Need advice on "Defueling Coolant" - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 07-09-2011, 05:59 PM Thread Starter
JasonDykstra's Avatar
I need some help here. When I am towing up a steep hill the engine sometime start to cut power because the temp starts to climb. I have a bullydog GT tuner and when I looked at it it said "defueling Coolant. The programmer is in tow mode (low power) but after coolant temp climbs past 210 degrees the programmer goes to no power (stock). It will still give some power but slows down to about 50-55 MPH. This did this while programmer was off also and even does this in tow mode. Anyone heard of this before and is it normal or do I need to have it looked at? Only happens when I tow.
07 2500 5.9L 4x4 megacab. K&N filter, BullyDog GT tuner, muffler delete, leveled, 18in motometal rims w/34inch terra grapplers
JasonDykstra is offline
post #2 of 3 (permalink) Old 07-09-2011, 08:47 PM
mkwelds's Avatar
I think its more like defueling because of coolant temperature. So go down the list is ur radiator full if so does thermostat work all good there replace the temp sensor and so on and so on. Its basically the engine trying to protect itself and what the gauge shows on the dash might not be the actual temp so thus might be saving ya from some serious issues. Just sounds like u have a colling issue so find it and fix it and that'll fix the defueling. Oh and also before any of that check the settings on ur programmer they might be set to shut down at that temp in which case u need to change it to a more realistic number like 240 or 245just cause anymore than that u will be pushing ur luck big time and even that's hot for what normal is temp is
2004.5 3500 4x4 NV5600, PDR Cam, ARP 425s, industrial injection 60 horse injectors, Raptor 100 fuel pump, DIY 2micron fuel filter system with big line upgrade, HE351 over S475,more brewing
SMARTY S06 and UDC fine tuning all of it
mkwelds is offline
The Following User Says Thank You to mkwelds For This Useful Post:
Newbi ram canadian (02-01-2016)
post #3 of 3 (permalink) Old 07-09-2011, 11:21 PM
macko300exc's Avatar
What you need to do is change the defuel set point for coolant temp. My Triple Dog will do this with the monitor.
macko300exc is offline
