Leak from front of engine - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 12-26-2011, 01:50 PM Thread Starter
buffcummins87's Avatar
Exclamation Leak from front of engine
hey guys. this morning, as i usually do, i looked under the the truck when i walked out to the garage. this morning, i saw a leak under the front of the engine.
it was too thin to be oil, and too dark to be coolant. its coming from the front passenger side of the engine. if i look up the side of the block between the ac compressor bracket and the block, i can see where it looks like it's leaking. (don't ask me what color it was, i'm color blind, but it looked like a red-brownish lol. on a dirty floor too).
the puddle this morning was about the size of a golf ball.
as always, thanks for the help guys!
'06 2500 QCSB. Browning Edition. Str8 Piped. IceBox. Smarty Jr. REVO, Kore/Carli "custom" lift- 35's. Firepunk Built Trans
OHIOCOALROLLERS
buffcummins87 is offline
post #2 of 14 (permalink) Old 12-26-2011, 02:14 PM
That area is notorious for a water pump leak. The coolant in these trucks is red from the factory. I bet thats your problem. Like 99% sure. Hope that helps!
2007 Inferno Red 5.9 2500 PML cover,Gorilla Juice, autometer Phantom boost, Pyro, Fuel Pressure, GDP 2 micron big line fuel filter Kit with CAT 2 micron.. 6 speed.
Roperteacher is offline
post #3 of 14 (permalink) Old 12-26-2011, 04:56 PM
Moochoff's Avatar
Yep, mine started the exact same way/scenario. about a week later she blew coolant everywhere because I kept putting it off
Mine went at around 70k, Ive heard of them going a lot earlier too
Moved on to smaller toys.
Moochoff is offline
post #4 of 14 (permalink) Old 12-26-2011, 11:06 PM Thread Starter
thanks guys.. hopefully i'll have mine fixed this week. i have around 115k on her right now, so it lasted a little longer than yours moochoff, if that is truely what it is. goin to a dodge expert friend tomorrow
OHIOCOALROLLERS
post #5 of 14 (permalink) Old 12-30-2011, 04:12 PM
Cup of coolant per week
I know...old thread. I have the tell-tale signs of my water pump starting to give way. I have an 04.5 CTD with 170k. The leak is very hard to detect from up top or underneath. Here's a couple pictures (I have to zoom way in to see the leak). Can anyone confirm its from the water pump?
Max Headroom is offline
post #6 of 14 (permalink) Old 12-30-2011, 04:34 PM Thread Starter
hey max, thread isn't to old lol. i haven't fixed mine yet, and its leaking from the same area, just a few drops over night for me.
since i haven't fixed it, i can't tell you 100% that's what mine is; but the fluid is coolant, the guys above have seen the same thing when their pumps have started to leak, and my dodge-expert friend said its the water pump- so i'm 99.99% sure.
OHIOCOALROLLERS
post #7 of 14 (permalink) Old 12-30-2011, 05:53 PM
You sure it isn't the coolant by-pass line that runs between the manifold and the block? The hose shrinks with the cooler weather and you have to tighten the bottom clamp as it runs down the line and onto the housing of the tranny. For whatever reason, there is a short 3 - 4" hose that connects the two lines and the clamps have to be retightened.
Mine did the same thing about 6 weeks ago and a quick tighten and it is all good. Not sure if it is the same area but it may be worth a second look. Sounds like the same area. There are some other threads you can look up that describe this issue.
2006 3500 QCSBSRW Laramie 4x4, Bushwacker SS, XD Hoss, Nitto, MBRP - SOLD!!!!
2010 Acura TL SH-AWD
nismod05 is offline
post #8 of 14 (permalink) Old 12-30-2011, 06:21 PM Thread Starter
positive. i tightened mine once last year and again this year, but the leak is in front dripping off the block by the bracket for the a/c compressor
OHIOCOALROLLERS
post #9 of 14 (permalink) Old 12-30-2011, 07:40 PM
I read the main thread regarding that tube and the problems people have. I checked my truck and found the rubber tube connecting two lines together. I have the spring clips and the tube is not leaking. Both sides of the engine block are dry as a bone. My coolant is leaking from the right front. I can just see a little bit of moisture just below the water pump. See picture and zoom in. I'm only loosing about a cup per week.
post #10 of 14 (permalink) Old 12-31-2011, 02:43 PM
papaduck's Avatar
I noticed that mine was starting to leak. Didn't drive it and got a replacement. After getting it off found the bearings were starting to go. Glad I didn't drive it and have it come apart and loose the belt and most of the coolant that I had changed only a few months before.
03 Dodge 3500 SLT, HO, 6 spd, 4x4, SRW, quad cab, gauge on lift pump-boost-EGT-engine oil pressure and rail pressure, FASS 95, water seperator and 2m filter, steering box brace, 6.7L fluid damper
papaduck is offline
post #11 of 14 (permalink) Old 01-02-2012, 12:00 AM
kowsoc's Avatar
Yep, good advice. Soon as you see the pump starting to seep it's a ticking time bomb. The anti-freeze gets into the water pump bearings and destroys them pretty quickly. I had a slight belt squeak I could hear first start of the day and just assumed it's soon time for a new belt. Two weeks later the pump just started making awfull noise and coolant was raining out.....just lucky I was close to home. Change your waterpump or you may end up with an expensive tow.
Early 04 Laramie, 5.9L, 4" Magnaflow, Bully Dog TD/PMT stack, triple gauge pillar, B&D SBS.
kowsoc is offline
post #12 of 14 (permalink) Old 01-08-2012, 07:58 PM
I changed the water pump
Went to NAPA. They're closed on Sundays. Went to Bennett Auto Parts. They had a Chinese pump. Went to Advanced Discount Auto Parts. The pump looked really cheaply built. Went to Carquest and the salesman pissed me off. The seal in the carquest labeled part was round and didn't fit at all in the pump. Went to Autozone and looked at the Duralast. I bought the Duralast for $51 with a limited lifetime guarantee. Here's my experience.
1) the belt tensioner was unexpectedly sprung pretty tight.
2) working conditions are quite tight.
3) drained and saved the factory red antifreeze (it was really clean)
4) two bolts (used a short 10 mm box end wrench)
5) popped off the old pump in less than an hour.
6) had to remove the upper fan shroud bolt to wriggle the pump out.
7) installation went in just as it came out. Torqued the bolts to 18 ft-lbs
Running good with no leaks yet. Will see tomorrow.
Top view shows the castings are similar. the shaft sticks out a little from the Duralast, but it's not a problem. Duralast pump is made in Mexico
Strange modification to the impeller (above and below). Looks like a slinger. Not sure what to think about that. Note the weep hole in the OEM pump. I definitely didnt like that.
Pulleys are the same size.
Here's the weep hole difference. The OEM weeps onto the deck just below the pump and makes a mess. I hope when the duralast goes, It will drip straight to the ground. And when it goes, I'll have a brand new one from Autozone under warrantee.
