Glow Plug light stays on while driving - Dodge Cummins Diesel Forum
post #1 of 20 (permalink) Old 07-30-2011, 02:22 PM Thread Starter
DCullotta53's Avatar
I was driving today and the wait to start/glow plug light started flashing along with chimes. Now it's on permanently. Anyone know why that is. All other gauges read ok. No check engine light and truck starts and shuts down as normal. Any help would be appreciated
2006 Ram 2500 Quad Cab short bed 4x4, Banks Power CAI with Super Scoop, Fuel Filtration system from the RightConnection LLC, & Smarty Jr.
1973 Dodge Challenger 340 4bbl
DCullotta53 is offline
post #2 of 20 (permalink) Old 07-30-2011, 02:39 PM
any codes? turn key to on(but dont start) then off, 3 times and if you have any codes they will show up in the milage. If not it will say done.
2004.5 QCSB, 2.5 Level, 20" Chromes, 33x12.5 Toyo Tires, Silencer Ring? aFe Intake, AutoMeter Pyro, Boost, Tranny, 4" Straight to 6" tip, Fender Flares, Smoked headlights, Cab Lights & Brake Lights
BadHazard is offline
post #3 of 20 (permalink) Old 07-30-2011, 02:51 PM Thread Starter
Nope, no codes. I've done some reading and most people stay they have rough starts if the light is staying on but mine acts as normal.
post #4 of 20 (permalink) Old 07-30-2011, 02:58 PM Thread Starter
I take that back. P1222 code.
post #5 of 20 (permalink) Old 07-30-2011, 03:17 PM
P0122-THROTTLE POSITION SENSOR VOLTAGE TOO LOW
do some searches on that. Maybe a shortage
post #6 of 20 (permalink) Old 07-30-2011, 03:22 PM
HELP p1222 code
there you go
post #7 of 20 (permalink) Old 07-30-2011, 05:15 PM
Master of Mayhem NASFIG
rpage's Avatar
Never heard the grid heater chime in of the 7 dodges i had, You sure your not looking at the water in fuel because it will chime and stay on
Really don't give a rat's App**
rpage is offline
post #8 of 20 (permalink) Old 07-30-2011, 08:52 PM
hate to be that guy, but the cummins does not have glow plugs. I had that similar issue a few years ago and had the replace the grid heater, you can get a cummins grid heater online fairly cheap.
2014 2500 Black Appearance Package big horn CTD 4x4.
Thuren suspension, Rigid 30 inch e series, rear air.
MPD106 is offline
post #9 of 20 (permalink) Old 07-30-2011, 09:14 PM Thread Starter
Thanks for the help guys. Much appreciated.
post #10 of 20 (permalink) Old 07-30-2011, 09:31 PM Thread Starter
Would you suggest swapping the grid heater? Where is it?
post #11 of 20 (permalink) Old 07-30-2011, 09:51 PM Thread Starter
I have had my smarty jr for 6 months and had it set on towing since day one. Would setting it back to stock help?
post #12 of 20 (permalink) Old 07-30-2011, 10:08 PM
rpage's Avatar
its under the air intake horn on the manifold. you can disconnect the wires for it or pull the fuse or its a relay not sure which it is.
rpage is offline
The Following User Says Thank You to rpage For This Useful Post:
jamesh23 (07-02-2014)
