2005 48RE won't shift into 3rd - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 04-06-2012, 06:40 PM Thread Starter
Tech Specialist
wildcat's Avatar
My Dad's truck, bone stock with 83K on it, occasional towing 5K or less, but has towed 10K rarely.
Mostly, he just drives it around empty, and most of that is highway miles.
Symptoms:
Last week we noticed it didn't want to shift into 3rd gear. It would run all the way up to red line, and occasionally shift up to third if he backed out of it, sometimes, shifting back down to second, sometimes continuing on into upper gears.
I have read the threads here, and think I have all the bases covered as to what we can do to fix what's wrong without pulling the transmission, but just in case I missed something I wanted to run it by you guys to see what you think.
We checked every fuse and relay identified on the power center cover as being for the transmission, even swapped some of them around where we could find a "like match" in non critical equipment.
We then replaced the fluid, filter, tightened the bands per spec. When we dropped the pan, the fluid smelled burned, and the magnet was "Fuzzy" but nothing metal... I expected there to be more, but there wasn't. Kind of looked normal for a truck with 80K+ on it.
Test driving it we had the same problem. Today we replaced the Governor solenoid and Gov. Pressure switch, the problem persists.
Any ideas?
Thanks in advance!
2007 Dodge 3500 SRW 4X4/5.9L/48RE, KORE, SRT-10 hood, Recon, Isspro, ICEBOX/S&B, Walbro, SMARTY, CFM+, HGD, 5" TBE, TC & VB, SPS 62/71, Head studs, spool aid.
wildcat is offline
post #2 of 4 (permalink) Old 10-06-2012, 08:50 PM
texascummins13's Avatar
Im having what seems to be the same problem with my 06 it just randomly started last night have yall found the problem or are yall still looking?
06 2500 4x4 auto, smarty TNT-R, gauges, goerend billet tranny
, straight pipe, industrial 100s, airdog 150, AFE bladerunner intake and exhaust manifold, T&C 80% over cp3, modded wild rail with 32k valve
texascummins13 is offline
post #3 of 4 (permalink) Old 10-06-2012, 09:06 PM
LiftedI6Cummins's Avatar
im havin that prob too but myne runs to redline in 1st then meshes into 2nd. wont go to third unless you revv it up then let off completly. Im scared to drie because it gets kickdown happy and will bring the engine up to like 3500 rpm when it drops down. last thing i need is that happening on the highway.
2005 Ram 2500 4x4 qcsb. Arp headstuds, industrial 100hp injectors/cp3. aFe intake and intake manifold, 5" tbe, billet flexplate/input shaft, triple disc tq converter, 6"lift 37"tires.
LiftedI6Cummins is offline
post #4 of 4 (permalink) Old 10-07-2012, 05:56 PM
Lifted thats what mine is doin as far as the 3 gear i drove it around got it to 3 then o/d and it dropped down to 3 im supposed to be goin to waco from fort wort tomorrow thats not lookin like thats gunna happed with it droppin to 3 from o/d if anyone else has any input that would be greatly appreciated!
