Which Baldwin oil filter? 07 5.9 - Dodge Cummins Diesel Forum
post #1 of 24 (permalink) Old 10-14-2011, 12:10 AM Thread Starter
popup's Avatar
I searched the site and found two Baldwin oil filters for an 07 5.9. Which one of these two performs better and is it worth the price difference. Also what change interval is everybody using. I'm also running Rotella with it
bt7349 or the bd7317
07 Mega 5.9 2wd Banks cat back exahust / K&N intake
popup is offline
post #2 of 24 (permalink) Old 10-14-2011, 08:30 AM
NavyDood's Avatar
bt7349 is a full flow filter
bd7317 is a full flow and bypass all-in-one filter
Here is a great comparison on DTR between the BD7317 and Fleetguard LF9028. The Baldwin is easily inferior to the Fleetguard. Consensus on dual flow oil filters (Baldwin 7317) - Dodge Diesel - Diesel Truck Resource Forums
Retired Navy Chief - Vanilla 04 2500 QCSB, 4x4, 48RE w/MagHytec DD, Smarty Jr, HOG 4" Exh, Modded Air Box, Isspro Gauges, Quadzilla RPG w/fuel pressure, DynaTrac front, Coolant By-Pass Filter - B&W Turnoverball w/Companion 5vr hitch
NavyDood is offline
post #3 of 24 (permalink) Old 10-14-2011, 09:22 AM Thread Starter
popup's Avatar
I thought Baldwin oil filters were supposed to be as good as their fuel ones. So which brand then that doesn't break the bank ? How about the dealer mopar one. Because $45 for a filter is a big ouch
popup is offline
post #4 of 24 (permalink) Old 10-14-2011, 12:21 PM
I use the Doanldson oil filters, get them from the cummin`s shop. I do use the baldwin fuel filters.
06, QC, 4x2, Auto, 373 LS, Quad. XZT, S&B cold air intake, drive train all synthetic. 51" Donaldson. HyTec Diff. cover and Hytec DD trany pan. Firestone airbags. Bilstein shocks.
Fiftygrit is offline
post #5 of 24 (permalink) Old 10-14-2011, 12:23 PM
rufushusky's Avatar
Another good option is the donaldson elf7349...if you google it you will find it online for 13 bucks plus shipping...great value for a 15 micron absolute filter.
2002 Ford F-350 ECLB 7.3 4R100 4X4, 6637 intake, 203* T-stat, 08 diff cover, HPX, Stancor Relay, 6.0 trans cooler
Gone:
04.5 Ram 2500 Reg Cab 48re 205k miles
rufushusky is offline
The Following User Says Thank You to rufushusky For This Useful Post:
Desert Dually (10-15-2011)
post #6 of 24 (permalink) Old 10-14-2011, 09:48 PM
Monkeyman2500's Avatar
Yep Donaldson for oil and Baldwin for fuel. I get them at a local filter wearhouse.
2004.5, QC,4x4, 6spd, HO, Smarty Jr, 07 Stock Alloy Wheels, 295/70/17 Toyo RT, Westin Brushguard, Isspro Gauges, Raptor Step Bars, Trailworthy Fab 20" Light Bar, Maxx Links, Bilstein 5100's, JL Sound
Monkeyman2500 is offline
post #7 of 24 (permalink) Old 10-14-2011, 10:25 PM Thread Starter
popup's Avatar
Is there anywhere locally I can pick up the Donaldsons in Miami, fl. Does napa, grainger or any place like that carry them
popup is offline
post #8 of 24 (permalink) Old 10-14-2011, 11:32 PM
NavyDood's Avatar
This is the best available for the OEM filter locations. Donaldson ELF7349 or Amsoil EaO80 oil filter and Baldwin PF7977 fuel filter.
http://apartsdepot.com/catalog/index...facturers_id=1 is where I get all my filters from.
NavyDood is offline
The Following User Says Thank You to NavyDood For This Useful Post:
post #9 of 24 (permalink) Old 10-15-2011, 08:43 AM
does the donaldson compare the same to the amsoil?
2005 Dodge Ram 3500 SRW 4x4 -2" leveling, 35 Nitto trail grapplers, Heavy Hauler trans, BHAF, Smarty TNT, FBD 5", ADII, Arson III, Flux 2 injectors, BD Killer B
Revolution is offline
post #10 of 24 (permalink) Old 10-15-2011, 09:27 AM
NavyDood's Avatar
Exact same media is inside. Donaldson owns the patent and Amsoil has a manufacturing license with Donaldson to make the media themselves. Donaldson calls it SynTeq and Amsoil calls it NanoFiber.
NavyDood is offline
post #11 of 24 (permalink) Old 10-15-2011, 10:11 AM
rufushusky's Avatar
A truck or heavy equipment store might have them but they might not have the ELF line at every location.
https://dynamic.donaldson.com/webc/W...r/locator.html
basically Donaldson makes Amsoils full flow oil filters.
Gone:
post #12 of 24 (permalink) Old 10-15-2011, 10:12 AM
NavyDood has the right answer.
