| 3rd Gen. Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
Tone Ring Mod
Hello All, I am planning on doing the tone ring mod this weekend and have a few questions for those who have done it. I have read many posts but still am unsure exactly how much to file and move the ring, or how much to retorque the pulley bolts. Thanks
04.5 SLT Quad Cab 4x4 HD, Transgo Kit, Air Raid Torque Tube, Amsoil Nano Fiber with CAI, Muffler delete, Ride Rite Air Bags, Putnam XDR hitch, EGT, Boost and Tranny gauges, DIY Grid heater delete, Banks Six Gun. Last edited by az04cummins : 02-13-2008 at 08:46 AM. |
#3 (permalink) |
zbollman, At the bottom half of this page will give you and idea of what he's talking about: Performance items
2006 Ram 2500 Big Horn Edition Auto 5.9L Mineral Gray Met. Quad Cab SB 4X4 SRW 3.73's |
#4 (permalink) |
Super Administrator
From what I understand, not much needs to be taken out of the pin hole, the slop in the bolt holes is what will limit the amount you can turn the ring. I believe the torgue is 30ftlbs + 60*.
![]() 03-3500, DRW, QC, 4x4, DTT Trans, Mag-Hytec, R700 BD Twins, BD IC Boots, BD Billet Flexplate, Lockup Switch, SMARTY TNT-R BETA/TS MP-8, Eliminator Fuel System, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. Old #'s (R/T .021, 60' 1.76, 1/4 ET 13.14 @ 100.45 mph) |
#5 (permalink) | |
04.5 SLT Quad Cab 4x4 HD, Transgo Kit, Air Raid Torque Tube, Amsoil Nano Fiber with CAI, Muffler delete, Ride Rite Air Bags, Putnam XDR hitch, EGT, Boost and Tranny gauges, DIY Grid heater delete, Banks Six Gun. Last edited by az04cummins : 02-13-2008 at 11:06 AM. |
#6 (permalink) |
I just ground down the 4 bolts holes (counterclock wise) not quite 1/4" total. Then when you mount it back on, you should be able to turn it (CW) that far before tightening the bolts. I don't know if there is any true way to figure out the total amount of degrees but I have heard about 2*. Almost the same as the RokkTech sensor. But that sensor is calibrated for 2* if you go the complete way. I actually have done both on my truck. I did notice a difference with the Tone Ring Mod, and since it was free. Figure it is easy to test once completed. It helps to remove the 2 bottom raditor bolts so you can squish the bottom of it in a little to give more room for your hands. Then pull the serp belt, loosen up the 4 bolts to the pulley. Turn all the way, tighten back down. put belt back on and go for a ride. I have done the adjustment on the side of the road while testing.
Scott 2005 2500, Auto, TC lockup switch, RokkTech sensor, RokkTech muffler, Gutted chrome torque tube, Ram Snorkel on air box, Mopar cold weather kit. Pro Comp Extreme A/T 35's. |
#7 (permalink) |
I did the TRM on my 03. I drilled and filed the dowel pin hole until the bolts would hit and I advanced it as far as I could. It made a big difference on that 03 SO in off the line power and in mileage. I put a Rokktech on my 07 and although there is no power difference I can feel, I got a 1 mpg gain. As far as torque on the crank bolts......... I used a long handled 1/2" drive ratchet and 3lb hammer to get the bolts loose and that's what I used to "Torque" them back on. Just remember to spin the ring the right way. Many people, but not me, while laying upside down under the truck have spun it backwards and retarded it and then wondered why power was down. I didn't do that though. Not me.........
08 Ram 2500 Mega 4x4,68RE,6.7,Loaded Laramie,SRT10 hood,Sunroof,DVD,Nitto 285s,Polished Alloys,Fogzilla,Rear Spoiler,MOPAR Grill Guard,Rokktech,H&S StageII,AFE Drop-In How do YOU spell relief? D.E.L.E.T.E. |
#8 (permalink) |
Need More $ For HP
So this advances the timing?, what if you have a chip/programer that does timing is it safe to do both?.
06 slt, 4x4, qc, sb, g56, smarty TNT/mp8, di pricol gauges, sbc 3600 dd, fluidampr, s&b cai, cfm+, 5" tb exhaust into 6" aussies, eliminator fuel system, arson II cp3 kit, rail cap, II edm transfer tubes, top gun customz leveling kit, hurst shift handle and roll control, ss bed rails, custom led light bar, truck nutz, and a lot more on the wish list dynos 504hp and 1180tqCUMMINS GUYS KEEP IT STRAIGHT, THE OTHERS SWING BOTH WAYS |
#9 (permalink) | |
Super Administrator
#10 (permalink) |
Thanks
Thanks for all the replies... I am thinkin about doing it tonight, it sounds like it does not take that long.
04.5 SLT Quad Cab 4x4 HD, Transgo Kit, Air Raid Torque Tube, Amsoil Nano Fiber with CAI, Muffler delete, Ride Rite Air Bags, Putnam XDR hitch, EGT, Boost and Tranny gauges, DIY Grid heater delete, Banks Six Gun. |
#11 (permalink) |
what exactly is this? im confused
2003 2500 SWB 2wd, Leveled, Smarty Revo, Cool Tube, Silencer Ring & Heater Grid MIA, Train Horns(thanks to the gf), dual 6" mitors w/magnaflow,Cobra 29 w/K40, Blue LED Dash and Floor Lights, Recon Big Rig Lights, Prodigy, H2s.
