iPhone app
Moved on to smaller toys.
Moochoff is offline
The Following User Says Thank You to Moochoff For This Useful Post:
sthrnrider (06-17-2012)
post #10 of 15 (permalink) Old 06-17-2012, 12:03 AM Thread Starter
sthrnrider's Avatar
Thanks I'll do that
post #11 of 15 (permalink) Old 06-18-2012, 01:14 PM
rgsauger's Avatar
My 06 with 207K miles has done the lope every now and then for the last 100K miles. Not always, just occasionally. Not worried about it.
06 Mega 4WD,Transgo, 315K miles, 2" TopGunz kit,4.11, H-2 wheels,35/12.50/17E BFG's, Flashpaq, K&N, B&W goose, dual shocks at each corner up front, steering box brace, and a bigass dent in the tailgate because my wife just had to back the trailer...
rgsauger is offline
post #12 of 15 (permalink) Old 06-18-2012, 05:03 PM
Tuckert's Avatar
Mine does it on occasion, from what I've figured out, 1. your injectors are probably getting up there in age (sometimes this has nothing to do with it though) 2. It's the idling around that causes this, the fuel isn't being shot through the injector fast enough or in enough volume so it "clogs" the injector just a tad causing a slight rough idle. That's why you notice after you run it good it doesn't idle bad when you stop. So when your putting around roll alittle coal just to get the rpm's up for a second to keep those injectors clean. A lot of the times I leave my truck at idling I'll use the high idle to keep the fuel flowing!
06 Laramie 2500, a little 🔊🔊, it's heavy and not so quick.
Tuckert is offline
