2006 -07 crankcase breather - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 10-29-2011, 07:45 AM Thread Starter
07 ThunderRoad's Avatar
Has any one had to replace the valve cover because the breather is not a serviced part? What did you do about the engine ser# tag on the old valve cover?
2007,5.9/2500Laramie,Banks 4" monster exhaust & brake ,EconoMind tuner & Techni-Cooler,Bilstein shocks, Load-Lifter5000 Ultimate,Hellwig HD bar,6.7Viscous VD.
07 ThunderRoad is offline
post #2 of 9 (permalink) Old 10-29-2011, 11:38 PM
Bump! I'd like to known the answer too!
Inferno Red, 2006 Quad Cab Laramie, Short Bed, West Coast, hard tonneau cover, LED Lights all around, Nitto Dune Grapplers on Cruiser Wheels 32" 285/55/20, Banks Six Gun with Banks IQ, Banks Ram Air and Intercooler, AirRaid Air box, MBPR 5" Turbo Back Exhaust with MBPR Performance Muffler.
scotchwhiskey is offline
post #3 of 9 (permalink) Old 10-30-2011, 08:23 AM
airborne.pathfinder's Avatar
Subscribing..
airborne.pathfinder is offline
post #4 of 9 (permalink) Old 10-30-2011, 10:36 AM
Gear Nerd
TX_Dj's Avatar
What makes you think it would need to be replaced? It's not something that fails...
2007 3500 MC DRW 4x4 5.9L (122k mi)
G56 / SBC SDD3250
aFe Stg 2 / Pusher / GH Delete / FTE 5" TBE
AirDog II DF-165 (P551315/BF1275) / GDP Canister Delete / Bosch 505 - Stock Tips (Replaced @ 112,381 mi)
Autometer / JVC / Polk Audio
Best Tanks: 16.6 towing / 23.92 unloaded hwy / 23.2 city
TX_Dj is offline
post #5 of 9 (permalink) Old 10-30-2011, 10:59 AM
just back flush the filter. as long as you do not run a K&N air filter the engine will not produce enough blow by to cause a problem
063500dually4X4qcg56,dynatrac,bd exhaust brake,donaldson m090535muffler,cfm+,winspeed spacer,smartyjr,taylor wings,luberfiner bypass filter,psm cold air,cool hose,tag,air tab's,pdr cam,ddp50hp injectors,htt 62 65 13ss,ss manifold, turbo and manifold blankets
carl48 is offline
The Following User Says Thank You to carl48 For This Useful Post:
scotchwhiskey (10-31-2011)
post #6 of 9 (permalink) Old 10-21-2012, 08:39 PM
WI-cummins's Avatar
just asking....... whats wrong with the K&N ? i have a AFE on mine
2006 2500 sport 5.9L
black QCSB auto 4wd, 5" str8t pipe, AFE CAI
EFI live by ANARCHY DIESEL
WI-cummins is offline
post #7 of 9 (permalink) Old 10-21-2012, 10:59 PM
You can nearly throw a cat through a k&n filter. They do not meet filter requirements. Also oiled filters arnt really the best. The turbo can suck the oil through them
06 HO,Quad Cab, 4x4,48RE. Straight pipe + resonator. Mini Maxxed. S&B Cold Air. Exergy injectors. 08.5 steering upgrade. Rough country dual stabilizer
220,000 kms
04yamaha is offline
The Following User Says Thank You to 04yamaha For This Useful Post:
jmercer (10-22-2012)
post #8 of 9 (permalink) Old 10-21-2012, 11:13 PM
waywardtravel's Avatar
Run some gasoline and it should be as goos as new. Careful with the gasoline and wash it out with soap and water before re-installing.
Geno's garage sells them.
04.5,QCSB, Goerend full billet, 4:10's, MPI 63/475,Engineered diesel 63, Exergy 40%'s,Dual CP3's, gauges, Airdog 2 165, S-06 TNT R and Gordon's UDC,edge JWA CTS, Top Gun Customz 3 1/2", Carli BJ's, BIG steering box, 5100's, Helo 791's with 35's.
When all's said and done there's usually a whole lot more said than there is done.
waywardtravel is offline
post #9 of 9 (permalink) Old 10-22-2012, 12:15 AM
iTrader Score: 13 reviews
CCV on a 5.9 cummins does NOT need to be changed or even serviced..it is ONLY a baffle box to direct oil vapors to back to the block. If it is leaking around the valvew cover, simply replace the o-ring or put some small hose clamps on the hose ends.
CCV on a 6.7 CTD DOES need replacing at service intervals...it is integral to the operation of the EGR. Do to its size and operation, Cummins designed it as part of the valve cover, unlike the small baffle box that attaches to the valve cover on the 5.9.
seafish is offline
