Fuel Control Actuator ...anyone 'know' if this is the problem? - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 07-07-2011, 03:10 PM Thread Starter
Okay ...have a 2006 5.9 Cummins Diesel 2500, with a little over 200,000 miles on it... that is very hard to start. Can be started with a can of Ether and that's the only way. Also, the service soon light comes 'on' when I do finally start this truck with the can of Ether. It'll flash @ 10 times and shortly after I have begun driving it, then the service soon light will go off. Took it to Auto Zone & they said the code stored was a PO148; which indicates a Fuel Control Actuator (FCA); Fuel Delivery Problem-with this code.
In trying to locate this part locally, it appears to be a dealer item only & they want $247.00 vs. $115.00 online at purediesel.com. Can anyone help with this? The part number that was given to me is 51832345AA; sound familiar? Or should I check something else first. Thanks.
Last edited by ACutAbove; 07-07-2011 at 06:26 PM. Reason: Additional Information ....
ACutAbove is offline
The Following User Says Thank You to ACutAbove For This Useful Post:
Austinv (12-10-2012)
post #2 of 12 (permalink) Old 07-07-2011, 03:52 PM
MotorCityMadman's Avatar
#1 scan for codes. Report back.
98 2500,4x4auto,48re vb,billet single,shift kit+, Super B, 4" ss,#10 ff,4gsk,.024s, 5x.014, BHAF,16* gauges,WVO, B164 bypass 2004.5 3500, SRW, FASS WVO, B164 bypass, Edge@1 Sold 96 2500 eclb 3gsk
MotorCityMadman is offline
The Following User Says Thank You to MotorCityMadman For This Useful Post:
post #3 of 12 (permalink) Old 07-07-2011, 04:32 PM Thread Starter
The only Code is the "PO148" ...Fuel Control Actuator in conjunction with Fuel Delivery problem.
post #4 of 12 (permalink) Old 07-07-2011, 04:46 PM
Or fuel delivery error.
If you disconnect the fca and start it should default to full rail pressure. I will sound very different. Shut off immediately. That may give some clue as to wether it is a malfunctioning fca.
ACutAbove (07-07-2011)
post #5 of 12 (permalink) Old 07-07-2011, 05:28 PM
domwilson4174's Avatar
Im haveing the same problem in my 2003 will only start by spraying into the intake. When mine started to do this I changed the fuel filter and everything was fine for a week now it is cranking hard agian and will not start. My truck is displaying 4 codes p0107, p0516, p0642, and p0480.
If im not digging the coal im rolling the coal.
2003, 3500,Singel rear wheel axle, 5.9, auto, quad cab, short bed, STOCK
domwilson4174 is offline
The Following 2 Users Say Thank You to domwilson4174 For This Useful Post:
ACutAbove (07-07-2011), Austinv (12-10-2012)
post #6 of 12 (permalink) Old 07-07-2011, 05:46 PM Thread Starter
The same was true with changing the fuel filter on this one too. It would run for about a week...the fuel filter would look like it needed changing again ...I'm on my 4th fuel filter ...its is very monotonous; especially when I have to use it from job to job & it will not start without the Ether ...I'm told that I could really screw the engine up on a diesel using the Ether on it. Let's hope that its the Fuel Control Actuator, rather than anything that is more expensive. The only code that shows up is this PO148 - Which implies that its a fuel delivery issue.
Thanks for your input.
post #7 of 12 (permalink) Old 07-07-2011, 05:52 PM Thread Starter
Thank you for your help ...I will give it a try.
post #8 of 12 (permalink) Old 07-07-2011, 05:52 PM
For s and giggels I just tried unplugging my FCA to see if my problem was simmalir to your but agian would not start
post #9 of 12 (permalink) Old 07-07-2011, 05:58 PM Thread Starter
Well with enough people reading this post & giving us their suggestions, we're bound to figure it out through elimination...keep me posted if you hear anything else ...appreciate it.
post #10 of 12 (permalink) Old 07-08-2011, 08:27 AM
Sounds like you one or more leaking injectors, especially with 200K+ miles on them. Best way to tell is take it to a dealer and have the scan tool hooked up to monitor rail pressure during startup. Too low rail pressure the fuel doesn't atomize correctly and makes for a difficult start.
MikeyB
MikeyB is offline
The Following User Says Thank You to MikeyB For This Useful Post:
ACutAbove (07-09-2011)
post #11 of 12 (permalink) Old 07-08-2011, 09:43 AM
Too low rail pressure and the computer will not signal the Injectors to fire.
post #12 of 12 (permalink) Old 07-08-2011, 10:05 AM
Everyone Should Watch These Vids Tons Info
________________________________________
YouTube - Dodge Ram/Cummins 5.9L High Pressure Common Rail Diesel Engine Part 1 of 4
YouTube - Dodge Ram/Cummins 5.9L High Pressure Common Rail Diesel Engine Part 2 of 4
YouTube - Dodge Ram/Cummins 5.9L High Pressure Common Rail Diesel Engine Part 3 of 4
YouTube - Dodge Ram/Cummins 5.9L High Pressure Common Rail Diesel Engine Part 4 of 4
you can do this without the special tools, i had to troubleshoot one before i could get the miller tools in. the tools are only about $100 total and well worth it.
063500dually4X4qcg56,dynatrac,bd exhaust brake,donaldson m090535muffler,cfm+,winspeed spacer,smartyjr,taylor wings,luberfiner bypass filter,psm cold air,cool hose,tag,air tab's,pdr cam,ddp50hp injectors,htt 62 65 13ss,ss manifold, turbo and manifold blankets
carl48 is offline
The Following 2 Users Say Thank You to carl48 For This Useful Post:
ACutAbove (07-09-2011), Deserttoyhauler (10-27-2012)
