Re-prime / bleed fuel lines - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 05-17-2012, 02:20 PM Thread Starter
I have a 2007 ram, straight piped, cold air and edge juice w/ attitude.
I was low on fuel, not empty but the truck justed sputtering at idle to turn into the gas station. I didnt run dry but when I turned the off to fill up it wouldnt restart.
I have followed the steps to prime the system. Go to start the truck as usual, crank for a second then start cranking again when the lift pump shuts off. Ive done this countless times now.
Last night, the truck sounded like it was starting to turn over with whitesmoke from the exhaust. Is this progress?
Is the edge interfereing? Should I unplug it?
Any other tips?
2007 Ram2500 5.9CTD - Straight pipe, AEM Workhorse, Edge Juice/Att, Deep tran pan
BlastZone is offline
post #2 of 13 (permalink) Old 05-17-2012, 02:23 PM
Master of Mayhem NASFIG
rpage's Avatar
self priming system, dont crack the lines pressurized fuel can kill you.Remove the edge to see if its interfering. white smoke is a drippy n dirty injector. all white smoke is is unburned fuel.
Really don't give a rat's App**
rpage is offline
post #3 of 13 (permalink) Old 05-17-2012, 04:47 PM
TECH SPECIALIST
steelhead01's Avatar
may have fried the lift pump or the HP CP3 pump from no diesel for lube/cooling
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
post #4 of 13 (permalink) Old 05-17-2012, 05:50 PM Thread Starter
I can hear the lift pump running. It also fills the fuel filter reservoir.
There is fuel getting to the injectors. Would that be the case if the cp3 was shot?
How many times should I be doing the crank cycle before it fires?
Do EGTs play any part in being able to tell if it's close to firing or not?
When I'm crank, I can hear the engine chugging like it's trying to start up but it's not. EGTs were only hitting 100 before, today they're hitting past 140 degrees. Like I asked, is that an indication of anything?
post #5 of 13 (permalink) Old 05-17-2012, 08:02 PM
gordy michael's Avatar
people say dont crack the line while cranking.....well i took my fuel rail off to get to my intake plenuim and when i put it back together i had to crack the #1 cyl line while i had a buddy crank it and it took a few cranks to get fuel to the injectors then it fired right up.
2006 4x4 quad cab 2500 slt, tunnel ram intake plate, w/horn and heated air delete, 48re, billet tc, heavy duty shafts, smarty s06 pod, afe intake air filter and torque tube, silencer ring mia, 5in straight pipe. Iss pro pyro, boost,air dog 100, low fuel press led.
gordy michael is offline
post #6 of 13 (permalink) Old 05-17-2012, 08:28 PM
mkwelds's Avatar
Well thats good for you but the day the 4500+ psi diesel cuts into you hopefully your brain will regain the ability to work. Yes this is a totally self priming system, no need or use in cracking open any of the fuel lines (especially injector lines) to "bleed" the system.
Just cause you can hear the lift pump doesnt mean it is pumping the appropriate mount of fuel. Id say check lift pump flow and pressure first. If its all good move on to the CP3. Like Steelhead said possibly you burnt out one of or both of the pumps due to lack of lube/fuel.
2004.5 3500 4x4 NV5600, PDR Cam, ARP 425s, industrial injection 60 horse injectors, Raptor 100 fuel pump, DIY 2micron fuel filter system with big line upgrade, HE351 over S475,more brewing
SMARTY S06 and UDC fine tuning all of it
mkwelds is offline
post #7 of 13 (permalink) Old 05-18-2012, 02:19 AM
TECH SPECIALIST
fresh meat anyone from a former "homebrew diesel mechanic"
The Following 2 Users Say Thank You to steelhead01 For This Useful Post:
mkwelds (05-18-2012), Moochoff (05-19-2012)
post #8 of 13 (permalink) Old 05-18-2012, 07:29 AM
plugged fuel filter
carlsonr is offline
post #9 of 13 (permalink) Old 05-18-2012, 02:55 PM
pjs thunderbolt's Avatar
Can you say ouch??????
He's lucky he dosent have a whole all the way through his hand........
The normal stuff: baldwin fuel filter, silencer ring MIA, K&N cold air intake w/Amsoil 4090 filter, fuel, trans, coolant, boost, lift pump pres., pyrometer gauges, diablo trinity tow & performance tune only, Suncoast single disk t.c. Is next w/shift kit.
pjs thunderbolt is offline
post #10 of 13 (permalink) Old 05-18-2012, 03:57 PM Thread Starter
I'm not saying its the right way but funny enough the diesel tech at the stealership suggested that I crack the injector line. Absolutely no more than one turn.
Fuel filter still in new condition. Same colour as when I bought it.
How would one check for debris in the lines?
Remember, the truck didnt die because it went dry. I turned it off at the gas pump. It had pnly started sputtering at an idle waiting to turn into the station.
post #11 of 13 (permalink) Old 05-18-2012, 04:07 PM
rpage's Avatar
crack a line loose before the cp and see what its doing
rpage is offline
post #12 of 13 (permalink) Old 05-18-2012, 08:27 PM
TECH SPECIALIST
running these HPCRs below 1/8 tank results in hot diesel with lots of air mixed in going to the pumps. lift pump overheats which causes damage.
CP3 overheats from hot fuel and air mixed in. Diesel with large amounts of air bubbles has little to no lube quality.
remember the CP3 bypasses at least 80% and most of the time over 90% of the diesel going into it for cooling and lubrication.
only takes seconds to damage a CP3.
