Fuel injector supply voltage code - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 09-14-2011, 02:33 PM Thread Starter
BullRhino's Avatar
I have 2004.5 RAM 2500 w/Cummins (of course). Has an Edge EZ chip that came with it from previous owner. Coming back from errand this AM and truck started running terrible and check engine light was on. Checked DTCs and got P2146 "Fuel injector Group 1 supply voltage circuit/open" and P0202 "Fuel injector 2 circuit/open".
Could this be from the chip? I recently filled up and added "Power Source Diesel Kleen + Cetane Boost" to the fuel.
Any suggestions and help would be greatly appreciated.
I am a total amateur at this so If you can help with detailed instructions or where to get detailed instructions including photos it would be wonderful!
2004.5 Ram 2500 SLT Quad Cab, 5.9L Cummins HO Turbo, 4X4, 4 Sp Auto Trans, Stock wheels/tires
BullRhino is offline
post #2 of 3 (permalink) Old 09-14-2011, 07:08 PM Thread Starter
BullRhino's Avatar
I went ahead and disconnected my Edge EZ chip and that seems to have solved it.
post #3 of 3 (permalink) Old 09-15-2011, 12:07 AM
TECH SPECIALIST
steelhead01's Avatar
congratulations,
you are no longer a total amateur.
welcome to the living world of color high powered Cummins diesels.
the horizontal control on the foot pedal works far better than the vertical control
don't waste your hard earned money on the extra Cetane boost stuff, US diesel doesn't need it nor does the Cummins. regular old Power S. Diesel Kleen will serve you well. try some commercial bio diesel now and then to help keep things clean inside. these things make soot and lots of diesel snot inside.
kinda like a woman that doesn't have sex that often, gotta blow her out now and then or things get gummed up and stop working.
fishing was good today
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
