03-04 vs 04.5-07 whats the difference - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 10-04-2011, 11:11 PM Thread Starter
tails101's Avatar
Can any one help me, I am trying to figure out what the difference is between the 03-04 cummins common rail and the 04.5-07 cummins common rail.
2005 Ford F-350 66/74-225cc injectors water meth-cross over reg return fuel-coolant filter-Swamps 58v FICM hot tune- SCT X3 with Vivian Tunes, im sure theres more. 667HP-1160TQ
Sitting in garage (05 CR getting built to go into truck.
tails101 is offline
post #2 of 13 (permalink) Old 10-04-2011, 11:23 PM
Master of Mayhem NASFIG
rpage's Avatar
injector spray pattern, piston bowls, std tranny in 05.5. injector firing event went to 3rd in 05 i believe, some cosmetics in 06. valve seats, and some other things. hp torque
Really don't give a rat's App**
rpage is offline
post #3 of 13 (permalink) Old 10-05-2011, 10:19 AM Thread Starter
tails101's Avatar
What do you mean injector firing event
tails101 is offline
post #4 of 13 (permalink) Old 10-05-2011, 10:27 AM
TurboDiesel7's Avatar
A third injection event was introduced to quiet down the truck. It also helped with emissions? Not sure on that.
08 2500 6.7 68rfe 4x4 efi autocal from starlite carli backcountry
TurboDiesel7 is offline
post #5 of 13 (permalink) Old 10-05-2011, 10:32 AM Thread Starter
tails101's Avatar
Oh thanks so can you swap the pistons and injectors from the 04.5-07 to the 03-04
tails101 is offline
post #6 of 13 (permalink) Old 10-05-2011, 10:50 AM Thread Starter
tails101's Avatar
Actually which ones are better the 03-04 or the 04.5-07
tails101 is offline
post #7 of 13 (permalink) Old 10-05-2011, 01:10 PM
03-04 also use a smaller turbo, HE341 as compared to the HE351 on the newer trucks. Easy swap if you can find a good used one
Sent from my Autoguide iPhone app
2003 2500 2wd on 35's, 6spd, Southbend 3250DD, Smarty, II 60's, Fass 95gph, Killer B
BruteRam is offline
post #8 of 13 (permalink) Old 10-05-2011, 04:41 PM
Banned
Early 03 trucks could also be the lower HP rated motors and have a 47RE instead of the later 48RE.
Uncle Ugly is offline
post #9 of 13 (permalink) Old 10-05-2011, 07:22 PM
rpage's Avatar
you have to do both and i believe you also need the ecm.
rpage is offline
post #10 of 13 (permalink) Old 10-05-2011, 08:12 PM Thread Starter
tails101's Avatar
oh ok. Im just trying to figure out which one would be a better engine for power 03-04 or 04.5-07
tails101 is offline
post #11 of 13 (permalink) Old 10-05-2011, 08:41 PM
cerberusiam's Avatar
For just power they are comparable. Both will suffer catastrophic failure if you push them too hard. All things being equal, the piston design on the 03-04 is a bit more conducive to longer life under high HP conditions than the later engines, but, the later engine shave better valves and seats.
The later engines have more power potential but neither will live long at the levels they can be pushed to without mods.
cerberusiam is offline
post #12 of 13 (permalink) Old 10-05-2011, 08:56 PM
edmeyers's Avatar
Early 03 had forged rods as compared to the later motors having powder cast cracked cap rods if your looking to push high hp u need the forged rods the 2 injection events got better fuel milage but other than that I not sure a dropped valve seat weened me of cr trucks forever and I made sure my 24valve had an so head without replace able valve seats before I ported and oringed it
2001 Dodge 3500 4x4 ETH SO pump, 2k over B2 twins, Redline, smarty, isspro, gauges, Full ATS Auto w/controller
1994 Dodge 2500 4X4 Money Pit 390k 302 hp 799 torque. 10 plate, ported and oringed head.
edmeyers is offline
