06 Rough idle - Dodge Cummins Diesel Forum
post #1 of 16 (permalink) Old 03-14-2012, 10:17 PM Thread Starter
06 Rough idle
have an 06 cummins with a rough idle truck has no trouble starting no codes had injector drop test performed and all dropped the same... smoothes out when driving or at 1000+ rpms looking at the engine at idle the truck shakes more than the engine... can hear a slight knocking coming from bottom towards back of engine but changes pitch when pushing in the clutch... was told truck has a dual mass fly wheel i think thats what it was called and heard that they get out of balance and cause similar symtoms. any one else agree or have any other ideas to what else could be the problem have had this issue for about 2 years also have had a smarty on it and it didnt seem to make a difference with a chip at all. any ideas would be appreciated
Cumminmopar is offline
post #2 of 16 (permalink) Old 03-14-2012, 11:43 PM
gordy michael's Avatar
I had a similar thing and it turned out to be the harmonic balancer just a thought.
2006 4x4 quad cab 2500 slt, tunnel ram intake plate, w/horn and heated air delete, 48re, billet tc, heavy duty shafts, smarty s06 pod, afe intake air filter and torque tube, silencer ring mia, 5in straight pipe. Iss pro pyro, boost,air dog 100, low fuel press led.
gordy michael is offline
post #3 of 16 (permalink) Old 03-15-2012, 12:27 AM
Wheelie's Avatar
Im having this same rough idle issue and when I rev it up it sputters and slowly rpms drop. Other then that its smooth in higher rpms just as yours.Everything has been serviced/inspeced on mine so I am curious what other have found also.
'06 White auto 2500 Laramie HD 4x4 5.9l QC/SB, Triple Dog GT tuner, MBRP exhaust, DPF delete, Air raid intake, Airdog 100, Dragon FLy 60hp injectors, 6" superlift, 35" procomp tires, 150,000 mi.
Wheelie is offline
post #4 of 16 (permalink) Old 03-15-2012, 10:31 PM
Good luck!
There are springs in the dual mass that wear out mine were but that didnt fix it. Just did injectors too, but my truck was down so long i forgot what normal was.
Check ac wires?
Fca?
06 Mega- fire punk comp1 Auto, LVD, EV1's, 5" TBE, Sportsman 6.7 CP3, S&B intake, GDP 2mic, 100hp Exergy, EFI CSP5 by Les, fass 150. Apr 425, ED63/68 268Kmi
jray3369 is offline
post #5 of 16 (permalink) Old 03-15-2012, 10:48 PM
iTrader Score: 5 reviews
i have talk to sheid diesel industrial beans diesel and several other and they all agree injectors my truck has all the same issues and sometimes it runs really well no white smoke ever and smoothes out around a thousand if i rev it up is slow to return to idle as if it almost bounces back to idle something else you guys should watch is your tach on start up mine will be below idle then i rev it up and it moves up a bit closer to idle but my truck does sit all week since i have a work truck.my truck has 115,000 they all say that around 135,000to 150,000 you start having return rate issues with the injectors everybody varies a bit but all agree on injectors.
06 MEGA CAB, Smarty,Autometer gauges, Volant cai,banks intake horn,RSD 5in TBE,Bag of parts
WHTCummins00 is offline
post #6 of 16 (permalink) Old 03-15-2012, 10:58 PM
hey i just got my 06 6 speed stnd. in sep. and had the same exact thing happening, pulled the trans and found my flywheel was screwed! The springs in there where so worn out it was unreal! for some reason, that makes no since on a diesel, they put springs in the stock flywheel and with that much torque they wear out fast... i only had 89K and they where worn out.... i went with a valair dual disk (kinda wish i had a single now due to bein noisey) came with new flywheel, bearings, clutch.... You dont want to put off changing your flywheel/clutch due to it can come apart and destroy you trans., bellhousing, and possibley your block.... not to mention the toll its taking on your crank and bearings... You can just change your flywheel but might as well change your clutch and all.... more cost/time effective....but btmn line id bet money its ur flywheel.... (and fyi i didnt belive the first 3 ppl that told me this)
2006 Dodge ram 2500 CTD, 4X4, 4 Door, Long Bed, G56, 5" RSD exh., bills 5" intake, smarty, dual disk valaire, 35" trail grappler's, 2"level kit & stearing gearbox brace
cpickett1989 is offline
post #7 of 16 (permalink) Old 03-16-2012, 12:35 AM
lonestarwelder's Avatar
Your clutch is smoked, mine did the exact same thing. Get a new clutch, preferably South Bend or Valair, before it takes out your transmission case.
2015 3500 DRW Laramie CCLB 68RFE 4.10 4x4.
Cooper LT255/70R17 ST Maxx and 2" Stahl Steel spacers. 1.5" Traxda leveling kit. Mag-Hytec rear cover with 75/110 Amsoil.
SOLD:2010 3500 DRW Big Horn CCLB Auto 4x4.
SOLD: 2005 3500 SRW SLT 4x4 G56
lonestarwelder is offline
post #8 of 16 (permalink) Old 03-16-2012, 07:48 AM
intercooled's Avatar
My 06 idled rough when the fuel filter got to dirty... i run marked diesel so the dye plugs it up
1992 W250 LE Red/Grey RCLB 4x4 Cummins A727
Sold (Wish I Kept)
2006 3500 SLT Khaki MCSB 4x4 Cummins 48re, HBS 2", 325/60R18
Sittin in the garage: 3" TGC lift & 35x12.50 Toyos
intercooled is offline
post #9 of 16 (permalink) Old 03-16-2012, 10:01 AM
I agree, it's sounds like your flywheel is coming apart. I had 2 buddy's with 06 trucks that both had the flywheel problem.new flywheel and clutches did the trick.
2014 mega 3500 srw longhorn.
00 4wd built auto,studs,oringed head,103 springs colt cam,69 sxe,dap 225's,fass 150,edge drag comp,snow stage 3,ats lockup box, reverse leveled,longhorn fab bars,nitto 420's.
02smokin is offline
post #10 of 16 (permalink) Old 03-16-2012, 03:53 PM
I know this wont help but i too had the rough idle and replaced the clutch, yes the spring were wore but didnt fix it. Had 3 injectors fail the test. Truck ran fine other the the slight rough idle...
If id do it over again i send injectors to exergy FIRST, spent over $5500 in clutch, jectos, arson (thought it was FCA, if not is upgraded)
Test fees, dealer test fees, rail guage......
jray3369 is offline
post #11 of 16 (permalink) Old 01-10-2013, 07:59 PM
I too have rough idle, 06 2500 with 6 spd., knock toward back of mtr. Diesel runs good 1000rpm and up, is clutch the problem?
Bolted dodge is offline
post #12 of 16 (permalink) Old 01-10-2013, 08:33 PM
blacksmoke83's Avatar
If the noise changes when you push in the clutch, then YES. It is a clutch issue.
If you have a rough idle with slight knocking noise and it doesn't change when you push in the clutch pedal then it is most commonly injectors.
2007 Mega Cab: Coated pistons, machined rods, balanced rotating assembly, Colt Stage 4 cam, Twin FASS Titaniums feed twin 33% over CP3's Industrial Silver 64 over S483 EFI Live
blacksmoke83 is offline
The Following User Says Thank You to blacksmoke83 For This Useful Post:
snipewa (07-22-2015)
