Found my transmission overheating issue.... 48RE running Hot? - Page 5 - Dodge Cummins Diesel Forum
 2Likes
post #49 of 300 (permalink) Old 09-06-2011, 02:58 PM
05BlackLaramie's Avatar
ATS sells replacement thermostats
I have been following this thread as my transmission temperatures get out of control not hauling anything just this past weekend I was up in the mountains with an ATV in the bed and my temps climbed to around 225 degrees. My transmission is stock as far as I know and i'm only running a 60 hp tune via smarty. I was thinking about purchasing one of these from ATS it's a replacement auxiliary cooler thermostat they go for about 69$ Dodge Cooling Systems - ATS Diesel let me know what you guys think.
05BlackLaramie is offline
The Following User Says Thank You to 05BlackLaramie For This Useful Post:
normie321 (08-07-2012)
post #50 of 300 (permalink) Old 09-07-2011, 01:22 AM
CF Chapter President
dieselenthusiast's Avatar
Subscribing……
SOLD - 2006/5.9 Cummins/Big Horn/2500/QCSB/4X4/48RE
2015/3.0 Ecodiesel/Big Horn/1500/QCSB/4x4/8HP70
2016/Travel Trailer/Arctic Fox 22G/LP Cummins Onan Generator/160 Watt Solar Panel
dieselenthusiast is offline
post #51 of 300 (permalink) Old 01-27-2012, 06:18 PM
I am trying this right now and the thermostat popped out a very little bit, like not even enough to grab onto it so what does one do? Heat it up more or try prying it out and just replace the o ring?
tysonmatc2 is offline
post #52 of 300 (permalink) Old 01-27-2012, 08:06 PM
so the purpose of this thermostat is to bypass the coolant when cold and when it gets up to temp it sends it through the cooler?
is this the one way valve thing they are talking about that in the line or is that something else to?
2005 Dodge Ram 3500 SRW 4x4 -2" leveling, 35 Nitto trail grapplers, Heavy Hauler trans, BHAF, Smarty TNT, FBD 5", ADII, Arson III, Flux 2 injectors, BD Killer B
Revolution is offline
post #53 of 300 (permalink) Old 01-27-2012, 10:00 PM
well from looking at it tonight it's to bypass the cooler, there is no coolent in the cooler so it's not like a heat exchanger. It is just a cooler that when the thermostat gets hot enough it opens up letting the tranny fluid run through the the cooler. Mine was very hard to get out and now I an totally screwed as far as putting the thermostat back in, it shot up into the "body" of my truck and into the abyss. I am trying to figure out what I can stick in there to plug it up, was going to put a threaded 3/8" plug in it but there is not enough wall there to tap the threads for anything.
post #54 of 300 (permalink) Old 03-17-2012, 09:22 PM
44newman's Avatar
Originally Posted by joestang350 View Post
Well my idea was, (before I get started this is just an idea, I take no responsibility for what you do to your trucks) I was going to take the thermostat, remove the little rod (will stay left out) and cut about 4 coils off the spring (about 1/2"). Then reinstall the thermostat first into the cooler (in it's normal way, little end first) then install the spring behind it and then the cap like normal. This would make the spring push on the thermostat all the time and close the bypass off alltogether and without the rod installed it could not move anything. I would think this would be fine, all my older cars never had a thermostat in the transmission lines and the coolers worked 24/7, didn't seem like it caused any issues...
This is going to be what I do if I have to "clean" the thermostat again in the future.
I know this is a older thread but it still gets referred to.
A update on this, I did the described above but didnt need to cut any coils off the spring. Seemed to have moderate spring pressure but not a lot.
So thermostat went in 1st, with rod removed, Then spring 2nd, and plug w/ clip, last.
The heat trick really works to get plug out. just keep heating and pushing the plug in, letting it spring out, until it starts to finally come farther out.
TOYOTA ROCK CRAWLER BUILD 95' X-cab 4.3 Vortec, duals, SAS, CUSTOM
2005 2500 Laramie QCSB, S&B Intake, Exhaust,Smarty S-06POD, ATX wheels.
44newman is offline
post #55 of 300 (permalink) Old 05-23-2012, 07:42 AM
06speed's Avatar
Sorry to resurrect this again, but I need some help/input.
My cousin performed this procedure and cleaned his thermostat, however a few weeks later, has a leak. What are his options?
Ive read some guys just gut it all and weld it up....
Any other options? I'm not sure if the o-ring is damaged or housing scored or what.
Thanks.
'06 2500 4x4 QC, G56(MD-50wt)-ValAir Dual Disc, Jacobs ex.brk, crazy larry, Firestone ride-rite bags, Baldwin f/w sep + Cat 2mic filter, EV2-lift,rail,EGT,boost, MBRP 5" w/muff, OEM intake w/Banks Scoop
06speed is offline
post #56 of 300 (permalink) Old 05-23-2012, 08:30 AM
pepsi71ocean's Avatar
Thanks.
I would say have him take it apart and then put it back together and see if anything is torn or broken when putting it back together.
99 3500 Built DTT Auto, 600 lower TC, 3.55, 4x4, BHAF, 6" lift, ARP's, Danin Optix, Gauges, DAP 100hp sticks, FASS 95, 2LO kit, HIGH Idle, Silencer ring delete, 4" exhaust, SMARTY, 03 VW PASSAT 1.8T Big Thanks to (FTE Diesel),(DAP),(DTT)
They ROCK!
pepsi71ocean is offline
post #57 of 300 (permalink) Old 05-23-2012, 08:54 AM
06speed's Avatar
OK. We'll give that a shot first. He talked about tapping threads and plugging the end of the tube. We'll see. Thanks.
06speed is offline
post #58 of 300 (permalink) Old 05-23-2012, 09:18 AM
Unless you live in a really cold environment I would pull it out, take it to a machine shop and have them weld that hold shut (take the thermostat and everything out of course). I am seeing much cooler tranny temps and I live in Southern Wisconsin and have no problems getting my tranny up to operating temp in the dead of winter. That thermostat is only there to help your tranny warm up to operating temp in cold conditions.
post #59 of 300 (permalink) Old 06-04-2012, 02:19 AM
Did you buy one?
post #60 of 300 (permalink) Old 06-04-2012, 09:12 PM
For the folks that want to make the cooler have full flow and cool all the time. Remove the internals as previously described, leave out the little metal rod, flip the brass thing around, placing it in backwards. Now it blocks the bypass. Then the spring, plug with a new o-ring. Make sure the area where the o-ring sits is smooth with fine sand paper. Enjoy lower temps.
04.5 CC SB 4x4, Garmon stage 2 trans, HPT tuned by Firepunk, GDP walbro pump with 2mic filter set up. BMS 50 injectors.
Home made traction bars that are awesome.
jballou is offline
The Following 4 Users Say Thank You to jballou For This Useful Post:
24hrsparkey (04-24-2016), Blast Chamber (04-02-2016), condoraircraft (08-23-2012), Talon4u2nv (01-26-2015)
