Can I drive without front drive shaft? - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 12-27-2011, 11:04 PM Thread Starter
trying to find the cause of grinding and occasional squeal under my truck. Can I remove the front drive shaft to see if the noise stops? I just want to drive long enough to see if it is the cause of the noise.
04.5 QC SB Laramie 4x4, 5.9 HO ISB 325/600 CTD, Auto 48re, 3.73, Raptor 100, Shell Rotella T6 synthetic 5w-40, Nitto Terra Grappler 265/70/17
trajan3 is offline
post #2 of 13 (permalink) Old 12-27-2011, 11:05 PM
Feelings NOT Included!
cumminalong's Avatar
Yes, its no problem at all.
- Garmon Stage 4 Fat Shaft, Trips (FMW 472 over a pair of FMW 467's)
- Garmon High Pressure 68RFE
Shut up and open your wallet! This whoopin' ain't gonna be free!
cumminalong is offline
post #3 of 13 (permalink) Old 12-27-2011, 11:07 PM
mkwelds's Avatar
I do all the time, it gains me 1.5 mpg haha
2004.5 3500 4x4 NV5600, PDR Cam, ARP 425s, industrial injection 60 horse injectors, Raptor 100 fuel pump, DIY 2micron fuel filter system with big line upgrade, HE351 over S475,more brewing
SMARTY S06 and UDC fine tuning all of it
mkwelds is offline
post #4 of 13 (permalink) Old 12-27-2011, 11:11 PM Thread Starter
Thanks guys. Going to remove it in the morning.
trajan3 is offline
post #5 of 13 (permalink) Old 12-29-2011, 02:43 PM
ROCKYTOPCUMMINS's Avatar
Are you serious? You really gain that much?
2001 Dodge 2500/ 4x4/ 6spd ECLB
P-pumped South Bend DD#3850 hydros
AFE Brute Force intake/ Air Dog 150-150
ROCKYTOPCUMMINS is offline
post #6 of 13 (permalink) Old 12-29-2011, 02:45 PM
railer and bailer
elephantrider's Avatar
iTrader Score: 10 reviews
you can drive it like that all day long and twice
on sunday. i took mine out so i could back
trailers up in 4lo with my old 3rd gen.
jason
closet poster
Originally Posted by tco2612 View Post
I would not sell it to you a$$ hole
elephantrider is offline
post #7 of 13 (permalink) Old 12-29-2011, 03:57 PM Thread Starter
Noise is GONE! When I removed the front drive shaft the grind noise that i thought was brake rotors is gone. The squeal that was getting really bad is gone too! I turned the shaft by hand and could not get this to make the noise but now that it is off the truck, the noise is completely gone. Now to find out the best u-joints to replace these. I had these replaced by a shop with precision brand from o'reilly about 60,000 miles ago. Don't want to use same ones again. I will search the forum and see what others are using in this front shaft. Any suggestions?
trajan3 is offline
The Following User Says Thank You to trajan3 For This Useful Post:
Jbreit (11-01-2015)
post #8 of 13 (permalink) Old 12-29-2011, 05:57 PM
papaduck's Avatar
Make sure the cardon joint between the double u-joints has absolutly no play in the centering bearing shaft and bearing. If this joint fails it can cause a lot of damage up to destroying the transfer case. Sometimes this joint cannot but be rebuilt and the shaft must be replaced or a good driveshaft shop can remove the centering bearing shaft and weld a new one on.
03 Dodge 3500 SLT, HO, 6 spd, 4x4, SRW, quad cab, gauge on lift pump-boost-EGT-engine oil pressure and rail pressure, FASS 95, water seperator and 2m filter, steering box brace, 6.7L fluid damper
papaduck is offline
post #9 of 13 (permalink) Old 12-29-2011, 08:51 PM
mkwelds's Avatar
I did haha. Now a factor in that was that the joints where shot so with good joints you might not gain as much when removing the shaft.
60,000 on u joints and u want a different company?? Little tall order there pal these drive shafts spin all the time which is why the joints go out so often on the front. I have precision joints on the rear and front and are good. I do keep spares on the truck too just in case. On a truck this size if your working it at all expect u joints every 50k.
mkwelds is offline
post #10 of 13 (permalink) Old 12-29-2011, 09:02 PM
Got Torque's Avatar
Ha I just did the same thing but opposite, pulled my rear driveshaft and drove around in 4hi to see if the noise was ujoints or transfer case. It was joints
05 2500 NV5600. 700hp---AW Whatever!!! Nobody really cares what I say anyway!!!
Got Torque is offline
post #11 of 13 (permalink) Old 12-29-2011, 10:20 PM
Blowin' smoke !!
wolfeel13's Avatar
Cool
I had that intermediate bearing go out on my front shaft. Ground like hell in FWD. Took it to my dealer and they said its pretty much non servicable. They put in a whole new front drive shaft with U Joints. UNDER WARRRANTY! was at 77K miles. Unbelievable. Good Luck
[/SIGPIC] 06 4x4 Laramie LBQC, Edge Juice w/Attitude, Arson Kit, Airdog 165 , boost fooler, KN, Shade tree CoolAir, DTT intake, heater block delete, ATS exhman, open 4" w/ AERO, 6" lift, Bilsteins, Firestone Bags, PROCOMP Bars,
MagHytek Diff, 37" Cooper STT's, CD Steering brace , Trans by Tony, Warn12K, KC's Lightin' it up, Leer W/ KargoMate rack,"We don't need no stinking badges!!:
GOOD LUCK !!
wolfeel13 is offline
post #12 of 13 (permalink) Old 12-29-2011, 10:26 PM
The cv joint in my front drive shaft exploded on the interstate in Minnesota at 517,901 miles. They could not get a drive shaft for several days.
Had them remove it and converted it to a 2 wheel drive until I got home later in the week.
I had been noticing a noise in 4 wd and had tried to not use it when it suddenly became more noticeable in regular mode before its failure.
I run precision U joints in my truck and only one u joint gives me a problem. The rear one. It usualy dies at 90,000. It made it to 98,000 this time.
All Stock.
Roadmedic is offline
