Dtt voltage regulator - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 04-11-2012, 10:04 PM Thread Starter
xmikedentx's Avatar
Is this how you hook it up?
2006 2500 4x4 TRX edition, 4" Lift, 35" Toyo's, AFE Stage 2 intake, Magnaflow 5" Turbo back, Edge Juice w/Attitude, DTT super single TC, DTT shift kit. Amsoil Bypass Oil Filter, Coolant Filter, Poly Performance Sector Shaft Brace.
xmikedentx is offline
post #2 of 5 (permalink) Old 04-12-2012, 11:47 AM
That splice is a problem waiting to happen.
1983 2500 Suburban 6.2 sm465 4x4
bftrain is offline
post #3 of 5 (permalink) Old 04-15-2012, 09:29 PM
cchase's Avatar
That Guy needs to clean his engine compartment. That wire looks like yellow and orange not yellow and pink.
2007 quad 5.9 4x4 stock exept for turbo baffle removed
cchase is offline
post #4 of 5 (permalink) Old 04-16-2012, 03:21 AM
cumininmycummins's Avatar
Those butt connectors dont belong on load sensitive electronics. At LEAST get bare crimps and heat shrink them. Better yet solder them and they last longer then the copper. If you leave those as they are youll be fixing them in a matter of weeks.
Sent from my Motorola Electrify using AutoGuide.Com Free App
Smarty, mild trans, stuff
cumininmycummins is offline
post #5 of 5 (permalink) Old 04-16-2012, 11:55 AM Thread Starter
xmikedentx's Avatar
This was meant as a temp connection to see if we had the right wire. The instructions were a bit confusing, and I thought the wires in the engine bay were the same as the ones going to the tranny. Turns out there are 3 yellow with kinda pinkish stripes on them, and the wire you need is down on the actual plug.
So this is a "what not to do" thread.
And yes, the engine bay needs to be steam cleaned next time I work on it....
