amp draw on intake manifold air heater? - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 01-20-2012, 11:32 PM Thread Starter
stimpe's Avatar
just wondering if anyone knows what each grid on the intake manifold air heater is supposed to be drawing.. I got about .5 ohms resistance on each grid, the math says about 25 amps for each x 2 grid heaters = 50amps total?
can anyone confirm these numbers?
(a wiring schematic would be a bonus!)
2003 5.9 2500 / Auto / AFE intake / 4"lift / Magnaflow 4" /
stimpe is offline
post #2 of 13 (permalink) Old 01-20-2012, 11:54 PM
waywardtravel's Avatar
The manual says approx 95 amps from each cable.
Here it is.
OPERATION
The air heater elements are used to heat incoming
air to the intake manifold. This is done to help
engine starting and improve driveability with cool or
cold outside temperatures.
Electrical supply for the 2 air heater elements is
controlled by the Engine Control Module (ECM)
through the 2 air heater relays. Refer to Intake Manifold
Air Heater Relays for more information.
Two heavy-duty cables connect the 2 air heater elements
to the 2 air heater relays. Each of these cables
will supply approximately 95 amps at 12 volts to an
individual heating element within the heater block
assembly.
Refer to the Powertrain Diagnostic Procedures
manual for electrical operation and complete description
of the intake heaters, including pre-heat and
post-heat cycles.
04.5,QCSB, Goerend full billet, 4:10's, MPI 63/475,Engineered diesel 63, Exergy 40%'s,Dual CP3's, gauges, Airdog 2 165, S-06 TNT R and Gordon's UDC,edge JWA CTS, Top Gun Customz 3 1/2", Carli BJ's, BIG steering box, 5100's, Helo 791's with 35's.
When all's said and done there's usually a whole lot more said than there is done.
waywardtravel is offline
post #3 of 13 (permalink) Old 01-21-2012, 09:09 AM Thread Starter
stimpe's Avatar
Here it is.
OPERATION
assembly.
post-heat cycles.
higher draw then i thought..thanks for the info. I think my relays are shot
stimpe is offline
post #4 of 13 (permalink) Old 01-21-2012, 09:37 AM
not your relays, there is a fuse link between the + side of the battery and the relays. it is not very easy to spot because it looks like insulation on the wire. just short across the top of one of the relays, if you get lots of sparks the fuse is good. the motor does not need to be turned on to do the test. you do not need the heaters, if the fuse is bad just do not wait to start and it will not throw a code.
063500dually4X4qcg56,dynatrac,bd exhaust brake,donaldson m090535muffler,cfm+,winspeed spacer,smartyjr,taylor wings,luberfiner bypass filter,psm cold air,cool hose,tag,air tab's,pdr cam,ddp50hp injectors,htt 62 65 13ss,ss manifold, turbo and manifold blankets
carl48 is offline
post #5 of 13 (permalink) Old 01-21-2012, 11:08 AM
TECH SPECIALIST
steelhead01's Avatar
actually do need the heater with ambient air temps below -10d F.
speeds up engine start, warm up and cly/piston/ring raw diesel washdown at extreme cold temps.
the Dodge ECM on the Cummins overfuels badly at temps below -10d F, too much condensed cold air with rich oxy mix that the intake air temp sensor and ECM can't calculate. worst at cold idle and cold run.
guys in Minnesota, N. Canada and Alaska can give you examples
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
post #6 of 13 (permalink) Old 01-21-2012, 06:50 PM Thread Starter
stimpe's Avatar
im in northern canada, last week it was -48 Celcius. the heaters are a must as steelhead01 said.
the reason i say it is my relays are:
battery to relay : 12v
when ignition is on wait to start is engaged, ecm sends power to engage the relay (tested the posts from ecm - have power). at this point that relay should engage and i should see that 12v on both sides of the relay, which i don't
stimpe is offline
post #7 of 13 (permalink) Old 01-21-2012, 11:01 PM
TECH SPECIALIST
probably relay solenoid coil ground.
manual 03
http://www.wedophones.com/Manuals/Do...M%20Manual.pdf
so ya must have been duck hunting in Iraq or Afghan? loved my Thumper 79 and canister rounds
post #8 of 13 (permalink) Old 01-23-2012, 10:53 PM
nick9004's Avatar
Just thought I'd put in my $0.02. Tested my intake heaters. Found they pulled 125 Amps each.
2003 3500 SRW, 4x4, Auto - 5" Skyjacker, Bilstien 5100, Goodyear Duratracs -Magnaflow 4" Turbo Back, Banks Six-Gun w/Speed Loader, Compustar Pro Remote Start/Security, Isspro EV2 Gauges, Mopar Steering Box/Linkage Upgrade, Custom 2mic Filter Setup
nick9004 is offline
post #9 of 13 (permalink) Old 01-23-2012, 11:16 PM Thread Starter
stimpe's Avatar
right on thanks for the info. out of curiosity did you measure the draw from just the heaters or is that total truck draw?
stimpe is offline
post #10 of 13 (permalink) Old 01-23-2012, 11:17 PM
Yeah I figured they are about 100 amps each, of course resistive loads have larger tolerances.
'03 2500 QCLB 4x4 47RE One Piece Driveshaft
superman279 is offline
post #11 of 13 (permalink) Old 01-23-2012, 11:58 PM
nick9004's Avatar
That's on each heater positive cable coming off the pass. side bat. measured between the bat and heater sol.
nick9004 is offline
post #12 of 13 (permalink) Old 01-09-2013, 01:35 AM
Anyone ever see one of these relays remain closed and drain your battery? I think this happened to me earlier this week. I cleaned the terminals and reacharded the batteries, and everything seemed fine - just odd that the batt drained on me.
2006 Dodge 2500 5.9 L Bone Stock
2006 VW Jetta Diesel
1990 Volvo Penta 2-cyl marine diesel
robrichtx is offline
The Following User Says Thank You to robrichtx For This Useful Post:
chatttn (01-24-2015)
