Weird smell, need help. - Dodge Cummins Diesel Forum
post #1 of 25 (permalink) Old 10-01-2011, 01:10 AM Thread Starter
I've searched and searched - I've got an 06 with about 66k on her. I had an oil change about 3 weeks ago, and about a week later started to notice this "smell." I smelled it most potent underneath the wheel well on the driver side after about 5-10 minutes of normal driving. The passenger side stinks, but not that noticeable. Every once and a while I get a whiff of it at the stoplight. I can't tell if its oil, burning plastic, antifreeze...? I did the brakes about 2 months ago, and I pulled them a part again today, and everything looks fine. I changed both batteries last week too (one was bad), which I thought could have been the smell, but it wasn't.
I bought the oil change package from my dealer, and called and asked what kind they are using. They are using penzoil.
Truck is running great, stopping fine, normal temps, etc. Any suggestions???
It's driving me nuts!!!
halligan is offline
post #2 of 25 (permalink) Old 10-01-2011, 01:21 AM
waywardtravel's Avatar
Seriously not to be a smart axx. Have someone else smell it that can differentiate between the smell of oil, burning plastic, antifreeze or brakes. Each has it's own very distinct smell.
04.5,QCSB, Goerend full billet, 4:10's, MPI 63/475,Engineered diesel 63, Exergy 40%'s,Dual CP3's, gauges, Airdog 2 165, S-06 TNT R and Gordon's UDC,edge JWA CTS, Top Gun Customz 3 1/2", Carli BJ's, BIG steering box, 5100's, Helo 791's with 35's.
When all's said and done there's usually a whole lot more said than there is done.
waywardtravel is offline
post #3 of 25 (permalink) Old 10-01-2011, 05:52 AM
TECH SPECIALIST
steelhead01's Avatar
Penzoil doesn't make a CI-4 or CJ-4 diesel engine oil.
Probably Rotella 15w40. Rotella uses a unique polymer viscosity modifier that stinks as the byproducts boil off the oil. Bothers some more than others.
Most dealers use bulk 15w40, what ever bulk dealer bids the cheapest. They sell the Mopar 15w40 at the parts counter, jugged by Valvoline, their Premium Blue
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
post #4 of 25 (permalink) Old 10-01-2011, 09:12 AM
Sounds like Rotella to me as well. The 15-40 has a more potent smell than the 5-40 syn. I really noticed this the first time I used the 15-40, for the first 2-3K any idle time or stop light time and it would make your eyes water. Since switching to the sun, (which I should be using anyway in Mi) it really isn't noticeable. A little right after the oil change but that's about it. Maybe ask to talk to someone at the dealer who can prove were they got the last shipment of oil from.
LJ 452 is offline
post #5 of 25 (permalink) Old 10-01-2011, 02:22 PM
Gear Nerd
TX_Dj's Avatar
My bet.
2007 3500 MC DRW 4x4 5.9L (122k mi)
G56 / SBC SDD3250
aFe Stg 2 / Pusher / GH Delete / FTE 5" TBE
AirDog II DF-165 (P551315/BF1275) / GDP Canister Delete / Bosch 505 - Stock Tips (Replaced @ 112,381 mi)
Autometer / JVC / Polk Audio
Best Tanks: 16.6 towing / 23.92 unloaded hwy / 23.2 city
Last edited by TX_Dj; 10-02-2011 at 12:18 AM. Reason: made pic bigger than a postage stamp
TX_Dj is offline
post #6 of 25 (permalink) Old 10-01-2011, 04:30 PM
Diesel 4 Me!!
21gti's Avatar
If your coolant level is low, check your pass side of the engine block at the rear for a 2.5 inch coolant hose make sure its not leaking. I had a pin hole leak making a smell and that was the problem.
06 2500 QCLB 4x4 Borla exhaust, Airdog2, Carli level kit, Torsion Sway Bar & ball joints, 08.5 Steering , Mopar steering box, S&B filter & Air Ram, Goerend Trans, Pacbrake Airbags, AMP side steps, Edge CT2!
21gti is offline
post #7 of 25 (permalink) Old 10-01-2011, 04:39 PM
Oil from the front axle can smell really bad if the seals leak a little and water gets in. If they changed it and filled it up to proper level with a leaking seal you would have some oil coming out near the U-joint.
post #8 of 25 (permalink) Old 10-01-2011, 07:43 PM Thread Starter
Thanks guys, I'm working on still pin pointing. I'm going to check the front axle.
Coolant level is not low, as of right now. I'm going to keep an eye on it.
Lastly I'll get ahold of the dealer after I have a buddy smell it.
It's completely odd, and straight pissing me off!
halligan is offline
post #9 of 25 (permalink) Old 10-01-2011, 10:57 PM
Shrub's Avatar
I'd bet the farm it's "rosmella". Have the same issue with my truck, no leaks no codes no issues just stinks all the time. Called my dealer who does my changes, sure enough it's bulk 15w40 Rotella.
I don't look busy, because I did it right the first time.
Stock 04.5, QCSB 2500 HO, 48RE, BFG AT's Silencer/Baffles MIA, Autometer Boost, Trans, Pyro
Shrub is offline
post #10 of 25 (permalink) Old 10-02-2011, 12:20 AM
Master of Mayhem NASFIG
rpage's Avatar
if its a coolant smell then its that little hose clamp by the turbo.
Really don't give a rat's App**
rpage is offline
post #11 of 25 (permalink) Old 10-02-2011, 12:22 AM Thread Starter
What's up with the little hose clamp by the turbo?
I let my captain smell it tonight, he said it's definitely coolant.
halligan is offline
post #12 of 25 (permalink) Old 10-02-2011, 12:26 AM
rpage's Avatar
back behind the turboby the firewall theres about a 4 inch hose that is notoriuos for leaking on the 06 and 07
rpage is offline
