5.9l g56 transmission same as 6.7l g56? - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 12-20-2011, 08:55 AM Thread Starter
1998-12v's Avatar
I'm wondering if the g56 behins the 6.7l is the same as the 5.9l? I found a very badly wrecked 2008 that I may buy to do a 6 speed swap on my 98.
Thanks
1998-2500 quad-cab- long bed. Goerend built auto. Airdog 165, 4" exhaust, afc mods/ tst spring. 3k rpm springs.
1998-12v is offline
post #2 of 6 (permalink) Old 12-20-2011, 05:01 PM
Gear Nerd
TX_Dj's Avatar
Physical dimensions are the same, ratios inside are different (better). You'll have a better overdrive and a little more reasonable 3/4 split with the 6.7L version of the G56, if memory serves.
2007 3500 MC DRW 4x4 5.9L (122k mi)
G56 / SBC SDD3250
aFe Stg 2 / Pusher / GH Delete / FTE 5" TBE
AirDog II DF-165 (P551315/BF1275) / GDP Canister Delete / Bosch 505 - Stock Tips (Replaced @ 112,381 mi)
Autometer / JVC / Polk Audio
Best Tanks: 16.6 towing / 23.92 unloaded hwy / 23.2 city
TX_Dj is offline
post #3 of 6 (permalink) Old 12-20-2011, 09:26 PM
World Champs!!!
MoparProud's Avatar
Yeah, I think it's the 08 and later trans that has the better ratios. Can't remember the code off hand
'07 3500 SRW QC/LB-EFILive w/Silverbullet Tuning-Goerend-WOP triple turbo-200% Exergy-Carli Backcountry
'03 2500 QC/LB. HO/NV-
-HE351v-Southbend-TNT/R
Originally Posted by Common View Post
Why would you buy a Hellcat for road trips?
Originally Posted by MorSmokPls View Post
Because you can
MoparProud is offline
post #4 of 6 (permalink) Old 12-21-2011, 12:05 AM
Chowderhead72's Avatar
Fifth gear is the same on both, the g-56r used in 2008 and later has a .74 6th gear as opposed to the regular g-56 with a .79 6th gear.
05.5 2500 slt 4x4 QCsb g56- Spec ST dd, 6" BDS la, some Carli stuff, Toyo MT 37's, Diprocol/Isspro, Smarty, AMP, Stainless Diesel, Fluidampr, Crazy Carl, FMW62/476 on the way... A bunch of other stuff...
Chowderhead72 is offline
post #5 of 6 (permalink) Old 12-21-2011, 11:22 AM
easymon's Avatar
Make the change best investment i made 1thing you notice is will need to bring rpms up more in 5th to grabe 6th under load. I belive what read most gears have diff. Ratio i know 5th is diff in mine which i like for when real heavy load i can run 5th with lower rpm.
06 dodge 3500 G56 ,EFI,BY Zach Fuller at starlite diesel,tunes by,anachy Les at silver bullet ,valair dd organic,fass 150
2013 Ram Laramie longhorn 342 none assin
easymon is offline
post #6 of 6 (permalink) Old 12-21-2011, 05:49 PM Thread Starter
1998-12v's Avatar
Ok thanks guys that's what I needed to know. I gotta do something with this stock slushbox that's in my truck now.
1998-12v is offline
