Help please engine derated - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 01-21-2012, 03:56 PM Thread Starter
S415bmxer's Avatar
I have a dodge 2005 5.9 I had a 2906 code no voltage
Drop from intake heater I took all apart cleaned all
Connections and now that went away and now #1 intake heater no voltage and the heater lights on and it deratedI the engine I just got a smarty I don't think that has anything to do with it please help idk if I need the soliniods or a new heater I don't have a blok heter cord yet getting it next week I also have another question when it ran good I have 2 stacks is it normal for it to crack after 2000 rpms when ur on it hard
S415bmxer is offline
post #2 of 19 (permalink) Old 01-25-2012, 05:59 PM Thread Starter
S415bmxer's Avatar
Replaced alternator and cleaned grounds on motor someone please help
post #3 of 19 (permalink) Old 01-25-2012, 06:50 PM
rgaskell's Avatar
Now that you have a new alt you can rule that out. But the truck should still run without the heaters on it. What's the Smarty set at? Oh and the exhaust noise is probably related to the fueling upgrade to.
2016 3500 Asisn Megacab Stock for now
rgaskell is offline
post #4 of 19 (permalink) Old 01-25-2012, 07:09 PM Thread Starter
S415bmxer's Avatar
I hit on setting 3 it dosnt matter were I put it even stock the light always comes back on I'm down to the relays and the map and air intake temp but I think it has to be working cause when I first start the truck u can see the lights dim back and forth from it cycling on and off it won't come on till I get over half throttle if I babbyy it it won't come on for a lil longer then when I go balls to the wall please help I'm
Sick of driving with half power I keep resetting the ECM
With the smarty the take it away but it comes right back I was at the dealer last week and he never seen anything like that
post #5 of 19 (permalink) Old 04-11-2012, 10:01 AM Thread Starter
S415bmxer's Avatar
So now I replaced IAT sensor and air filter thought it worked but it didn't idk what to do when I turn the key on its over 60 degrees on the meter the grid heater light comes on and I hear I crack thats the grid heater working right or is it broken?? Also the light comes on if I go over 75 when the motor is at full temp not like the trucks fully warm it happens right befor the thermostat kicks in I'm a diseil mechanic for 6 years this thing is killing me I'm wondering if I should buy a new computer I'd rather do that then injectors
post #6 of 19 (permalink) Old 04-11-2012, 10:07 AM
Master of Mayhem NASFIG
rpage's Avatar
did you check your * cables for corrosion and any chaffing of the wire harnes by the altenator?
Really don't give a rat's App**
rpage is offline
post #7 of 19 (permalink) Old 04-11-2012, 10:25 AM Thread Starter
S415bmxer's Avatar
I cleaned all grounds and conections but look what I just found this means dodge has admitted there is e ECM program problem I'm wana go to the dealer to get my truck up to date this program just came out but from what I understood that what a smarty dose too it updates the trucks software so dose that means this won't fix my problem Don't feel like paying the dealer to do something I already did also I have the ittch program at work there talking about If I get the file I could do it myself please helppp
NUMBER: 18-006-12
GROUP: Vehicle Performance
DATE: February 04, 2012
THIS BULLETIN SUPERSEDES SERVICE BULLETIN 18-011-11 REV. B., DATED JULY
1, 2011, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE
HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE ADDITIONAL OVERVIEW AND
DIAGNOSTIC INFORMATION.
HELP USING THE wiTECH DIAGNOSTIC APPLICATION FOR FLASHING AN ECU IS
AVAILABLE BY SELECTING “HELP” THEN “HELP CONTENTS” AT THE TOP OF
THE wiTECH DIAGNOSTIC APPLICATION WINDOW.
THE wiTECH SOFTWARE LEVEL MUST BE AT RELEASE 12.02 OR HIGHER TO
PERFORM THIS PROCEDURE.
THE DRBIII® FLASH FILES FOR THIS BULLETIN ARE AVAILABLE ON
DealerCONNECT.
SUBJECT:
Flash: Diagnostic Enhancements For Fuel System
OVERVIEW:
This bulletin provides Engine Control Module (ECM) software enhancements to improve
robustness to fuel system issue detection and two new Diagnostic Trouble Codes (DTC's).
This bulletin involves selectively erasing and reprogramming the Engine Control Module
(ECM) with new software.
Diagnostic procedures for these new DTC's are included in this Service Bulletin on the last
2 pages which may be printed.
The two new injector Diagnostic Trouble Codes (DTC's) for excessive injector return flow
are:
· P1222 - LEAK DETECTION DURING MOTORING
· P1223 - LEAK DETECTION BASED ON QUANTITY BALANCE
**When the fault(s) occur, a solid Wait to Start lamp will illuminate in the cluster along with
chiming 10 times. When the fault goes inactive, it will clear the wait to start lamp with no
chimes**.
post #8 of 19 (permalink) Old 04-11-2012, 08:07 PM
TECH SPECIALIST
steelhead01's Avatar
did the "problem" start after you used the Smarty?
if so, contact Smarty, believe there are user reports similar to your problem
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
post #9 of 19 (permalink) Old 04-11-2012, 09:52 PM
macko300exc's Avatar
Are both grid heaters getting power and ground, are both relays working?
macko300exc is offline
post #10 of 19 (permalink) Old 04-12-2012, 12:37 AM Thread Starter
S415bmxer's Avatar
I think I may have fixed the problem me putting a new air cleaner on and putting a new IAT sensor I havnt seen the light all day but I'm not saying its fixed yet I sure hope so tho I'm gana keep driving if you don't hear back it worked
post #11 of 19 (permalink) Old 04-13-2012, 09:22 AM Thread Starter
S415bmxer's Avatar
Now It came On back dated smarty did good for 2 days this morning I was on it hard and it was blowing white and black smoke out now I have some noise coming from the valve train it's due for a valve adjustment but is it the valves or the injectors dose it at idle and light throttle but when on it hard it gose away comes back when u let off can't hear it much once it gets warmed up also seen guys saying power service additive cause problems is that true
post #12 of 19 (permalink) Old 04-13-2012, 09:38 AM
I run Power Service every tank and it keeps my rig running smooth and quieter and I have never read or heard any negative feed back about Diesel Kleen....
2007 MegaCab Black/48RE/3:73/6''Superlift/20'' KMC MONSTER Wheels/325/60R20 Nitto Terra Grappler/BaldwinFW/RaptorRP150/Cat2mic/BaldwinPF7977/Smarty S-06 POD/IssproEV2/Jacobs Ex BRK/5"Flo-Pro TBE
Dieselus Maximus is offline
The Following User Says Thank You to Dieselus Maximus For This Useful Post:
S415bmxer (04-13-2012)
