testing Injectors......Fuel line cap - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 01-12-2012, 05:54 PM Thread Starter
so i want to stop the flow of fuel to my injectors one at a time for testing purposes, its my understanding that i can do this by blocking the fuel lines one at a time off the common rail, I understand this is very high pressure and dangerous.
i do not have a spare CR or fuel lines to use as donors, was hoping somone knew what thread that was comming off the CR, or a method of capping it, I do have a nearby hydraulic store, hoping i could find something there.
If not , can i remove one wire at a time from each injector, w/o killing myself, I know a dealer can cut one injector out at a time, but im hours away form anyone with that capability
any thoughts?
2003 5.9, built 48RE, 4" Banks Exhaust, BD lift pump, GlowShift 3 in 1 gauge, leveling kit, 34s, Ballistic locking hub conversion. New Bosch Injectors (stock), Smarty S06
b2krawler is offline
post #2 of 7 (permalink) Old 01-12-2012, 07:24 PM
There is a cap, its a miller tool. Search the forum, there is the part # listed somewhere on here. Its a cap just as you would imagine. Maybe the hydraulic shop can make you something that would work, its a real simple idea. Bring them a fuel line and see if they can make something?
'03 2500 QCLB 4x4 47RE One Piece Driveshaft
superman279 is offline
post #3 of 7 (permalink) Old 01-12-2012, 07:46 PM
TECH SPECIALIST
steelhead01's Avatar
https://millerspecialtools.spx.com/D...x?id=735&gid=3
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
post #4 of 7 (permalink) Old 01-12-2012, 09:01 PM
so you cant just pull the electrical wires one at a time?
06 HO,Quad Cab, 4x4,48RE. Straight pipe + resonator. Mini Maxxed. S&B Cold Air. Exergy injectors. 08.5 steering upgrade. Rough country dual stabilizer
220,000 kms
04yamaha is offline
post #5 of 7 (permalink) Old 01-12-2012, 09:08 PM
Sounds like a quick way to throw an injector circuit open code and a check engine light, maybe even limp mode, who knows. Don't do it, but it will technically not allow the circuit to fire. If you wanted to bypass it electrically, get a resistor/potentiometer that has equal ohms to the injector coil and connect that to the leads for the injector, this way the computer will think everything is okay.
EDIT: the point of the tool is to test for a mechanical leak of fuel pressure. Without the cap, the fuel pressure is still lost. The injector firing is not the cause of the loss of pressure.
post #6 of 7 (permalink) Old 01-12-2012, 09:41 PM Thread Starter
if i cap one line at a time the injector will be dry firing, can this cause damage to the injector? would only be running for a few minutes at a time
post #7 of 7 (permalink) Old 01-13-2012, 05:15 AM
TECH SPECIALIST
NO, Cummins tested and approved engine analysis method.
The Following User Says Thank You to steelhead01 For This Useful Post:
b2krawler (01-13-2012)
