VP Max Additional Fuel Filter Install & Leaky Fittings - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 02-05-2012, 10:47 PM Thread Starter
Mallardman007's Avatar
Posted this at the end of one of the on-going threads but thought I might post it again in its own thread..
Installed my VP Max system today and can't seem to get the fittings to stop leaking (all of them)...
First tried them not Super tight, that didn't work so I tightened them just about as tight as I could and they are still leaking. Do I need to put thread sealant on all of them? If so, what do I need to use? Would standard teflon tape work or should I use the Permatex #59214 High Temp Thread Sealant I used on the fittings I installed in the base?
Thanks!!
05 QCLB Laramie, NV5600, 4x4, 4.10's, SRW, EV2 Pyro, Boost & Fuel Pressure, Smarty Jr, Transfer Flow 74gal Fuel Cell, Aero 4040XL, VP MAX, 2" HBS Level, Thuren Adj. Track Bar, Bilstein, Ride Rites, '10 Laramie Wheels w/ 285/75 Trail Graps, CD Steering Brace
Mallardman007 is offline
post #2 of 9 (permalink) Old 02-05-2012, 10:52 PM
Teflon tape will work just fine. That permatex stuff is pretty slick though
98 12 valve qclb. 0 plate, 5" exhaust, 60# springs, 4kgsk, 0 plate, arp head studs, bhaf, 37's, 3" leveling kit, ford knuckle swap
metchosin joe is offline
post #3 of 9 (permalink) Old 02-06-2012, 08:37 AM
papaduck's Avatar
Be sure to use the yellow teflon tape, it is to used with hydrocarbons.
I had to use the tape on some of my fittings. I left 1 to 2 threads uncovered at the leading edge to make sure that some of the tape did not get cut loose and enter the fuel system.
03 Dodge 3500 SLT, HO, 6 spd, 4x4, SRW, quad cab, gauge on lift pump-boost-EGT-engine oil pressure and rail pressure, FASS 95, water seperator and 2m filter, steering box brace, 6.7L fluid damper
papaduck is offline
post #4 of 9 (permalink) Old 02-06-2012, 11:01 AM Thread Starter
Thanks for the replies! Are there different variations of the yellow teflon tape? I see there is some yellow that says for natural gas, and other yellow that says that it is good for oil and chemicals... are they the same?
Thanks again
post #5 of 9 (permalink) Old 02-07-2012, 08:44 AM
papaduck's Avatar
They are the same.
papaduck is offline
post #6 of 9 (permalink) Old 02-07-2012, 09:01 AM
I installed the Vulcan Performance kit and do not have a single leak. The 4 fittings provided have rubber o-rings and washers that seal. The fittings are designed to not leak if installed properly. IMO, I would 100% not want to chance getting any foreign matter in my CP3. I would call Vulcan Performance for technical help. Maybe you got the wrong oil filter base or wrong fittings if it does not seal as designed.
Just my opinion as mine worked perfectly and I cannot imagine how yours is leaking unless you have the wrong fittings for the base.
2004.0 Dodge Ram 2500,Stock 5.9L Diesel H.O. 305HP/555lb.ft ,6-speed NV5600,South Bend Dual Disk clutch,2WD,2" front level, Frantz oil bypass,Cat 1R-0479 fuel filter,Baldwin BF1212 filter,Smarty S06,revo tune,Issopro FP,ETG,Boost gauges,boost elbow set to 32PSI
Jbremount is offline
post #7 of 9 (permalink) Old 02-07-2012, 11:35 AM Thread Starter
I called Vulcan yesterday and Eric said that this was very uncommon and since I only used one wrench to install the 90's rather than 2 (one on the male side and one on the 90) that maybe I didnt get the 90 tight enough to seal properly. I am confident this is user error, not the products so I am hoping to get to it today and tighten them up...
Thanks for suggestions.
post #8 of 9 (permalink) Old 02-07-2012, 07:26 PM Thread Starter
Took the fittings apart and reinstalled with no leaks! No teflon tape needed! Thanks again!
post #9 of 9 (permalink) Old 02-07-2012, 09:36 PM
Good Deal!
