How to tell if axle u-joints are going bad? - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 06-30-2011, 10:09 PM Thread Starter
ThatDudeOrion's Avatar
I think my axle u-joints are starting to go, but I'm not sure...
Symptoms are that while driving straight ahead, everything feels normal, but when I turn, it feels like the front end is binding up like it does when I turn too tight in 4WD. Is that the angel of u-joint death telling me to get my affairs in order?
I'm at roughly 80K miles now, and I suppose I should do ball joints and wheel bearings while I'm at it, correct?
ThatDudeOrion is offline
post #2 of 12 (permalink) Old 06-30-2011, 11:21 PM
papaduck's Avatar
Jack up the front and with the wheels turned to one side, rotate the wheel by hand. If the joint is going bad it will get tight and loose every quarter turn.
If the bearing hubs are fine, why change them? If ball joints are loose you can check while it is on the jacks. Push and pull on the top and bottom of the wheel to check.
03 Dodge 3500 SLT, HO, 6 spd, 4x4, SRW, quad cab, gauge on lift pump-boost-EGT-engine oil pressure and rail pressure, FASS 95, water seperator and 2m filter, steering box brace, 6.7L fluid damper
papaduck is offline
post #3 of 12 (permalink) Old 07-01-2011, 01:29 AM
uc_bearcat_cummins's Avatar
Mine would making a squeaking noise when turning at slow speeds.
2007 Dodge Ram 2500 5.9 4x4 Auto Quad Cab SLT, Industrial Injection Dragon Fly 60's, S&B intake with scoop, grid heater delete, 5 inch straight pipe, Leveled, Custom MK2, 3in1 Gauges-Fuel Pressure/EGT/Boost, 18x9 Fuel Pumps on 295/70/18 Nitto Trail Grapplers
uc_bearcat_cummins is offline
post #4 of 12 (permalink) Old 07-01-2011, 04:28 PM
CoronaL's Avatar
newbie here, but with other cars I've had similar issues with the differentials and needing to add some friction modifier or service the diff
CoronaL is offline
post #5 of 12 (permalink) Old 07-01-2011, 07:56 PM
ROTTI54's Avatar
Mine just started acting up this week. I am getting a shimmy back and forth in the steering wheel as I turn. It is worse at slow speeds and I am getting a squeaking sound as well. I will be replacing them and the unit bearings in the upcoming weeks.
[B]2004.5, 5.9 HO Auto, Laramie, Gray w/Black Leather, Snow Plow Pkg., Tow Pkg., 4.10 Rears, MBRP T304 Duals, AFE Bladerunner, AEM Brute Force Intake, 08.5 Steering Upgrade, Mag Hytec Diff & Trans, HID's, Tint, Kore Performance Leveling Kit, 35" Toyo M/T's, Isspro triple gauge pod, Smarty Tuned!
ROTTI54 is offline
post #6 of 12 (permalink) Old 07-01-2011, 08:03 PM
Ain't No Boys Toy.
Kearnz06's Avatar
The best way I know my u joint was going bad was when I turn the wheel either way. It would jump and jerk. So I jacked the front end and a buddy climbed under and moved the U joint itself and said it was bad. They will also click when they are bad. I would not replace the ball joints unless they are bad. They become loose and move up and down in there. I replace my one u joint with only 89,000 miles on it. Now I have no jerking or anything.
Kearnz 2006 2500 Quad cab White with blue. Completely stock engine. Six speed manual. 2.5 Rough Country leveling kit. MT Classic Beadlock with 35's. Its a work in progress.
Don't care if you are carrying your load or carrying your a**. You better be carrying something.
Kearnz06 is offline
post #7 of 12 (permalink) Old 10-22-2011, 07:43 PM
Mopar Morris's Avatar
Mine has 117K miles and I just put in all new u-joints and upper and lower ball joints. Lots of squeaks and cracks as well as some vibrations from the u-joints prior to the recent work. Lots of frustration at having to change all of this at what I consider low milage. I used all Napa parts by the way. I think they hold up better than Moog parts.
Mopar Morris is offline
post #8 of 12 (permalink) Old 10-22-2011, 08:34 PM
rdefayette's Avatar
axle u-joints
Jack the wheel (have it turned all the way, doesn't matter which way)
look at the cups where they go onto the u-joint X. More than likely you'll see what looks like rusty water streaks coming out or chunks of the cups broken off at the edges.
If you have to replace I use greaseable (MY choice). Check the unit hub bearings and ball joints before tearing into it. Unit/hub bearing has to come off so if it looks questionable and you're almost to the ball joints so if they're iffy, why not.
Bob, Current;
'04.5, 2500HO,Auto,QCLB,4x4,CAI,4" TB,Smarty Jr,AD II 100,Flex-A-Lite fans, homebrew headache rack, "wedge" cap, Home brew rear bumper, Yukon Free Spins
'03, 3500,QCLB,4x4,Dually,RIP
rdefayette is offline
post #9 of 12 (permalink) Old 10-22-2011, 08:36 PM
rdefayette's Avatar
u-joints
Dodge does NOT use friction modifiers (sp?). Synthetic fluid, no clutches.
Bob, Current;
post #10 of 12 (permalink) Old 10-23-2011, 12:12 AM
Klickster102's Avatar
grab each side of the axle with the ujoint in the middle, if you can turn both shafts the opposite way and theres play that means there bad.
2006 Dodge 5.9 Cummins Bighorn, K&N intake and filter, 5" exhaust, 2" leveling kit, isspro gauges, blacked out headlights
Klickster102 is offline
post #11 of 12 (permalink) Old 10-23-2011, 08:50 AM
ROTTI54's Avatar
My axle u-joints were popping and as I would steer at slow speeds the steering wheel would shudder back and forth violently when they were going bad.
ROTTI54 is offline
post #12 of 12 (permalink) Old 10-23-2011, 09:02 PM
LR11's Avatar
you know I discovered that when a red dust (rust color) would develope on the rim the ujoint was going out.
05 hd 25 laramie 6sp and still stock
LR11 is offline
