transmission/tranfer case leaking...need advise - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-07 Common Rail Forums > 3rd Gen. Powertrain
Old 03-11-2012, 10:00 PM   #1 (permalink)
Bayouboy81's Avatar
noticed a few drops under truck today and it looks like its leaking where the trans/tranfer case couple together. Can you guys give me a run down of what I need to fix it and how to do it. Can I do the job in my driveway or will i need to go to a shop that has a trans jack?
Thanks fella's
06' 5.9L Laramie Megacab 4x4, Bullydog PMT, S&B intake, QZ Boost-fooler, Hell bent steel 2.5" leveling kit, 20" MB Motoring w/ 35x12.5x20 Mickey Thompson ATZ's. Silencer ring mia. Straight-Piped, Debadged, Roll-n-lock bedcover, Ranchhand rear bumper
Bayouboy81 is offline   Reply With Quote
Old 03-12-2012, 08:55 AM   #2 (permalink)
looks like its been out before (see RTV), you can have it out in 15-30mins depending how fast you are, its easier on a hoist, but can be done easily on your back.
unbolt drive shafts,, unplug electrical connections unhook vent line on top, undo 6 or 7 mounting nuts, slide the TC back until it just clears the studs it will allow the TC to swing down, it weighs about 75$ you can pull it off lay it on your chest then allow it to roll onto the floor, its easier than I explained. having 2 people would make it easier to handle.
when re-installing just worry about getting the 2 shafts lined up, after that rotate the TC till the studs line up with the proper holes (reverse of removal)
2003, QC/SB. Edge Juice,Hot, AirDog150 S&B CAI, BD Flex plate/tripple loc T/C. georend VB Trans rebuilt by Me. Bilstien5100. Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline   Reply With Quote
Old 03-12-2012, 09:34 AM   #3 (permalink)
Spend money on good RTV sealant like Mopar or International. I have used them all and these seem to be the best. Tried cheaper on 7.3 oil pan gasket and got to do it over for free.
[SIGPIC][/SIGPIC]2005 2500 MCLB 5.9 HO Stock 2 Mu Filter 1976 Ply Duster, 360 4sp 452 Hp Dyno 1992 5.9 Out of a FL60 going into a 47 Buick Special. If you can't fix it, GET A BIGGER HAMMER!
Jo Diesel is offline   Reply With Quote
Old 03-12-2012, 03:56 PM   #4 (permalink)
Bayouboy81's Avatar
Do I have to drain any oil prior to disconnecting the TC?
