03 with a bad crankshaft position sensor - Dodge Cummins Diesel Forum
post #1 of 34 (permalink) Old 10-02-2011, 03:18 PM Thread Starter
02Cummins WV's Avatar
I pulled the codes off my new 03 cr n came up with a p0336 which is crankshaft position sensor performance. My truck has been experiencing long cranking starts and it won't start in the morning at all when its cold. So I called my local parts store and they have the same part number for the cam and crankshaft. My question is are the cam and crankshaft sensors the same part? Cause genos has em listed as the same thing also
03 QCSB ~ NV5600 ~ 4.10 rear
E.D. 10mm stroker cp3 ~ carli commuter 2.0 ~ sb dd 3250 w/hydraulics ~ 35s on chrome revolvers
02Cummins WV is offline
post #2 of 34 (permalink) Old 10-02-2011, 04:20 PM
KDeemer's Avatar
Yup same part
Sent from my Autoguide iPhone app
2012 2500, 5" DPE delete, Sinister EGR Delete, H&S Mini Maxx tuned my Dave Matthews
KDeemer is offline
The Following User Says Thank You to KDeemer For This Useful Post:
02Cummins WV (10-03-2011)
post #3 of 34 (permalink) Old 10-02-2011, 04:20 PM
NightMare99's Avatar
yes sir they are the one in the same
99 Sport. BHAF. 4"TB into 7"ss Mitres. BD Sponge. BD Boost Builder. Custom Wastegate Elbow. FASS HD Titanium. ARP Studs. FireRings. ReWorked Head. C.D 100 Stix. ATS Intake. Smoked Lights Allround. Projector Angels. Leveling Kit.
NightMare99 is offline
The Following User Says Thank You to NightMare99 For This Useful Post:
post #4 of 34 (permalink) Old 10-02-2011, 06:13 PM Thread Starter
So where exactly is the crankshaft sensor is it above the starter like I've read in other post... or is the cam and crank the same partand there is only one of them? I'm confused parts store has me all confused sorry guys
post #5 of 34 (permalink) Old 10-02-2011, 07:09 PM Thread Starter
post #6 of 34 (permalink) Old 10-02-2011, 08:03 PM
The crankshaft sensor is mounted at the front of the engine next to the harmonic balancer tone ring.
MikeyB
MikeyB is offline
The Following User Says Thank You to MikeyB For This Useful Post:
post #7 of 34 (permalink) Old 10-02-2011, 09:55 PM Thread Starter
I replaced the cam/crankshaft sensor and so far it has done little to improve my hard start issue. The true test will be tomorrow morning after the truck has sat all night long(past two mornings it wouldn't start). So if this sensor wasn't the problem then I'm gonna check my injectors next to see if one or more of them are leaking back... just sucks I was sure this sensor was the problem since my truck was throwing the p0336 code.... anyone got any suggestions for me ...? Id like to say thank you to everyone who has helped me so far!!!
post #8 of 34 (permalink) Old 10-02-2011, 10:32 PM
check your high pressure relief valve...if its leaky itll bleed off pressure and be hard start
post #9 of 34 (permalink) Old 10-03-2011, 10:51 AM Thread Starter
Is there an actual way to check the relief valve or am I simply looking for it to be wet
post #10 of 34 (permalink) Old 10-03-2011, 11:06 AM
waywardtravel's Avatar
I would read this link to a sticky.
Rough idle and hard start solved...
Did you throw a belt? They often chew up the wiring to the Crank position sensor when they fail.
To check the HPRV remove the banjo fitting and plug the return line with a bolt and some brass washers. Dry out the relief then start it up. It should stay dry in all RPM ranges.
I would also try to re-torque the connector tubes to the injectors before removing them to have them tested. When they are loose they will return fuel causing hard starts.
Lift pump is another common failure causing hard starts. You can open and drain the filter bowl then attach a hose into a large graduated cylinder. Bump the key to activate the pump and measure the amount it pumped. I'll look up the spec.
Do you have any white smoke on startup?
How many miles? You have to be getting close on injector life but I'd check the other stuff first unless you blow white smoke on cold start.
I guess I should add fuel filter.
04.5,QCSB, Goerend full billet, 4:10's, MPI 63/475,Engineered diesel 63, Exergy 40%'s,Dual CP3's, gauges, Airdog 2 165, S-06 TNT R and Gordon's UDC,edge JWA CTS, Top Gun Customz 3 1/2", Carli BJ's, BIG steering box, 5100's, Helo 791's with 35's.
When all's said and done there's usually a whole lot more said than there is done.
waywardtravel is offline
The Following User Says Thank You to waywardtravel For This Useful Post:
post #11 of 34 (permalink) Old 10-03-2011, 11:22 AM
Mr. Vehicle Destroyer
Shibbyutman's Avatar
iTrader Score: 7 reviews
If it was actually getting the 0336 code then it isn't going to be fueling related. It is impossible for a fueling issue to trigger a crankshaft code.
This is most likely a wiring issue with the harness or connector itself.
Back in the common snail game. 03 SO 2wd 480,000 miles and counting.
Parts for sale: Van Aken SmartBox, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. RACEME 07-09 Delete Tuners
Shibbyutman is offline
post #12 of 34 (permalink) Old 10-03-2011, 11:26 AM
I think my logic is WAS getting the code.
