| 3rd Gen. Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
#13 (permalink) |
Mine used to do this too! However, it no longer does it. It started after I put on the level kit and I noticed it when pulling my ski boat around 65-70 mph. I was told by someone here on the site that it was possibly the carrier bearing. I did not notice it happening the last time pulled the boat around.
'07 2500 5.9L Mega, Black, Laramie, 4X4, 48re Isspro's, AFE Pro Dry, BMK-11, Edge EZ, Smarty JR.422HP/854TQ IAFF Local 1159
#14 (permalink) |
Yeah, Mine is now gone. I was driving it yesterday around 65 it started shaking really bad. I had snow packed in the rims. I took it to discount tire to get them balanced and rotated (it needed it). They did the balance and rotate, and told me they were all off a little, but one of the back ones (now on front) was off by 5 oz. Since the balance and rotate, driveline vibration gone. I didn't think that a wheel unbalanced would only do that in a 55-65 mph range. I thought that it would do it all the time. Who knew
04.5 ctd cc, auto, 4x4, 2" leveling kit, Quad Commander, Walbro 392 Custom, Smarty Programmer SW3, Afe torque tube, EAAU 4090 air filter, All lubes synthetic amsoil, Muffler gone, Nasta s.s. nerf bars, Access Tonneau Cover, More to come,
#15 (permalink) |
We used to screw around with eachother by putting large wads of duct tape, taped to the inside sidewall of the tire, resulting in a lot more vibration than what you'd think. By the way, I got the new driveshaft installed with the new u-joints and all my vibrations are gone. Not exactly sure I bent the driveshaft...
#17 (permalink) | |
It has a bad vibration around 1700 RPM, with the TC locked up. Just resonates through the whole truck Looks like there's plenty of things that could cause it.
2007 2500 4x4 Big Horn Quad cab / long bed 5.9L / 4-speed auto |
#18 (permalink) |
had a prob like that in my 91 gm...had driveshaft of earlyer...figured ld rotate it 180 degrees and see if that helped...it did help but had noticed that one of my bearing caps in the ujoint hadnt seated quite right...anyway sorted it out..food for thought if youve had the driveshaft off.. lifted truck or larger tires...carrier useualy gos if adjustments werent made with lift ect
2007 Cab+Chassis 6.7/4x4 1997 gmc sle 5.7/4x4 stock 91GM 4x4 5.7 @ 40 over, Westers,Eld 3704.Extreme 50 mm TBI, 65lb injectors,Lunati 60100 Voodoo cam, Trickflow 195's @1.6 RR,Hooker ,overbuilt 700r4 @1800 TCS TC,4.10/tru trac, |
#19 (permalink) |
this is kind of off topic but i managed to bend my front drive shaft and it was a pretty bad shake at 120km after i got it fixed it was gone
My 01 ctd 6spd SLT laramie /MBRP tb 4" /285/16 BF a/t's /Granitelli motorsports chip FOR SALE Dads 02 ctd 6spd /Holley blue/ boost elbow/ TB4"/Quadzilla Chip |
#20 (permalink) |
I don't mean to highjack your thread, but my truck just started to do something similar. Mike runs smooth as silk below 70mph. But at 70 the rear starts to vibrate. The best way to describe it is an "audible vibration" or a rumble. I can change in tone and intensity by accelrating on decelerating. Holding a very constant throttle, the vibration desscrease quite a bit. I pulled my driveshaft and the U joints have no play and are not seazed. Other ideas?
05 Dodge 2500 CTD, 4" Superlift, 325/60R20 Nitto Terra Grapplers, Divino Wheels, Bushwacker flares, Flowmaster exhaust, Smarty Jr., Remote start, power rear slider. |
#21 (permalink) |
Mine was doing the same thing. Mine wasn't very audible, but it was at 60-70 mph. Anything above and below that it would smooth out. I have heard of people removing the drive shaft and drive in 4wd to see if it still happens. That way you would be able to tell if it is anything in that area. That was my next move after having the tires balanced and rotated.
#23 (permalink) |
Mine was a tire out of spec by 5 oz. I didn't have to remove the drive shaft. One of my buddy's had the exact same thing happen to him as well. I never thought a tire out of balance would cause vibration at certian speeds. It was only $42.00 to have them balanced and rotated, so it was a cheap investment.
#24 (permalink) |
U joint prolly
2004 Dodge 3500 Laramie SRW,Quad Cab,Fully Loaded ,Leather ,6Speed,Infinity Sound System,Rhino Liner, 305/70 Buckshot Mudders, Muffler M.I.A. and 5" tip DODGE MAKES IT CUMMINS SHAKES IT
