Transmission issue - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-07 Common Rail Forums > 3rd Gen. Powertrain
Old 03-04-2012, 10:42 PM   #1 (permalink)
Transmission issue
Hi everyone, I have a '07 5.9 2500 auto and it's having issues going from first to second gear. It revs up and down as its trying to shift. Not real bad, but noticeable. I got the trany fluid changed and the magnet inside was full of shavings. I'm assuming the transmission needs to be rebuilt, but until that happens I have fuel economy concerns. I've had the truck for a year, got a chip put in and am still getting about 12 MPG. Are the two related? Thanks a lot.
Ryanbumgardner is offline   Reply With Quote
Old 03-04-2012, 11:05 PM   #2 (permalink)
gordy michael's Avatar
Well 12 doesnt sound that good and do you have any upgrades to your tranny? It mite have to much power for a stock trans also.
2006 4x4 quad cab 2500 slt, tunnel ram intake plate, w/horn and heated air delete, 48re, billet tc, heavy duty shafts, smarty s06 pod, afe intake air filter and torque tube, silencer ring mia, 5in straight pipe. Iss pro pyro, boost,air dog 100, low fuel press led.
gordy michael is offline   Reply With Quote
Old 03-04-2012, 11:06 PM   #3 (permalink)
CumminsDieselSoot's Avatar
It does sound like your tranny is going out. If your tanny is having problems it will effect your fuel economey.
Former Marine. 2004.5 QCSB, ATS stage 4 tranny, Smarty S06 POD, Banks high ram, Amsoil EaAU4510 air filter , intake muffler MIA, turbo silencer ring MIA, strait thru muffler, issopro guages, firestone air bags, on board air compressor with 5 gal air tank, train horns.
CumminsDieselSoot is offline   Reply With Quote
Old 03-04-2012, 11:40 PM   #4 (permalink)
The trany is stock and thanks for the info guys. Any idea what a rebuild runs? $1-2k is my guess...?
Old 03-04-2012, 11:50 PM   #5 (permalink)
cumininmycummins's Avatar
$3000+ for a good HD rebuild
cumininmycummins is online now   Reply With Quote
Old 03-05-2012, 03:53 AM   #6 (permalink)
Matt.k's Avatar
My truck was doing that, seemed like it was slipping...it would start out in 2nd gear. It was the Pressure governor solenoid/transducer.
I did not have excessive shavings on my magnet though, it was pretty damn clean!
Matt.k is offline   Reply With Quote
Old 03-05-2012, 11:05 AM   #7 (permalink)
Mutch79's Avatar
you dont need a re-build!
You need a borge warner selenoid and pressure sensoe. Also a solid state servo and 12 quarts of new fluid. You can do all the work from home if your comfortable removing your valve body. While your at it, add an oversized pan and temp guage. The total cost is about $500. I just did it. PM me with q's if you need. Here's a helpful link.
Borg Warner Governor Solenoid for 42-48 RE Transmissions
07 2500 SLT-Long Bed, 5.9L H.O., 2WD, 2.5" level kit, Diablo Sport Programmer, Cat Delete, Magnaflo Muffler, K&N Cold Intake, Built up Valve Body, 256:1 2-Stroke Mix, B&M trans Pan, functional hood intake.
Mutch79 is offline   Reply With Quote
Old 06-06-2012, 12:35 AM   #8 (permalink)
is a oversize pan necessary for the new selonoid ?
hendo is offline   Reply With Quote
Old 06-06-2012, 12:43 AM   #9 (permalink)
the reason why i am asking is because i am having problems with my tranny
going from 1st to second my revs have to hit 3500 rpms before it shifts into second ,i added fluid as it was a little low but still the same added more fluid and it has problems going into overdrive ,so i have to get some fluid out
my intention is not to hyjack a thread but the problem maybe the same
any help will be appreciated
Old 06-06-2012, 01:04 AM   #10 (permalink)
Garmon Transmissions!
06 5.9's Avatar
iTrader Score: 14 reviews
change the governor pressure solenoid and transducer first
06 2500 Inferno Red 5.9Garmon Stage 3...Full Billet BA TRANNY OD BURNOUTS READY 11.40@119.9 Byron Diesel Shootout (2nd Place)
06 5.9 is offline   Reply With Quote
Old 06-06-2012, 01:08 AM   #11 (permalink)
SmokenAce86's Avatar
Its not necessary for the solenoid, but a larger pan will allow you to put more fluid which will help keep your trans at a lower temp than a stock pan and stock fluid amounts. My truck is in the shop here in AK right now getting built(minus shafts) I dont plan on doing boosted launches or sled pulls atm. The rebuild kit for mine is 3 grand. Youll wanna upgrade to the billet band and band struts. Get the upgraded solenoids like the previous dude stated and youll be good to roll man
2007 5.9 modded with some parts from the dollar store
SmokenAce86 is offline   Reply With Quote
Old 06-06-2012, 01:16 AM   #12 (permalink)
thanks for the advise i will try that
