cracked flexplate - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 01-23-2012, 12:58 AM Thread Starter
cracked flexplate
well i noticed a wierd sound coming from under the hood sounded like a bird chirping when driving down the road a couple of days ago and had looked at it then and couldnt find anything till today when i started it to go to town it sounded like a bad pully. ended up taking the truck to my work and checking it out there took the bottom cover off of the trans and for dumb reason i took my fingers and grabed the flexplate and it moved back and forth. took me and a buddie not quite 2hr's to get the transmission out.. the flex plate was cracked all the way around. so what kinda flex plate should i get. a aftermarket one or just get another stock one? have alot of people had this prob? oh and found out also today the old owner that had the truck had a new short block put in at a 100,000 miles and i have 128,000 on it now
06 ccsb cummins just a smart jr, single disk billet tq beefed up clutch pack and custom shift kit, turbo silincer removed, 4in straight pipe
06whitecummins is offline
post #2 of 11 (permalink) Old 01-23-2012, 07:47 AM
sotyphoon415's Avatar
Are you planning on modding your truck any more? Looks like your basically stock still from your sig. Any HP goals in mind?
'07 5.9, EFILive, HTT 64/71/13ss, Stainless Diesel 2nd gen, T&C 60% CP3, Devils Own, ARP 625s, TRE Trans, OPIE Shafts, AD II 165, GDP, One Peace Mopar Drive Shaft, HBS 2", 20's w/34's, Mystery Switch, ISSPRO...
sotyphoon415 is offline
post #3 of 11 (permalink) Old 01-23-2012, 07:54 AM
Pierson's Avatar
iTrader Score: 8 reviews
If you want a stock one I have one with 35K miles on it, If you pay the shipping you can have it. However Id recommend a billet flywheel. If you want it PM me.
06 Mega DRW
07.5 QCLB DRW G56
02 LB7 Dmax
Pierson is offline
post #4 of 11 (permalink) Old 01-23-2012, 08:50 AM
DO you tow heavy? Stock TC?
post #5 of 11 (permalink) Old 01-23-2012, 03:22 PM
FireMedic427's Avatar
This same thing happened to me and I went back to a stock one just because of price at the time. If I had to do it again I would put in a Billet one just for piece of mind. I will say that the stock one I put back in has worked great for the last 40K since I put it in. Basically it is up to you on what you want to do. Good luck
2007 Dodge Crew Cab 5.9 liter 48RE Black Dually.Looking to upgrade to pillar gauges, smarty, intake, and muffler delete pipe.
ACDC
Stay Safe, Stay Low
FireMedic427 is offline
post #6 of 11 (permalink) Old 01-23-2012, 07:39 PM Thread Starter
the only other mods i wanna do to the truck is a cold air intake, exhaust and 35 inch tires. i usually pull something around 4-5 times a month usually weighting over 8 thousand pounds. and it has a stock tc..
post #7 of 11 (permalink) Old 01-23-2012, 10:09 PM
MIKEHKS's Avatar
ill give you one for free if you like , just pay for shipping to help out a fellow member , i have no need for it
2003 drw qc 2wd auto,TD flashed to PPE +DR.performance stage IV,fass 150 ,K&N,ATS ARC FLOW,performance muffler,4 isspro gauges ,ats 2gen t4 manifold , top mounted vgt , built trans,3:42 gears ,,,,
MIKEHKS is offline
post #8 of 11 (permalink) Old 01-24-2012, 12:23 AM
I also have a bunch on stock one I could give you one, if you want a Billet one I can make you a deal on one of those as well.
DTT SALES & TECH is offline
post #9 of 11 (permalink) Old 01-24-2012, 03:57 AM
TECH SPECIALIST
steelhead01's Avatar
be sure to put in new quality US made grade 8 bolts and use the red permanent threadlocker on them. lots of imported pot metal bolts out there. full line major bolt jobber is the place to go.
make sure your torque converter is not starting to fail, lock and grab on coast down, throws a hell of a shock load on the stock FP.
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
post #10 of 11 (permalink) Old 01-24-2012, 01:15 PM
RICK0718's Avatar
I replaced mine 2 years ago with a "heavy duty" flexplate, after i cracked the stock one, cracked the heavy duty one last week. This time I spent the money on the Billet.
RICK0718 is offline
post #11 of 11 (permalink) Old 01-31-2012, 10:26 PM Thread Starter
i got a free one from one of my buddies friends. but thanks for all the offers guys really apperciate it but now my torque converter out on me when i was pulling a friends f350 with a 6.0 in it home after the oiler cooler craped out on him.. truck threw the p1740 code and when your going 65 the torque is locked in and when u ease into the tiny pedal to get up to like 70-72 its locked for a little bit then unlocks wich it never did that before
