best torque coverter for the price - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 05-14-2012, 06:31 PM Thread Starter
well after my torque coverter bolts have worked themselves loose 3 times in the past month, dealer says i need a new torque converter and flex plate. i do not want to go back with stock parts! so whats ya'lls recomendations? truck is used as a DD and tows every once in a while. want one that is a step up from stock. thanks
BLACK SMOKE 09 is offline
post #2 of 19 (permalink) Old 05-14-2012, 06:54 PM
04.5CTDlaramie's Avatar
and single disk from goerend, garmon, suncoast, dtt, revmax...take your pick, theyre all better than stock.
04.5 2500 Laramie,4x4,3" level w/bilsteins,17's w/35s,4.10s,63/68/.80,smarty tntr,floor it cp3,edge ez,water meth,straight pipe w/cat,s&b intake,elbow,raptor 150,big line,billet trans,gauges boost,egt,fp,rp,539hp/979tq
04.5CTDlaramie is offline
post #3 of 19 (permalink) Old 05-14-2012, 06:56 PM Thread Starter
also forgot to say its for a 48re.
post #4 of 19 (permalink) Old 05-15-2012, 04:02 AM
Um... bolts dont just loosen up assuming they have been installed corectly. Did the threads somehow get messed up? Assuming your paying for this out of pocket, I would almost use lock wire, lock tight ETC before I just spent money to spend money for bolts loosening up.
Wonder if something inside is bent causing a vibration. or a bad U joint or...
imjustdave@hotmail.com is offline
post #5 of 19 (permalink) Old 05-15-2012, 08:11 AM
[QUOTE=BLACK SMOKE 09;5139755]well after my torque coverter bolts have worked themselves loose
I had the same issue and had to replace the flex plate. While it was down I also had Chaz the tranz man replace the converter and up grade the VB.
Question is who retightened the bolts?? If the dealer did then I'm thinking that they are responsible for said replacement they are saying that you need.
Jim
03 quad cab dually, J&J stainless boards, extang full tilt toneau, bhaf, glacier 392
"some days you get the bear, some days the bear gets you"
dezeldog is offline
post #6 of 19 (permalink) Old 05-15-2012, 08:22 AM
Also I do believe that Chaz got a converter from Wally at Fte and I am quite pleased with it. My truck is a DD and strickly stock so it works for me....HTH
Jim
dezeldog is offline
post #7 of 19 (permalink) Old 05-15-2012, 09:03 AM
CantStopCummins's Avatar
I have a Precision billet triple disc and it has been nothing but great so far.
2005 QCSB | MTD Built 48RE | Smarty UDC | Edge Insight CTS | AFE stg 2 | Muffler Delete | GDP 2MK Big Line | 2.5" level | Gauges | Bushwackers | Nitto Trail Grapplers 35x12.5 | MTD Traction Bars | CD Steering Box Brace | Maxx Links
CantStopCummins is offline
post #8 of 19 (permalink) Old 05-15-2012, 09:39 AM
Hello Kitty admirer
MadMikeX3's Avatar
Pm Revmax
Sent from my HTC Sensation 4G using Tapatalk 2
00' 2500 Sport QCSB, 4X4 Auto, Open down-pipe exhaust, Smarty S-03, Air Dog I, Eagle Alloy Series 185 16X10 Maxxis Buckshot's 315/75/16. ""There is no replacement for Displacement except for volumetric forced induction."
MadMikeX3 is offline
post #9 of 19 (permalink) Old 05-15-2012, 11:26 AM
amko22's Avatar
Goerend triple disc, just shy of 1500 but comes with a lifetime warranty. Love mine!
05 crewcab> Short Bed> Built Auto> SRW> K&N intake> 5in turbo back> Silencer ring MIA> 8000K headlights> 6000K Fog Lights> Smarty SO-6> Fass> 60hp nozzles> More to come!
amko22 is offline
post #10 of 19 (permalink) Old 05-15-2012, 12:25 PM Thread Starter
ive looked at goerend, garmon, suncoast, ats, and revmax. revmax is the cheapest, however there all reasonably priced. looking for a tripple billet tq and billet flex plate. it may be over kill but atleast i would have piece of mind that i shouldnt have any problems out of it. im ordering a tq and flex plate when i get home this evening, so.....
post #11 of 19 (permalink) Old 05-15-2012, 12:30 PM
i purchased the stage 4 revmax 3 disk 300 lower and couldnt be happier. night and day over stock. lock up is firm but not harsh. ive heard some 3 disk can have such an aggressive lockup theyve been known to break stock inputs.
post #12 of 19 (permalink) Old 05-15-2012, 01:51 PM Thread Starter
Most likely going with rev max. Should I get the low, supper low, or high stall Stator upgrade?
